Anodized brake rotors - Mustang Evolution
Old 09-09-2015, 05:12 PM   #1
Hello I recently picked up a 14 V6 and I've done a bit of research on American muscle as well as a couple other sites but was unable to find a pair of front black anodized rotors.
Does anyone have any suggestions? I read in the beginners guide to basically stay away from the drilled rotors to avoid cracking, so I'm trying to do that.
Also, could anyone suggest a good pad? I'm going for mainly street use but increased performance. I can't stand the stock brakes!
Side note: does anyone know if it's possible to use someone else's remote tuner on my car? The tune seems great but it doesn't seem like 2-400 dollars great
Thank you
Deanbramer is offline   Reply With Quote
Old 09-09-2015, 05:20 PM   #2
Voltwings's Avatar
1. you only anodize aluminum, so you would either have to paint or powder coat calipers.
2. im partial to carbotech, so check out their 1521 pad compound.
3. I have a spare set of calipers i'll sell you if you want to get them powder coated so you dont have any down time.
Questions about powdercoating:
Barton Shifter + 11-14 brake parts
Edit, i just realized i read your post wrong. That being said, you would still have to paint the rotors, powdercoating may not work the same... you're talking about just the hats right? Not the whole rotor?
Old 09-09-2015, 05:22 PM   #3
I'm not really interested in any calipers although I appreciate the offer. Right now I think all I really need is a nice set of rotors and pads. The stock pads and rotors over heated on me trying to stop from 100mph and I think the rotors may have warped.
Old 09-09-2015, 05:51 PM   #4
Voltwings's Avatar
Trust me, they didn't, and how do you know they "over heated?" Also, what exactly are you looking for in "anodized rotors?"
Old 09-09-2015, 05:55 PM   #5
The reason I know they overheated is because the wheel started shaking violently and I could feel it in the brake pedal, The reason I suspect they're warped after is because now when I brake the wheel has a slight shake to it. They don't have to be anodized, it was just my first choice and was wondering if anyone knew of any because I'm having a hard time finding them.
Old 09-09-2015, 06:33 PM   #6
Mean14's Avatar
I've put drilled and slotted rotors on every mustang I've owned (still have to order for my current one). Never had any issues with cracking or warping. Keeps the heat down and prevents warping
Procharged D1 on 12Lbs, MPT 93 Tune, 73mm BBK TB, Ported Upper/Lower Intakes, BBK Shorty Headers, FRPP Cut n Clamp Xpipe, Borla S-Types, Barton Short Shifter/Blowfish Bracket, SS Clutch Line, Whiteline Trans Bushing, One Piece Driveshaft, Front and Rear Tower Brace, Whiteline Front and Rear Sway Bars, Whiteline Adj LCAs/Adj UCA, BMR Relocation Brackets, BMR adj Panhard Bar, Eibach Sportlines, FRPP Dampers, 20" AMRs, 3.55 gears, Brembos
Mean14 is offline   Reply With Quote
Old 09-09-2015, 06:53 PM   #7
tym_v6's Avatar
I managed to "warp" (or put a pad impression on) stock rotors with a panic stop at highway speeds. Probably that had more to do with not releasing the brakes after I came to a stop. And no, I wasn't doing 100 mph.
Old 09-11-2015, 10:05 PM   #8
NewMtang's Avatar
No, on using someone else's tuner. You have to set it up for only one car. Evening purchasing or if someone gave you a tuner for free, you have to have it unlocked and then purchase your tunes. Bama has lifetime tunes, which most people have purchased.
Looks like no one told you, to own a Mustang, get's expensive.
Old 09-11-2015, 11:09 PM   #9
2011 Kona Blue's Avatar
Thank you
In all the years (5) I have been on this mustang site and other mustang forums I have never heard to stay away from slotted/drilled rotors because they crack???? Where did you get this information from? A cracker jack box?
Now , I have seen debates on here if the drilled rotors were worth buying from a performance stand point. Many feel its strictly an apperence mod but never had anyone say they crack
Non 🍼and non 🌽fed. I $uck!
Old 09-12-2015, 02:15 PM   #10
pitboss's Avatar
I love my drilled and slotted rotors. coupled with SS lines and they are fimer. I had so much brake pad left though stock Im still using the stock pads. low dust. will switch in 6 months to better pads but for now system is working out for me. Only thing is I think I might need to upgrade to dot 4 fluid maybe since a lot of braking in the mountains causes brakes to fade somewhat
2012 Pony Pkg 3.7 convertible, MPT tuned, 4.10's, Dynotech 3.5" DS, Borla Touring axle backs, BBK 73mm TB and ceramic shorties, Whiteline sway bars and UCA/LCA with relocation brackets, BMR adj. PHB and brace, Steeda CAI, CE frame braces, Bilstein shocks, H&R race springs, SS brake lines, full HID, GT 500 gauge pod with gauges and misc. exterior upgrades
pitboss is offline   Reply With Quote
Old 09-12-2015, 02:42 PM   #11
Abominable Mustang
WhoDat's Avatar
Region: Alaska
Thank you
No, only one car can be tuned at a time because losing the tune marries the tuner to the car. You'd have to return one car to stock to tune the other. And the tuner/tune IS worth the money.
2012 Kona Blue 3.7L V6:
Old 09-12-2015, 05:45 PM   #12
Voltwings's Avatar
Non and non fed. I $uck!
It is strictly an appearance mod and they will crack in a performance standpoint (as in road racing). They look cool as hell, don't get me wrong, but they offer zero performance increase, and in some cases are worse than a premium blank.
Old 09-12-2015, 07:43 PM   #13
That has been the general consensus about the slotted/drilled rotots. They are an apperence mod and personally will get them myself. Love the look of them. Since I don't auto cross road race, I will not have cracking issues. 😀
05-10 GT rotors vs 11-14 3.7 rotors au01st 2011-2014 V6 Mustang 6 05-08-2015 08:22 AM
GT Front Brake Calipers and Rotors SVTCOBRA Pre-2005 V6 Mustang 23 07-20-2010 02:22 PM
Stock Front Brake Calipers & rotors off a 2002 V6. runvsofthisbull Mustang Parts for Sale and Wanted 0 05-27-2009 05:20 PM
brake pads and rotors electricstang Pre-2005 V6 Mustang 18 07-10-2006 03:18 PM
Installing Brake Pads and Rotors Mustang414 Pre-2005 V6 Mustang 13 05-21-2005 06:04 PM
12:45 AM
