Bad experiences with CJPonyParts - Mustang Evolution
Old 09-16-2015, 11:57 AM   #1
I bought my Dynotech aluminum driveshaft from CJPonyParts. During the test drive there was a drone during deceleration. It was so bad that it caused me a migraine. So I immediately took it off.
When I contacted them for a return, and I was told that installed parts can not be returned. Installed = used, and used parts can not be returned They recommend me to sell it on craigslist or ebay.
Is this normal? I mean how can you figure out whether a part has a problem or not, unless you install it?
Any recommendations?
2014 Mustang 3.7L cyclone engine with 6 spd transmission. Mods: 93 MPT Race Tune, 3.31 Gears, Airaid CAI, BBK Shorty Ceramic Headers, Corsa Sport axle backs, Strut Tower Brace, Steeda rear seat X-brace, BMR Rear LCAs, GT wheels, MGW race spec shifter, Passenger seat delete, spare tire delete, Moroso battery relocation to the trunk.
liv4spd is offline   Reply With Quote
Old 09-16-2015, 12:07 PM   #2
Kevin.Cook
Guest
Posts: n/a
AM never gives me that problem and I have had to return bad brake pads and gears that were installed.
Maybe don't buy from CJ Pony Parts? I don't. LOL!
Old 09-16-2015, 12:18 PM   #3
Voltwings's Avatar
This is not uncommon. What's to stop someone from installing something wrong and damaging it and trying to pawn it off on the seller?
Also, did you try to diagnose the driveshaft issue at all, or did you immediately turn around and try to ditch it?
Old 09-16-2015, 12:22 PM   #4
natestang07's Avatar
I though added noise was common with a driveshaft?
Old 09-16-2015, 12:24 PM   #5
Kevin.Cook
Guest
Posts: n/a
I thought this too. Even when my 2014 had 3.31s, I would sometimes here a slight hum that wasn't there before the aluminum one. I assume the aluminum doesn't muffle sound as well.
Old 09-16-2015, 12:25 PM   #6
JimC's Avatar
So how much do you want for it?
JimC is offline   Reply With Quote
Old 09-16-2015, 12:30 PM   #7
Mean14's Avatar
I bought the same exact DS from CJPonyparts. I do get some vibrations when decelerating right around 2100rpms. This I found out is normal due to having a dual mass flywheel which increases vibrations. Thought it was the DS out of balance, but if it was out of whack, it would get worse at higher rpm and speeds and this is not the issue.
Make sure you've installed it correctly with the black boot towards the rear. Sometimes turning the shaft 90degrees will fix common issues.
Procharged D1 on 12Lbs, MPT 93 Tune, 73mm BBK TB, Ported Upper/Lower Intakes, BBK Shorty Headers, FRPP Cut n Clamp Xpipe, Borla S-Types, Barton Short Shifter/Blowfish Bracket, SS Clutch Line, Whiteline Trans Bushing, One Piece Driveshaft, Front and Rear Tower Brace, Whiteline Front and Rear Sway Bars, Whiteline Adj LCAs/Adj UCA, BMR Relocation Brackets, BMR adj Panhard Bar, Eibach Sportlines, FRPP Dampers, 20" AMRs, 3.55 gears, Brembos
Mean14 is offline   Reply With Quote
Old 09-16-2015, 02:41 PM   #8
They told me that the problem is that they think the driveshaft is 100% perfect, it is my gears that are generating the noise. They said without any defects, they can not get a refund from Dynotech.
Come on, I can not return an item that is not defective?
Old 09-16-2015, 02:47 PM   #9
Voltwings's Avatar
Why do you want to return an item that is not defective?
Old 09-16-2015, 06:04 PM   #10
I got a drone during deceleration, probably caused by the backlash of my differential gears. I say it is not defective, because there is no vibration of any sort.
That said, does it require a reason in order to make a return?
Old 09-16-2015, 06:06 PM   #11
Is the car lowered? If it is then your pinion angle is probably off unless you have an adjustable UCA. The vibration could be very slight to where it is causing an upset in sound waves, which could be a drone.
Old 09-16-2015, 06:20 PM   #12
DiESeven's Avatar
Return Policy:
60 Day Customer Satisfaction Guarantee!
Items purchased may be returned within sixty days of purchase for any reason
Items must be unused and in resale-able condition
All returns must be accompanied by the original invoice and return authorization
Special order items are non-returnable
No restocking fee will apply
Can't really put any blame on CJ when the item is not defective.
