Rear end leaking :( - Mustang Evolution
Old 09-08-2015, 04:03 PM   #1
jayochs's Avatar
Rear end leaking :(
so today when i got home, before i pulled into the garage, my dad showed me a bunch of new spots on the garage floor. so i pulled my car in to exactly where it was the day before, and it matched up with the rear end..the differential around the U joint area it looks like.
so we get under and look, and it seems the whole thing was just wet.
the axle looks bone dry, where other peoples were wet on the drivers side
great. my rear end is leaking.
ugh time to make an appt to leave it with Ford! luckily i'm still in the 3 year warranty but has anyone else ever had this issue before? is it a quick fix from Ford or are they gonna have my car for a week?
uggggggh
2014 Ford Mustang 3.7 Premium 6-speed:
MPT Performance Tune, AM Laguna Seca Black 19" Rims, Borla Touring Axlebacks, Boss 302 Strut Tower Brace, Airaid Modular Intake Tube, aFe Pro Dry S Air Filter, Mustang GT Grille w/ Foglight Mesh, Taillight Tint, Tinted Door Ventvisors, Diode Dynamics LED's
jayochs is online now   Reply With Quote
Old 09-08-2015, 04:06 PM   #2
oxford5pointoh's Avatar
Prob the breather valve. Mine did the same thing. There is a revised part. No sweat.
Old 09-08-2015, 04:08 PM   #3
jayochs's Avatar
oh yeah? was it a quick fix for them?
Old 09-08-2015, 04:16 PM   #4
jayochs's Avatar
my dad actually got under and felt it (bc he can fit under it easier than i can without ramps lol) and he said it felt like the differential was wet, along with the exhaust pipes around it.
so i wonder if it's splashing all around or if it's sometihng else.
on another forum, someone said it was the rear diff. leak at pinion seal
Old 09-08-2015, 04:39 PM   #5
Takes 5 min
---------- Post added at 10:39 PM ---------- Previous post was at 10:38 PM ----------
Yeah I suppose it could be. Some have mentioned that. Either way sounds like it's under warranty
Old 09-08-2015, 04:44 PM   #6
jayochs's Avatar
i just took some pics...it's not the same area leaking that i've seen on other peoples with the breather valve problem. it's the entire bottom of the differential, and on the exhaust. check it out:
also, god the bottom of this car is disgustingly rusted lol.
Old 09-08-2015, 04:58 PM   #7
tym_v6's Avatar
If it's the pinion seal, there will probably be a line of cast-off oil on the exhaust pipes and underside of the car (basically lining up with the pinion flange area).
My car had that and the dealer "fixed" it, but messed up (probably didn't torque the pinion nut correctly), that the bearings crapped out and I needed a full rebuild within a few months. So, I would encourage you to have the service dept. guarantee that a rear end specialist does the work to save you hassle down the road.
Old 09-08-2015, 05:13 PM   #8
jayochs's Avatar
ugh jesus. so what do I tell them? I'm going to call to make the appointment and drop it off on a Sunday night for Monday most likely. what exactly do i say or write? I can leave a note when i drop off the key.
Sent from my Galaxy Note 4
Old 09-08-2015, 05:15 PM   #9
tym_v6's Avatar
Just ask the service writer if they have a rear end specialist that can do the work and have him note it on the service order. He could of course lie to you, but at least it should be documented in case they fudge something up. It might also be worth having Deysha with Ford Customer Service elevate the issue to the regional manager (she posts on other Mustang fora, but I don't think she is on ME).
Old 09-08-2015, 05:19 PM   #10
Kevin.Cook
Guest
Posts: n/a
If your rear is leaking, may want to go see a doctor....just saying...
Old 09-08-2015, 05:31 PM   #11
That's definitely the pinion seal and not the common breather on the driver's side.
