Bearing Replacement - Mustang Evolution
Old 09-14-2015, 05:02 PM   #1
5pointYoBro's Avatar
Bearing Replacement
So I have to replace my bearings in the rear end.
Going to order this...
Ford Racing Mustang Ring & Pinion Installation Kit - 8.8in M-4210-B2 (86-14 V8, 99-04 Cobra, 11-14 V6) - Free Shipping
along with the axel bearings.
My question is, on the page I posted, it asks you to add a 2010+ rear gear pinion bearing.
But the kit says it comes with a 2012 GT500 rear pinion bearing, so do I need to add the other one??
2014 GT. Oxford White.
20" Velgen VMB5s on NT555s.
MBRP Race Series Catback Exhaust
Bama 93 Performance Tune
5pointYoBro is offline   Reply With Quote
Old 09-14-2015, 07:57 PM   #2
Do I need this...
Rear Mustang Gear Pinion Bearing - 8.8in (10-14 V8; 11-14 V6) - Free Shipping
If the kit in original post comes with the 2012 gt500 pinion bearing??
Old 09-14-2015, 07:59 PM   #3
Kevin.Cook
Guest
Posts: n/a
I want to say yes. I believe the gears for the GT and V6 grade are different. This is why I would assume each shop that sells them have them in different catagories. Unless someone can confirm the part numbers are the same.
Wait - I just saw what I think you meant. On http://www.americanmuscle.com/frpp-8...14v8-NoFitment
It asks if you want to add that additional $60 bearing. I believe it is the same thing. If not, just opt out and get that other one.
Old 09-14-2015, 08:13 PM   #4
Wait - I just saw what I think you meant. On Ford Racing Mustang Ring & Pinion Installation Kit - 8.8in M-4210-B2 (86-14 V8, 99-04 Cobra, 11-14 V6) - Free Shipping
Yeah I'm pretty sure its the same friggin thing. If you look through all the pics on the first link you can see the same looking bearing thats in the second link
And if i'm replacing all the bearings, will it hurt me to drive another 2 days? like less than 100 miles
Old 09-14-2015, 08:53 PM   #5
Originally Posted by LavaRedSixxer View Post
Do I need this...
give the vendor a call for clairification would be best move, then you will know you have everything you need
ALLYDRIVER1 is offline   Reply With Quote
Old 09-14-2015, 08:54 PM   #6
tym_v6's Avatar
Maybe you can call/chat with AM to see if they are the same bearing?
Old 09-14-2015, 09:10 PM   #7
If i'm getting all the new bearings and even a set of gears just in case(called and they are returnable if not used),, can I drive to work and school for 2 days?? less than 100 miles.
Or is it a bad idea?? Dont want to screw anything else up. anything besides the stuff im ordering
Old 09-14-2015, 09:20 PM   #8
Kevin.Cook
Guest
Posts: n/a
Well, why are you replacing this again? What gears do you have now? Auto or manual? Sorry, mobile app is s***.
Old 09-14-2015, 10:17 PM   #9
Auto 3.55's
I have bad rear end noise. Took it to someone and he says its forsure the bearings and maybe gears, wont really know until you open up the diff. But he also said there doesnt seem to be any gear backlash
Old 09-15-2015, 12:41 AM   #10
tym_v6's Avatar
^ There's got to be some gear backlash...if there is too little, your prior installer might have put them in too tight and this might be the cause of your troubles.
Is your diff leaking/low on fluid? If not, I'd say just drive on it another couple of days. Not much additional harm will be done, and you'll be replacing all the stuff that might get harmed anyways.
Old 09-15-2015, 04:25 AM   #11
Kevin.Cook
Guest
Posts: n/a
Possibly shimming is off also. Shimming is one of the more easier ones to not be dialed in/correct. But still requires taking everything apart to redo it. And its usually best to.
When they redid my gears, i had them swap all new gears in as well. As a bad wear pattern might have burned in.
Old 09-15-2015, 08:19 AM   #12
I'm just not going to drive it until Friday.
I dont want to make it worse...
But yeah I'm going to replace all bearings and got the gears just in case there bad too.
I wish someone could tell me if I need that extra bearing that it tries to get you to add. Guess I have to call AM
Old 09-15-2015, 08:24 AM   #13
Kevin.Cook
Guest
Posts: n/a
One would assume if it is suggesting it, then it doesn't come with the kit. You COULD drive it for a bit. Improper shimming - assuming its not crazy off, should still make the car driveable but it will make noise. And since they will be taking it entirely apart and redoing it, you SHOULD be fine.
However! I am not a mechanic and will not be held liable if something did break. Note that I drove mine for a week when it was making all of the horrible whining upon accelerating and slowing down.
Old 09-15-2015, 11:05 AM   #14
The mechanic immediately could tell that it was bearings when I took him for a ride. And the gears he said you wont really know forsure until you look at them.
How did you fix your gear whine?
Old 09-15-2015, 11:11 AM   #15
Kevin.Cook
Guest
Posts: n/a
For me it was improper shimming. It is still a hair off. But nothing overwhelming. And in the 3 months or so I have had them in the car, It has not got any more noisy then it was.
Old 09-15-2015, 11:44 AM   #16
If your bearings to go bad, is there anything else it can affect besides other bearings or gears??
Old 09-15-2015, 12:06 PM   #17
it could possibly burst the housing,not likely but maybe
Old 09-15-2015, 01:20 PM   #18
How do you know if that happens??
I'm not driving until Friday when I go to the shop, just curious
Old 09-15-2015, 01:26 PM   #19
rear-end dope runs out on ground and makes a hell of a racket and/or quits moving. believe me you will know
Old 09-15-2015, 01:28 PM   #20
Alright good. I have that pinion seal leak too but none ever drips on the ground and level is still good
Old 09-16-2015, 06:47 AM   #21
jayochs's Avatar
might as well get a new seal done while you're at it. mine just developed that, so I'm getting it done next week.
Sent from my Galaxy Note 4
2014 Ford Mustang 3.7 Premium 6-speed:
MPT Performance Tune, AM Laguna Seca Black 19" Rims, Borla Touring Axlebacks, Boss 302 Strut Tower Brace, Airaid Modular Intake Tube, aFe Pro Dry S Air Filter, Mustang GT Grille w/ Foglight Mesh, Taillight Tint, Tinted Door Ventvisors, Diode Dynamics LED's
jayochs is offline   Reply With Quote
Old 09-16-2015, 09:14 AM   #22
Yeah the kit comes with a new pinion seal and crush sleeve too.
I have the same exact leak that you do. Looks identical
Old 09-16-2015, 07:52 PM   #23
jayochs's Avatar
stupid ford seals. lol. I hope they replace it with something that's a revised part.
Old 09-16-2015, 08:48 PM   #24
Idk. It's whatever comes in the ford racing kit on AmericanMuscle.
Not getting the dealership to do it, not under warranty, and if I was it would be voided lol
Wheel bearing replacement DerekJohnScott 1979-1995 Mustang GT 5 03-08-2013 08:41 PM
Throw out bearing replacement cost 9tee7pony 1996-2004 Mustang GT 4 11-06-2012 08:30 AM
Pinion Bearing or Wheel Bearing? SCCofSV 2005-2010 V6 Mustang 0 09-30-2012 02:43 PM
pinion bearing replacement 1990mustang5.0 1979-1995 Mustang GT 12 05-07-2012 02:11 PM
Front Wheel Bearing Replacement 00vertstang Pre-2005 V6 Mustang 3 03-24-2007 09:42 AM
10:22 PM