Old 09-16-2015, 06:39 PM   #13
Thanks, but my car is not lowered.
Old 09-16-2015, 06:46 PM   #14
This.
I don't get people who put performance mods on a car then expect it to be as or more quiet than stock.
2013 SGM 3.7 | MPT Tune | JBA Shorty Headers | MGW Gen 1 | Blowfish Street Bracket | 18" Charcoal AMR | FRPP 3.55 | BMR LCA | Steeda Panhard Bar | Dynotech 3.5" Driveshaft |
mariusvt is offline   Reply With Quote
Old 09-16-2015, 06:55 PM   #15
The point is that they never proved that the item is in unused and resalabe condition. They simply assumed it is not in unused and resalable condition, and their only proof is that it's ever installed, even though it only saw 10 miles on my car, and is in absolutely pristine condition.
If it is just slight increase in noise, why would I even try to return it? The drone was giving me a migraine, seriously.
Old 09-16-2015, 06:56 PM   #16
Originally Posted by liv4spd View Post
The point is that they simply assume it is not in unused and resalable condition without even have a chance to examine it. Their only excuse is that it is ever installed, even though it only saw 10 miles on my car, and is in absolutely pristine condition.
..... It was installed there for used.. They don't say unused or resalable
Old 09-16-2015, 07:12 PM   #17
Come on, this is a driveshaft. It can be installed and still in mint condition. I just examined the driveshaft, there is absolutely no signs of being used.
Old 09-16-2015, 07:35 PM   #18
I can buy a car drive it off the lot and drive right back to the lot and sell it and it is used.
Old 09-16-2015, 07:40 PM   #19
FastFord13's Avatar
Tbh, with the amount of people who have gone to an aftermarket $600+ driveshaft and have complained of more noise, clunking and drone with it I'd be a little pissed also, as the only real benefit is that i can track my car over 120 safely.
For a dd Imo the stock ds is just fine and unless I ever track it there is no reason to change it.
Sent from LG G3.
Old 09-16-2015, 07:41 PM   #20
Harm_3.7's Avatar
This.
Honestly this is true. You should of researched before buying the driveshaft if it's causing you an issue now...
IG: justaslow3.7
Harm_3.7 is offline   Reply With Quote
Old 09-16-2015, 07:57 PM   #21
Thank you, Kevin!
This is the point. I have been buying >90% of my Mustang parts from AmericanMuscle. I did returned a couple of them, but never had any issue. What I got from AmericanMuscle is quality customer service, no headache like what I experienced with CJPonyParts at all.
It seems that the representatives of AmericanMuscle are always going out of their way to help you out, but the representatives of CJPonyParts are behaving short-sighted and unprofessionally.
Old 09-16-2015, 10:24 PM   #22
tym_v6's Avatar
+1 on this.
I have a DSS aluminum shaft. I do get a bit more noise, probably because the shaft is basically a hollow metal tube perfect for transmitting and amplifying sounds. It's not bad, though, so I'm not too worried. The OP could consider putting some Dynamat under the rear seats and in the trunk area, which will cut down on road noise overall.
Old 09-17-2015, 03:58 AM   #23
ponie1992's Avatar
Try rotating the shaft 180°. This can fix a lot of issues.
Jeremy
2012 Black PP V6
Jeremy
2016 Ruby Red PP GT
ponie1992 is offline   Reply With Quote
Old 09-17-2015, 05:51 AM   #24
Realistically if you can't live with the sound, I'm sure you can sell it here for what you paid minus the cost of shipping it to the new owner.
Old 09-17-2015, 12:30 PM   #25
thelastsumurai's Avatar
If you have a drone when decelerating it's probably the rear end pinion bearing ( not defective). Ford steel DS does a good job of covering up some rear end noises, and amplifies others.. I don't think Ford did that intentionally but I've seen it in the shop a few times after a change over to alum DS. That's why I went with the CF drive shaft. We have also been successful at getting rid of harmonics by rotating Drive the shaft 90* at a time till vibration goes away. If it doesn't, its probably is out of balance or is bent beyond spec.
If a shop or dealer won't stand by their product don't use them anymore, and post it for the rest of us to see.
But make sure you do your best to solve problem yourself.
'16 Eco-Boost Premium, White, Performance Pkg, 6R80 (again), Pwr Ebony Lthr with Nether Region Cooling, Adaptive Cruise Control, Enhanced Security Pkg., Reverse Park Assist., Big Worm OTT Graphix.