2013 SGM 3.7 | MPT Tune | JBA Shorty Headers | MGW Gen 1 | Blowfish Street Bracket | 18" Charcoal AMR | FRPP 3.55 | BMR LCA | Steeda Panhard Bar | Dynotech 3.5" Driveshaft |
mariusvt is offline   Reply With Quote
Old 09-08-2015, 05:38 PM   #12
Yeah with that pic it's obvious you have a leak from the front
Old 09-08-2015, 05:51 PM   #13
ragtopman's Avatar
Yes, looks like the pinion seal. I just had the exact same prob on mine. It was the perfect time to upgrade my gears(3.73) and have all the bearing and seals done. Looks like urs is definitely from the front and goes back so most likely pinion seal. Sorry bro...
ragtopman is offline   Reply With Quote
Old 09-08-2015, 10:24 PM   #14
5pointYoBro's Avatar
Awh man.... This is exactly what mine looks like right now, and ive got rear end "whine"
Am I screwed?
2014 GT. Oxford White.
20" Velgen VMB5s on NT555s.
MBRP Race Series Catback Exhaust
Bama 93 Performance Tune
5pointYoBro is offline   Reply With Quote
Old 09-09-2015, 04:54 AM   #15
jayochs's Avatar
this isn't a bad problem though, is it? it's under warranty, so if i bring it in, it probably won't be a hard fix, right?
Old 09-09-2015, 10:44 AM   #16
olerodder's Avatar
Region: Oregon
My 14 had the same pinion seal leak and it was replaced under warranty, at the time my car had 7800 miles and it now has 9800 miles. I talked with the mechanic and he showed me the old pinion seal...which is plastic...he put in a revised seal which is metal......haven't had any issues in 2000 miles of hard driving.
Old 09-09-2015, 11:35 AM   #17
jayochs's Avatar
cool. I just made an appointment for Monday. hopefully it's a quick fix and i can pick it up Monday night after work. mines got about 13k miles on it
Old 09-09-2015, 09:23 PM   #18
this isn't a bad problem though, is it? It's under warranty, so if i bring it in, it probably won't be a hard fix, right?
Sent from my galaxy note 4
someone who knows what he is doing and has the proper tools to torque the new crush sleeve about a 45 min job about two hrs if replace bearings if remember correctly re torque to 250 ft lbs. Suggest they replace bearings on penion shaft at same time,never saw a seal leak that wasn't caused by bearing wear!
ALLYDRIVER1 is offline   Reply With Quote
Old 09-10-2015, 07:41 AM   #19
olerodder's Avatar
Region: Oregon
I understand what you are saying about never seeing a pinion seal leak that wasn't caused by pinion bearing wear..........have you ever seen a plastic pinion seal?
Old 09-10-2015, 08:42 AM   #20
fenixignition's Avatar
if it's a breather valve issue, then is it too much pressure inside causing this? This is the same 8.8 rear end ford has been using for years. I have 160k miles on mine and nothing's leaked. How are your newer cars leaking this much?
also if you have a leak and a whine, top it off. should be 75w140 synthetic with limited slip.
or do you guys have a 7.5 inch axle? in which case, 75w90 i believe. I forgot what year the v6 changed over to 8.8 rear end.
2002 GT 5sp. 16x,xxx miles
Old 09-10-2015, 09:45 AM   #21
shunc01's Avatar
Would upgrading the differential cover help compare to the oem cover? Like the steeda diff cover. Just curious..
MPT tune, Axle exchange Aluminum driveshaft, 3:73 gears, borla stype, frrp x pipe, Mac ceramic shorty headers, airaid cai, Jlt separator, koni orange shocks and struts, SR Springs, gt500 mounts, J&M Panhard bar, Bmr LCA, 2010 gt500 wheels, roush chin splitter, roush louvers, and RTR stripes... 😎 🚘
2016 GT RACE RED MANUAL aka " RAGING BULL"
Mods:
Borla stypes cat back exhaust, tint kit all lights, 5.0 race red shift knob, MMD V SERIES SPOILER... and more to come...
shunc01 is offline   Reply With Quote
Old 09-10-2015, 09:58 AM   #22
Strange Mud's Avatar
it would look better and if it's made in America it would help the economy.
