2013 V6 problems - Mustang Evolution
Old 09-27-2015, 10:27 AM   #1
2013 V6 problems
I have some concerns with my 13 V6 performance package. Car has 37,000 miles
1. Soft brake pedal? Seems that the brake pedal has to be pushed in really far before it actually stops. My moms acura has 130k miles and the brake pedal is very sensitive
2. Installed ford racing axelbacks about 1000 miles ago and smell a strong sulfer smell only when revving high/ accelerating hard
3. Steering wheel has some play going at higher speeds when accelerating hard
Are these signs normal?
racemamxx is offline   Reply With Quote
Old 09-27-2015, 10:34 AM   #2
Voltwings's Avatar
1. 40k is normal for brakes needing to be bled.
2. check for leaks.
3. going to need more detail. The mustang has electronic assisted power steering, so its a touch vague to begin with, but what exactly is yours doing?
Voltwings is online now   Reply With Quote
Old 09-27-2015, 10:39 AM   #3
2. check for leaks.
Basically if I step on it and fly up the road and I change lanes the steering gets very loose and sesnsitive. Doesnt feel precise
Old 09-27-2015, 10:48 AM   #4
Voltwings's Avatar
Thats called stock suspension and crappy tires.
Old 09-27-2015, 10:55 AM   #5
I have the goodyear eagle f1 tires. 19 inch rims the radial like 255 40R 19. What tires should I get?
Old 09-27-2015, 11:00 AM   #6
Voltwings's Avatar
Just depends on what kind of driving you plan on doing, how long you want them to last, how much money you plan on spending... There's too many variables for me to answer that question for you.
Old 09-27-2015, 11:35 AM   #7
Region: Nevada
I've heard the sulfer smell is from the cats. Most likely getting hot when you're accelerating hard.
Jenkins is offline   Reply With Quote
Old 09-27-2015, 02:03 PM   #8
TrevorMCA's Avatar
I have the same Axlebacks and get the same smell. Also my steering rattles when hit about 80
2012 MCA 3.7
Trevor
TrevorMCA is offline   Reply With Quote
Old 09-27-2015, 02:51 PM   #9
jek57's Avatar
My 2012 does the same thing when i step on it at highway speeds also on my 09 v6 seem to do the same thing ..It almost feels like the front end raises up a bit when you step on it not sure if it is but thats what it feels like.
jek57 is offline   Reply With Quote
Old 09-27-2015, 03:02 PM   #10
Abominable Mustang
WhoDat's Avatar
Region: Alaska
1. Brakes may need to be bled or the pads may be at the point of needing to be replaced.
2. The reason for the steering feel is basic physics. Hard acceleration is shifting a lot of weight to the rear wheels, taking weighing off the front/steering wheels.
3. Under acceleration, it's normal to smell that. I believe it's the cats heating up. I stopped smelling it after I got an off-road midpipe.
Sent from the Death Star.
2012 Kona Blue 3.7L V6:
Old 09-27-2015, 08:15 PM   #11
TrevorMCA's Avatar
What exhaust setup do you have? Did the midpipe make a big difference?
2012 Kona Blue MCA 3.7
Ford Racing Axelbacks
Airaid CAI
Old 09-27-2015, 08:33 PM   #12
NewMtang's Avatar
Checked your tire pressure lately?
Old 09-27-2015, 08:57 PM   #13
RaceRed3.7's Avatar
2012 MCA 3.7
Trevor
Could be unbalanced tires or out of alignment. Or missmatched tires(Brands, sizes, etc.)
-SOLD-13.246s@107.81 RaceRed 2013 v6 Mustang, 3.73 gears, MPT 91Race Tune, Axle-Back Straight Pipe, Tower Brace, BMR LCA's, BBK Shorty Headers, BMR Relocation Brackets, Lethal Performance X-Pipe Catless.
-2008 Civic SI...
RaceRed3.7 is offline   Reply With Quote
Old 09-27-2015, 10:21 PM   #14
2012 MCA 3.7
Trevor
Do you find that the ford racing axelbacks are a little quiet? I am wanting them to be a little louder
Old 09-28-2015, 02:37 PM   #15
TrevorMCA's Avatar
Well when I first got my car I thought it was awesome because I had never heard a v6 sound so good. I think I've gotten used to them but in the winter they sound better. I've heard the roush are really loud but some don't like the way they sound. It's hard to find a good set up with a sixxer.
Airaid CAI
Old 09-28-2015, 06:50 PM   #16
Airaid CAI
I think a catted x pipe would make them louder. Havent heard them in the winter yet. What makes them sound different in the winter? They get louder?
Old 09-29-2015, 11:54 AM   #17
Hawkstang's Avatar
Region: Iowa
Have the brakes bled and they will add new fluid. Don't pay over $100 for this though, call around. Sears auto is a nice cheap place for EASY fixes. Don't take it there for anything other than fluids though.
Axel backs take awhile to break-in, mine smelled like that for a good 600 miles but you need to get into some high rpms to get it to burn off quicker.
Did you go into your settings and see what the steering is set at? Try the other two settings and see if it helps.
Hawkstang is offline   Reply With Quote
Old 09-29-2015, 12:04 PM   #18
Hawkstang's Avatar
Region: Iowa
I have a performance package and I test drove a normal package Stang that handled like the OP is saying. My PP does not what he is saying so I don't think it's his stock suspension (unless something broke). Could be the steering feel setting or crap tires.
Lower control arm problems on 2013 mustang gt. silvercoyote 2011-2014 Mustang GT 4 08-28-2015 06:01 AM
2013 5.0 3rd Gear problems? Shadow27 2011-2014 Mustang GT 18 05-24-2013 01:30 PM
Problems and more problems BigB227 1996-2004 Mustang GT 1 08-22-2012 09:12 AM
Ford Electronics/Programming Expert? Swapping 2013 Premium Cluster to 2013 Base doofoo 2011-2014 Mustang GT 2 07-16-2012 04:29 PM
06:07 AM
