Suspension problem - Mustang Evolution
Old 09-25-2015, 05:32 PM   #1
mckhammer's Avatar
Suspension problem
When I am cruising on the road and when I get a patch or bump on the road I hear on the back left side of the car a sound. It sounds like a clunking/squeaking sound. My car only has 24,000 miles. Has far as I know it still has the factory suspension.
Sent from my XT1080 using Mustang Evolution mobile app
2012 pp, 20% tint all around, caliper covers, Roush ab, ford racing 3.55's, MPT tuned, Steeda cai, boss 302 strut tower brace, 1 piece aluminum Axle Exchange DS
mckhammer is offline   Reply With Quote
Old 09-25-2015, 06:24 PM   #2
tym_v6's Avatar
Not much for us to go on, but could be the rear stabilizer end links. The crappy OEM rubber bushings can groan and creak over bumps. There should be a TSB and stealership should fix under warranty.
Old 09-25-2015, 06:56 PM   #3
Mean14's Avatar
I had the same problem. Changed out the sway bar links and still didn't solve it. Ended up changing the rear shocks and it was eliminated. Weird cause it would only squeak when it was below 60degrees.
Procharged D1 on 12Lbs, MPT 93 Tune, 73mm BBK TB, Ported Upper/Lower Intakes, BBK Shorty Headers, FRPP Cut n Clamp Xpipe, Borla S-Types, Barton Short Shifter/Blowfish Bracket, SS Clutch Line, Whiteline Trans Bushing, One Piece Driveshaft, Front and Rear Tower Brace, Whiteline Front and Rear Sway Bars, Whiteline Adj LCAs/Adj UCA, BMR Relocation Brackets, BMR adj Panhard Bar, Eibach Sportlines, FRPP Dampers, 20" AMRs, 3.55 gears, Brembos
Mean14 is offline   Reply With Quote
Old 09-25-2015, 07:19 PM   #4
Kevin.Cook
Guest
Posts: n/a
Clunking can sometimes be a sign of worn out shocks or struts. Sometimes they go out quicker then they are supposed to.
Old 09-25-2015, 08:12 PM   #5
Diehard's Avatar
In my past experience I found that when I went to places like NTB, Firestone or Meineke for specials on oil change, they would check out the car for problems, while it was on the lift. They often found worn and/or loose joints, leaky shocks, etc and I would thank them and fix the problems myself.
I'm sure a place like that would be glad to look for the problem while servicing the car, at no additional cost.
Just a possible no-cost option to consider if out of warranty.
Bottom line...you should get it looked at by a professional or at least a semi-professional.
Old 09-25-2015, 10:39 PM   #6
mckhammer's Avatar
I'm thinking it may be the bushings. I'll look into having a professional examine it next week to see what it could be.
Old 09-26-2015, 10:05 AM   #7
Odai1437's Avatar
I had the same problem but on the front right side and it turned out to be the control arms
Instagram: Odaii_7
Odai1437 is offline   Reply With Quote
Soften up suspension: for those post suspension mods Jvibe92 2011-2014 Mustang GT 14 03-03-2015 02:05 PM
Suspension problem JayStang718 1996-2004 Mustang GT 9 01-18-2014 11:15 AM
Suspension problem Whitelightning 2011-2014 V6 Mustang 13 08-12-2013 07:08 PM
will trade fairings and lowered suspension for stock suspension vincent1 1996-2004 Mustang GT 2 06-22-2009 07:34 AM
07:18 AM
