Questions on driveshaft install - Mustang Evolution
Old 09-05-2015, 09:00 PM   #1
I'm looking at the instructions to install driveshaft and notice that they put the front wheels on Rhino ramp and the two rear wheels on jack stands.
Here is my question. The front wheels are basically at loose with no gear or emergency brake holding them. Is this really safe? Will my car sliding off the ramp when I jack up the rear end?
2014 Mustang 3.7L cyclone engine with 6 spd transmission. Mods: 93 MPT Race Tune, 3.31 Gears, Airaid CAI, BBK Shorty Ceramic Headers, Corsa Sport axle backs, Strut Tower Brace, Steeda rear seat X-brace, BMR Rear LCAs, GT wheels, MGW race spec shifter, Passenger seat delete, spare tire delete, Moroso battery relocation to the trunk.
liv4spd is offline   Reply With Quote
Old 09-05-2015, 09:42 PM   #2
Mean14's Avatar
I didn't even lift the front tires up when I installed my DS. I chucked the front wheels and jacked it up from the rear as high as I could, put her on jack stands and had it changed in less than an hour.
Procharged D1 on 12Lbs, MPT 93 Tune, 73mm BBK TB, Ported Upper/Lower Intakes, BBK Shorty Headers, FRPP Cut n Clamp Xpipe, Borla S-Types, Barton Short Shifter/Blowfish Bracket, SS Clutch Line, Whiteline Trans Bushing, One Piece Driveshaft, Front and Rear Tower Brace, Whiteline Front and Rear Sway Bars, Whiteline Adj LCAs/Adj UCA, BMR Relocation Brackets, BMR adj Panhard Bar, Eibach Sportlines, FRPP Dampers, 20" AMRs, 3.55 gears, Brembos
Mean14 is offline   Reply With Quote
Old 09-05-2015, 09:46 PM   #3
Mean14's Avatar
Name:	ImageUploadedByMustang Evolution1441507404.601744.jpg
I actually had mine on ramps in the front and the rear jacked up the other day when I changed trans fluid. Just make sure you're not on a hill or anything. If you have a inclined driveway like I do in that picture, make sure the ramps are facing "downhill" because they have a built in chuck on the front to prevent the car from rolling forward off the ramps. You will be fine. It's going to have to take a lot of force to get that rear end to move off of the jack stands.
If you're still worried about it after you get the car raised up, go to each corner of the car and shake it. Lol. If it doesn't budge, then you're good. If it falls off... Well... Better the car than you.
I am not responsible for the damage you may cause to you or your ride.
Old 09-05-2015, 10:17 PM   #4
Thanks! Good to know this is possible.
Attachment 190726
Thank you for sharing your experience. Considering that I'll have to use a lot of force to break the bolts loose, it's important to be extra cautious.
Old 09-05-2015, 11:03 PM   #5
I do mine on a lift.
But no, it won't move if its level. But you don't have to put the front on ramps either.
Rear wheels need to be free so you can set and unset the E brake or the DS will just spin when you go to remove the bolts. If its an older vehicle, suggest you buy a torch and soak the bolts in liquid wrench overnight.
2000 Mustang GT Steeda #0048
Old 09-05-2015, 11:19 PM   #6
What I've found out is that if on level ground you can put the fronts onto the ramps then jack the rear of the car fine since the jack wants to move forward as you jack it up. Just don't lower the car down that same way or else the car will roll back toward you until the rear wheels touch the ground........
Ask me how I know this lol
Old 09-06-2015, 09:18 AM   #7
Thanks. Hopefully, I won't need a torch.
Thanks for the warning about lowering the car after it is done. This is important to keep in mind
Old 09-06-2015, 09:21 AM   #8
Another question.
I know that after I took off all of the 8 bolts, the driveshaft will probably stay, thanks to the rust. If I don't have a helper, what is the best way to knock it off? Hammer the rear end first, and put some cushion between the front end of the driveshaft and the exhaust pipes? Or it is better to hammer the front end of the driveshaft first?
Old 09-06-2015, 09:25 AM   #9
Go from the rear.
2013 SGM 3.7 | MPT Tune | JBA Titanium Ceramic Shorty Headers | MGW Gen 1 | Blowfish Street Bracket | BBK TB | 18" Charcoal AMR | FRPP 3.55 | BMR LCA | Steeda Panhard Bar | Dynotech 3.5" Driveshaft |
mariusvt is offline   Reply With Quote
Old 09-06-2015, 09:30 AM   #10
Thanks, man!
BTW, I am getting the Dynotech 3.5, after seeing your posts
Originally Posted by mariusvt View Post
Go from the rear.
Old 09-06-2015, 05:03 PM   #11
S197 GT's Avatar
Good info in here!
S197 GT is offline   Reply With Quote
WIN A 2015 Driveshaft Shop Driveshaft & Half-Shafts at AmericanMuscle! AMAlexLazarus 2015 Mustang GT 13 02-22-2015 03:54 PM
2015 Mustang GT Driveshaft Shop Aluminum DS Steeda Install tj@steeda 2015 Mustang GT 0 01-30-2015 09:01 AM
Driveshaft install without a lift dblhelx General Mustang Discussion 11 08-28-2014 07:31 AM
Upgrade Your Weak Stock Driveshaft with The Driveshaft Shop at AmericanMuscle AMWill AmericanMuscle 1 03-16-2014 03:18 PM
install your own aluminium driveshaft? roushcoyotepony 2011-2014 Mustang GT 12 01-04-2013 09:31 AM
11:33 PM