2014 GT Premium 200A, Black on black , leather , 6R80, Nav, Security. Pro Cal, HT catback exhaust 12.54@112
thelastsumurai is offline   Reply With Quote
Old 09-17-2015, 01:06 PM   #26
Drone from a drive shaft ???????????? WOW !!!!!
This really has to go down in history as something to remember.
A Vibration===YES
A Clunk ===Yes
A Drone ==== I really don't think so unless you have a lot of air passing through the drive shaft.
I see you change rear differential gears at one time so thelastsumurai at post above may be on to your problem.
So bad that it gives you a migraine headache=== Ha! Ha! Ha! Ha! "Come -on"
Corsa exhaust may or may not be causing your "DRONE" It sure ain't caused by a drive shaft.
Old 09-17-2015, 01:07 PM   #27
audioAl's Avatar
Go to a Driveshaft Shop & have them diagnose the problem, they have a machine for testing.
2014 DIB 3.7 "Blue Cyclone" /Sold
2016 ruby red GT 300 A with 3.55:1 gear/SVE resonator delete X-pipe/ UPR catch can/Airaid/AEM/Steeda/ BMR CB005/BMR CB006 brace/BMR cc plates/SVE springs/
Old 09-17-2015, 01:26 PM   #28
As many of you super mechanics have probably experienced with customer complaints about differential noise. You will know that a pinion bearing can be described in many ways by different people, i.e. clank, clink, rumble, whine, thud, whirring and other things, it your job to figure out exactly what they mean. What I am saying is, don't make fun of others descriptions of a problem.
As audioAl said maybe it's time to go to a reputable drive shaft shop and have it diagnosed.
Old 09-17-2015, 02:19 PM   #29
Diehard's Avatar
Could be a First!
Or another alternate is record the sound and send it to ronnie. Just jesting.
Old 09-17-2015, 02:36 PM   #30
Panther140's Avatar
I tried ordering stuff from them.
it was all back-ordered.
They didn't mention this until a day after I ordered it.
I cancelled my order and went to the local auto parts store for my crap.
The parts came in (to the local store) the next day and shipping was free.
Shop Local. The smaller the business, the better.
The End.
Panther140 is offline   Reply With Quote
Old 09-17-2015, 02:57 PM   #31
Great advice
Old 09-18-2015, 05:03 AM   #32
bucko's Avatar
Let's try to stay on track with the replies to help the OP out.
Old 09-18-2015, 08:26 AM   #33
Diehard's Avatar
Power Train Set Up
I know there's a lot of instructional literature kicking around but I thought these by Inland Empire Driveline Service, Inc. were very good.
https://www.iedls.com/asp/admin/getF...&TID=28&FN=PDF
http://www.iedls.com/asp/admin/getFi...&TID=28&FN=PDF
Old 09-18-2015, 08:42 AM   #34
Site Sponsor
Hey OP - Sorry to hear about the trouble you had working with them but this is fairly common place from vendor to vendor. I would try to shoot them a call to work with them on how it was installed etc and what they would need to have this fixed for you.
Just my .02 !
Kevin - If the op had this purchased here we would need to have a shop report specifically stating what had occurred causing this to act up. Your pad was a different issue too and there's no way I was going to have you driving around with no brakes!
Alex
Toll Free: 1-866-363-4591
Free Same-Day Shipping!
Old 09-18-2015, 11:37 AM   #35
Waylap1's Avatar
Region: New Hampshire
You installed it and drove it...an inch or a mile, it don't matter. Would it have been just fine for you to order this $600 part from them and then get one that was already installed on someone else's Mustang and then returned? Yeah, I didn't think so.
Now here's something CJ really FAILS at. Order a shift knob that boldly states "Ships in 5-7 days". Order it, then see way down further in description "all shift knobs are custom made and ship in 3-4 WEEKS".
WTF CJ Pony parts?
Waylap1 is offline   Reply With Quote
4in cowl cjponyparts Tpost08 The Bar 7 11-22-2013 05:19 PM
CjPonyParts OG86GT 1979-1995 Mustang GT 2 03-21-2012 04:33 PM
Welcome CJPonyParts to Mustang Evolution Brent ME Site Help & Announcements 47 01-25-2011 07:23 PM
My experiences with Sideways AutoSalon of Austin Texas drakino General Mustang Discussion 6 03-03-2008 10:39 AM
no longer ordering from cjponyparts Bane- The Bar 2 01-04-2006 02:07 PM
04:00 PM