Old 09-10-2015, 09:59 AM   #23
Originally Posted by olerodder View Post
i understand what you are saying about never seeing a pinion seal leak that wasn't caused by pinion bearing wear..........have you ever seen a plastic pinion seal?
no,must be a ford thing
Old 09-10-2015, 10:03 AM   #24
tym_v6's Avatar
A couple of other advantages of a billet aluminum girdle are: (1) have a drain hole built in, so no need to crack the cover to change fluid and (2) the girdle theoretically strengthens the whole housing and has studs to keep the carrier bearing caps in place...looks nice but may not add much given the power levels of the V6.
Old 09-10-2015, 10:06 AM   #25
olerodder's Avatar
Region: Oregon
Would also dissipate heat better............that's what the fins are for.
Old 09-14-2015, 11:25 AM   #26
jayochs's Avatar
so dropped her off last night under the night drop off. said they'd look at it first thing this morning. waiting on a call, but nothing yet. maybe I should give a call to make sure they got it etc
Old 09-14-2015, 11:49 AM   #27
jayochs's Avatar
bah they have to order the part. won't be in til end of week so he suggested I just come pick it up today then bring it back once he gets the part next week.
Old 09-14-2015, 12:03 PM   #28
I hate dealerships, the one in my town always BS's me like this
Old 09-14-2015, 12:09 PM   #29
olerodder's Avatar
Region: Oregon
So........what part did they have to order that will take so long???
Old 09-14-2015, 04:00 PM   #30
jayochs's Avatar
according to the paper i got, it says
"customer states rear differential leaking bottom differential wet, maybe bad pinion seal leaking."
"VERIFIED concern found pinion seal leaking. ordered seal"
under it says SEAL ASY - OIL 1 W BR3Z4676A
also says performed free multi point inspection
i didn't wanna leave it there for them to get it Friday then install it Friday, only because I've got plans for a 4 day weekend this weekend, so I need the car. the service manager said it'd be better if I just picked it up anyway, then when he gets the part, schedule the fix for next week. he suggested monday, but that's part of the weekend I need the car, so I said Thurs and he said that's fine. hopefully it'll be a quick 1-day fix.
also inquired about airbag recall..he said they don't even have any of the parts for it, so he couldn't do it for me. worth a shot though! lol
Old 09-14-2015, 04:03 PM   #31
olerodder's Avatar
Region: Oregon
Here is the part;
AutoNation Ford White Bear Lake | Parts & Accessories
So for a $12 part you won't have your car for how long??????
Old 09-14-2015, 04:31 PM   #32
Waylap1's Avatar
Region: New Hampshire
Well this thread was misleading.
Waylap1 is offline   Reply With Quote
Old 09-14-2015, 04:35 PM   #33
jayochs's Avatar
Here is the part;
a day, hopefully. he had to order the part. and i guess shipping to the dealer from wherever they get it will take about 3-5 days.
that's why i took my car back; it's back home. i'll bring it back next thursday and hopefully bring it home thursday evening.
---------- Post added at 06:35 PM ---------- Previous post was at 06:35 PM ----------
gross. lol
Old 09-15-2015, 12:44 AM   #34
tym_v6's Avatar
I thought dealers could get most parts next day unless there was a backorder. I find it hard to believe a common seal would be backordered...wonder if the dealer is doing some yarn-spinning.
Old 09-15-2015, 05:49 AM   #35
jayochs's Avatar
dunno. I mean, what do they have to gain by doing that? they don't have my car or anything.
Rear Diff is leaking, OH NO!!!!!!!!!!!!!! drusmith 1996-2004 Mustang GT 13 02-21-2011 03:55 PM
Rear end leaking.... allnotch 1996-2004 Mustang GT 13 06-28-2010 07:56 PM
How long is a mustang rear end compared to a ranger rear end. lenth meaning from tire to tire? macray33 General Mustang Discussion 1 03-14-2010 03:43 AM
Is a 1995 Mustang V6 rear end different from a 1995 Mustang V8 rear end? celyddon Pre-2005 V6 Mustang 2 08-25-2009 06:56 PM
Leaking rear Calumus 1996-2004 Mustang GT 4 09-19-2008 04:41 AM
02:15 PM
