Interior Upgrades - Mustang Evolution
Old 09-20-2015, 10:09 PM   #1
Cameron2581's Avatar
Interior Upgrades
After spending a while looking for a way to inexpensively upgrade my interior, I was disappointed in finding lost of the dash kits were cheaply made and in my opinion, not worth buying. So I gave up until I finally got the idea to paint all the hard plastic pieces. I have a 2012 White Convertible and found the factory performance white and went to it. Honest Opinions? Attachment 191377
Also id love to see what y'all guys have done to the interior for some more ideas.
Cameron2581 is offline   Reply With Quote
Old 09-20-2015, 10:18 PM   #2
Cooolbreeez's Avatar
Looks cool, get some close ups. Anything can look good painted from far away.
Cooolbreeez is offline   Reply With Quote
Old 09-20-2015, 10:53 PM   #3
Mean14's Avatar
+1 I think it looks pretty sweet. Some closeups would help
Procharged D1 on 12Lbs, MPT 93 Tune, 73mm BBK TB, Ported Upper/Lower Intakes, BBK Shorty Headers, FRPP Cut n Clamp Xpipe, Borla S-Types, Barton Short Shifter/Blowfish Bracket, SS Clutch Line, Whiteline Trans Bushing, One Piece Driveshaft, Front and Rear Tower Brace, Whiteline Front and Rear Sway Bars, Whiteline Adj LCAs/Adj UCA, BMR Relocation Brackets, BMR adj Panhard Bar, Eibach Sportlines, FRPP Dampers, 20" AMRs, 3.55 gears, Brembos
Mean14 is offline   Reply With Quote
Old 09-21-2015, 06:45 AM   #4
Name:	ImageUploadedByMustang Evolution1442839404.960169.jpg
ID:	191385Click image for larger version
Name:	ImageUploadedByMustang Evolution1442839443.362106.jpg
ID:	191386Click image for larger version
Name:	ImageUploadedByMustang Evolution1442839485.862449.jpg
ID:	191387Click image for larger version
Name:	ImageUploadedByMustang Evolution1442839503.366311.jpg
Whatcha think guys?
Old 09-21-2015, 06:50 AM   #5
ragtopman's Avatar
Very nice! Great idea!
ragtopman is offline   Reply With Quote
Old 09-21-2015, 06:56 AM   #6
Rapinator126's Avatar
I like it.
🍼and 🌽 fed coyote.
Old 09-21-2015, 06:57 AM   #7
JohnnyBob's Avatar
Looks great! My only opinion is that those doors will look plain with just the bezel and the partial arm rest painted. Maybe get the "leather" panel stitched with white as well? Not sure
JohnnyBob is offline   Reply With Quote
Old 09-21-2015, 07:05 AM   #8
I agree with you. I might pull out the plastic around the handles and I am doing the area around the lock pins so maybe it won't be so plain but I feel like it would be too much to do the whole door like you're saying
Old 09-21-2015, 08:29 AM   #9
Sterlingbeast5.0's Avatar
Looks good. did you do it yourself? What kind of expense was it? Been contemplating a mix on mine of Sterling Grey and Carbon Fiber Hydro Dip
Old 09-21-2015, 09:21 AM   #10
I did. After buying all he materials it was around $50 and took a day of work but it was fun to take it apart and all. I love it
Old 09-21-2015, 09:46 AM   #11
Dang thats not bad at all! Ling up where you got paint ordered or let me know if you would. Did you spray it with spray cans? Also, if you can give little insite to how you got off the passanger airbag section without issue I would apreciate
Old 09-21-2015, 10:17 AM   #12
Ok so I got all my paint at auto zone. They have Duplicolor Perfect match paint and it is spray. They have all the ford factory colors. So I got paint the clear Duplicolor primer and then the Duplicolor clear lacquer You will also need 1500 and 2000 grit sandpaper. So you wet sand all the parts you are painting with the 1500 and then wipe down with rubbing alcohol. You then do 3 coats of primer with 3 minutes between coats. Then 4 coats of paint with 10 minutes between coats and then 2 coats of lacquer with 5 minutes between coats and let it dry for an hour. Then after that you wet sand it with 2000 and then use polishing compound Click image for larger version
Name:	ImageUploadedByMustang Evolution1442852001.275030.jpg
After that it's ready to go back in.
As to getting the airbag out, it is by far the hardest part to remove because everything else is extremely easy. First you take off the glove box by removing the 4 screws underneath the glove box. Second you will look up under the dash directly behind the panel and will see a black box. There are 4 outer screw that you remove and the box should drop down. Then you will see the bracket the box was on and it has 2 screw to remove. Once they are removed you should be able o use a flathead and unclip the panel and push the panel out from underneath with the airbag attached. I just set the airbag down into a box leaving the panel above it and then painted and put it back in. Not too hard if you know what to look for. Hope this helps
Old 09-21-2015, 12:42 PM   #13
Looks great! Sounds like you put some work into it and did it right.
