Boss grille on V6? - Mustang Evolution
Old 08-29-2015, 06:54 AM   #1
Hampton CIT's Avatar
Boss grille on V6?
I understand the Boss grille is not a direct fit for the 13-14' V6. Does anyone know if there an adapter or would some modification make it fit? I can't see ford mass producing two different types of mustang fascias. Small connectors and clips yes but structurally, isn't it basicly the same. This is what I'm looking at guys. Ford Racing Boss 302S Mustang Grille w/ Emblem - Unpainted M-8200-MBRA (13-14 GT, Boss) - Free Shipping
2016 Premium Eco w/ PP - Roush Quarter Window Scoops, Side Scoops, Rear Spoiler; Modded GT Mesh Grilles; FP Strut Tower Brace; Eibach Pro-Kit Springs; Steeda IRS Bushings; BMR Billet Delrin/Spherical Vertical Links; Mishimoto Oil Separator; MAPerformance CAI; Mishimoto Intercooler/Aluminum Charge Pipes; Turbosmart Kompact Dual Port BOV; Turbosmart IWG75 Wastegate (10 PSI); Mishimoto Coolant Tank; JLT Engine Cover; Mishimoto Downpipe with modded MBRP XP Catbacks for TRUE 3" exhaust from turbo to tips; Drilled/Slotted Brake Rotors
Hampton CIT is offline   Reply With Quote
Old 08-29-2015, 09:56 AM   #2
Grabber Blue's Avatar
I'm pretty sure all you need is a GT grill surround to make it compatible. The V6 has that ugly chrome one. (Unless you have an MCA or PP).
Here is a kit that has everything you need. http://pages.ebay.com/motors/link/?n...974398&alt=web
Here is the grill surround alone: http://www.starkey-products.com/must...ound-2013-2014
Also note that the honeycomb part of the grill is a little different than the V6. So If you have a stock V6 bottom grill it won't match perfectly. But it's not that big of a deal.
Anybody feel free to correct me if I'm wrong!
Grabber Blue is offline   Reply With Quote
Old 08-29-2015, 10:05 AM   #3
Kevin.Cook
Guest
Posts: n/a
The chrome ring is 1 piece with the base grille. So when you pull it out, and yes you can pull it out without removing the bumper, the whole thing comes out.
I put the pony package one in mine.
Old 08-29-2015, 03:28 PM   #4
It's not a big deal to remove it. I plasti-dipped mine a while back. Thanks for the link Keven. good price on both pieces too! Getting the surround to fit doesn't worry me to much. Modifying the grill alone is scary on a 300 piece. Anyone had any success in swapping out the surround?
Old 08-29-2015, 03:31 PM   #5
Kevin.Cook
Guest
Posts: n/a
Lol. I didnt give the links man. XD
Old 08-29-2015, 04:06 PM   #6
NewMtang's Avatar
Why Boss Grille?
What are you going to do with the empty spots for the fog lights?
Old 08-29-2015, 07:21 PM   #7
Commercial Member
au01st's Avatar
Everyone is just used to you taking credit for things!
Sent from my #racecar
Have a Raxiom nav system? Hate having two antennas? Contact me to wire your nav thru your factory satellite radio antenna!
"Holy crap bro. You're a genius." - 2011 Kona Blue
au01st is offline   Reply With Quote
Old 08-29-2015, 07:54 PM   #8
Whoops. Thanks Grabber Blue for the links. Actually, they helped me out tremendously. I never noticed that the hex grille of the boss unit didn't match the lower V6 grille. That would drive me nuts if the collars and cuffs didn't match. Thanks! You are usually so quick with a good link Kevin, I just assumed.
Old 08-29-2015, 07:58 PM   #9
NewMtang's Avatar
Pony Package
_________________
If your V6 came with the Pony Package, the only Grille Upgrades that plug in are the MCA and the Roush. I ordered the Upper and Lower Roush.
Old 08-29-2015, 08:11 PM   #10
Abominable Mustang
WhoDat's Avatar
Region: Alaska
Originally Posted by NewMtang View Post
_________________
But if you get the grill surround stated above, the other grills will also fit on a PP V6
2012 Kona Blue 3.7L V6:
Old 08-30-2015, 07:54 PM   #11
NewMtang's Avatar
I am not sure if it would or not. I was wanting the Cervini Lower and Upper grilles. But after looking at the Roush grilles, they look great to me.
Old 08-31-2015, 11:16 AM   #12
GRREEN's Avatar
You guys are confusing me. I bought Boss 302 upper and lower
grills and put them on my 2013 V-6 three years ago. I just yanked out my old grills
after masking off the bumper so it wouldn't get scratched and snapped in the Boss grills ....I didn't remove the bumper. when I bought my Boss Grills the upper came with the black surround as part of the piece. The whole deal took me about 30 minutes. As I recall, the two grills were ridiculously expensive....hundreds of dollars for the lower one.
GRREEN is offline   Reply With Quote
Old 08-31-2015, 12:09 PM   #13
Kevin.Cook
Guest
Posts: n/a
I figured it was that easy.
Old 08-31-2015, 03:25 PM   #14
Looks great Grreen. I'm a big fan of the Boss upper grille but after Grabber Blue pointed out the hex pattern was different on the V6 so the upper and lower honeycomb wouldn't match, I'm rethinking do I do both as you did or go the Roush route. I have the Roush hood like yours also.
Old 08-31-2015, 07:40 PM   #15
I have the black gt grill surround you need for sale. Also the fog light deletes if you want them
mark09 is offline   Reply With Quote
Pony Package Grille to Boss 302 Grille w/ halos? OBEY 2011-2014 V6 Mustang 16 01-31-2016 06:07 AM
Wanted: Multiple 13-14 Parts: GT Grille Surround, BOSS 302 Grille, Axle-back OBEY Mustang Parts for Sale and Wanted 2 07-15-2015 06:50 PM
96 - 04 grille or grille delete?? rodrigo9 Mustang Paint, Appearance & Detailing 10 11-25-2012 01:13 PM
Replacing Stock Grille With Billet Grille hockeyfan67 1996-2004 Mustang GT 13 12-30-2009 09:03 AM
wtt my billet grille for mach 1 grille/chin spoiler tigerfan2771 Mustang Parts for Sale and Wanted 1 07-11-2008 07:27 AM
01:15 AM
