Unconnected Vacuum Line - ??? - Mustang Evolution
Old 09-25-2015, 07:57 PM   #1
Diehard's Avatar
After having my mustang for about 15 months now I just today discovered a hose hanging down low near the steering column.(I lifted it up and laid it on the hose going to the brake booster) As soon as I discovered the hose I spotted that PVC tee type connection with an open connection. So I say to myself...WTF? (1st picture)
The other end of the hose was connected to the air intake tube, close to filter box.(2nd picture)
I started engine and put my finger on the tee connection and sure enough it was pulling a small vacuum.
I had the oil changed by the dealer a few months ago and they obviously didn't notice it.
Also, I noticed that this hose lacked a clamp similar to what the others have. Could it have been left off from the factory?
(I did do the headers myself, in the 1st month I had the car, but I'm pretty sure I never touched that hose.)
But moving forward, what exactly is that small amount of vacuum suppose to do? I'm assuming the hose to the brake booster has a high vacuum.??
How would that affect my air intake?
Old 09-25-2015, 08:37 PM   #2
Originally Posted by diehard View Post
after having my mustang for about 15 months now i just today discovered a hose hanging down low near the steering column.(i lifted it up and laid it on the hose going to the brake booster) as soon as i discovered the hose i spotted that pvc tee type connection with an open connection. So i say to myself...wtf? (1st picture)
Attachment 191526
the other end of the hose was connected to the air intake tube, close to filter box.(2nd picture)
Attachment 191527
i started engine and put my finger on the tee connection and sure enough it was pulling a small vacuum.
Also, i noticed that this hose lacked a clamp similar to what the others have. Could it have been left off from the factory?
(i did do the headers myself, in the 1st month i had the car, but i'm pretty sure i never touched that hose.)
but moving forward, what exactly is that small amount of vacuum suppose to do? I'm assuming the hose to the brake booster has a high vacuum.??
crank case vent? Pcv pulls air through engine from filter
ALLYDRIVER1 is offline   Reply With Quote
Old 09-25-2015, 08:44 PM   #3
Diehard's Avatar
Well now that I reconnected it, I will pay attention to any subtle changes, if any.
Old 09-25-2015, 10:57 PM   #4
I think that hose is used to bleed off excess vacuum to the brake booster. It is drawing metered air from the intake tube. Probably, if you step on the brake, the vacuum from that tee will diminish, or disappear altogether.
That's my theory anyways...
You've actually discovered two separate un-metered air vacuum leaks. One at the intake tube, and one at that tee. You might notice a small difference in the way that the engine runs. If you don't have a tune, you might want to do a idle relearn procedure to speed up the computers process of relearning the air and fuel trims.
Old 09-25-2015, 11:06 PM   #5
tym_v6's Avatar
And while you're at it, you might want to spring for some small stainless screw (band) hose clamps to replace the one that's missing.
Vacuum line trouble 67mustang97 1996-2004 Mustang GT 4 04-26-2013 06:26 AM
vacuum line diagram for gt40 intake FLAT BLACK GT 1979-1995 Mustang GT 0 11-22-2012 02:26 PM
sea foam + vacuum line joey18 Pre-2005 V6 Mustang 7 07-21-2012 11:28 PM
1999 Mustang 3.8L vacuum line connection help dscott4410 Pre-2005 V6 Mustang 3 06-19-2012 08:13 AM
Sea Foam in vacuum line? afree05 2005-2010 V6 Mustang 1 12-12-2011 12:23 AM
04:54 PM