Old 09-21-2015, 01:01 PM   #14
Rosariors3's Avatar
Looks nice.. I think u should continue with the white on ur seats. Not the whole thing though just the middle where u sit and the back. Same with the back seats that would look real sharp.
I might not know as much as you but i know how to drive better than you!!!
Rosariors3 is offline   Reply With Quote
Old 09-21-2015, 01:21 PM   #15
I completely agree. Just gotta save up
Old 09-21-2015, 03:36 PM   #16
Great Job!
I'm dying the inside of the Cobra right now. making some leather repairs too. I'll take pics when completely completed.
Old 09-21-2015, 05:04 PM   #17
Please do
Old 09-21-2015, 05:43 PM   #18
rmb427r's Avatar
I'm with everyone else. Great job! Let us know how it holds up.
Ron..
2008 Roush 427R
2014 V6 Prem
rmb427r is offline   Reply With Quote
Old 09-21-2015, 09:39 PM   #19
I'll be honest - I expected to be quite underwhelmed when I clicked on the picture. Instead I was EXTREMELY impressed. Nice job!!
2014 V6 manual
Charlotte Stang is offline   Reply With Quote
Old 09-22-2015, 10:27 AM   #20
AngryTech's Avatar
Agreed!
It's the right amount of white to compliment the black dash. Great Job OP!!
AngryTech is offline   Reply With Quote
Old 09-22-2015, 05:39 PM   #21
rringler's Avatar
Looks great!
rringler is offline   Reply With Quote
Old 09-22-2015, 06:19 PM   #22
dquigney is offline   Reply With Quote
Old 09-22-2015, 06:21 PM   #23
I think it's just the right amount of white. It looks great!
Old 10-02-2015, 03:50 PM   #24
So the paint has held up PERFECTLY so far. Very happy with it and now I'm ready to do something else. Anyone have any suggestions?
Old 10-04-2015, 07:35 PM   #25
alucard3600's Avatar
That looks AWESOME bro! I may do that for mine, just in Oxford white, I am also going to put on leather seat covers Ford Mustang PACKAGE - Ford PACKAGES - Pre-Selected PACKAGES I think it all will come together nicely!
2014 3.7l Auto Oxford White
Mods: Cervini Stalker Hood, Roush highflow upper and lower grill, AirRaid CAI, LMR strut tower brace,Mac LT headers,Mac Prochamber, Kooks Highflow Cats,Dynomax Race Bullets (resonators), 2.5 o/a pipes, 2011 Gt500 Axlebacks, MPT 93 performance tune.
alucard3600 is offline   Reply With Quote
Old 10-04-2015, 07:37 PM   #26
I actually did the same technique on my mirror covers and they look great. So I saved $200 by just doing it my self
Old 10-04-2015, 07:53 PM   #27
I am trying to decide on whether I should wait until I get a touchscreen nav and do it then or just do it soon, and then just paint the doubledin mount
when I get the radio.
Old 10-04-2015, 08:37 PM   #28
It's really not too bad and it was pretty fun to take a day and just fool around with the car and it really does change the look and make it stand out
Old 10-06-2015, 09:48 AM   #29
It looks very nice!! I want to do the same but in Grabber Blue.
How much paint have you used for this project?
AirAidCIA | BAMA 87P Tune | BoralAtak AB| BMRAdj UCA | BMR UCA Mnt | BMRAdj PHB | GCCoilOvers | DSS 1 Piece AL Driveshaft | BMRLCA | BMR LCA Reloc Brackets | BARTONShifter | GT CS Spoiler| RedLine Hood struts | MMD Axim 20X8.5 Audio: Dynamatted Rear & Doors | AudioControl LC8i | Speakers: Infinity 682.9cf | RockFord Prime R250X4 Amp | Rockford Prime 500.1 Mono AMP | Kicker Twin10" L5 Solo Barics in a Ported BOX |P.S MORE TO COMEEEEE!!!!
Firstang001 is offline   Reply With Quote
Old 10-06-2015, 09:49 AM   #30
Everything took me about 4 cans of the paint and then just one can of primer and lacquer
Old 10-07-2015, 02:09 PM   #31
Looks great - very nice paintjob. I thought the vinyl wraps were the only viable option, but now you've got me looking into paint schemes.
VeryVeryEvilGuy is offline   Reply With Quote
Old 10-08-2015, 08:44 AM   #32
Thanks Cameron!!
Exterior upgrades and maybe performance upgrades RedToplessPony 2011-2014 V6 Mustang 34 12-26-2011 04:09 PM
Interior upgrades? Rocco4.6 1996-2004 Mustang GT 10 10-03-2011 12:00 PM
Interior upgrades ! Dj77 1996-2004 Mustang GT 3 04-19-2011 02:18 PM
1995 mustang v6 interior upgrades? Pascullon Pre-2005 V6 Mustang 7 02-08-2011 08:27 AM
Small interior upgrades The Arson Mustang Audio & Video 9 09-18-2004 07:53 AM
09:04 AM
