Rear end noise - Mustang Evolution
Old 09-29-2015, 08:45 PM   #1
Gumbus's Avatar
Rear end noise
Every time I make a left or right turn, the rear end makes this creaking noise and it has me concerned. I'm lowered on springs and have a panhard bar but that's it as far as suspension goes. Thoughts?
2013 mustang v6 premium
Gumbus is offline   Reply With Quote
Old 09-30-2015, 09:56 AM   #2
Mean14's Avatar
Make sure your panhard bar is torqued down to the proper specs to 129ft lbs.
Procharged D1 on 12Lbs, MPT 93 Tune, 73mm BBK TB, Ported Upper/Lower Intakes, BBK Shorty Headers, FRPP Cut n Clamp Xpipe, Borla S-Types, Barton Short Shifter/Blowfish Bracket, SS Clutch Line, Whiteline Trans Bushing, One Piece Driveshaft, Front and Rear Tower Brace, Whiteline Front and Rear Sway Bars, Whiteline Adj LCAs/Adj UCA, BMR Relocation Brackets, BMR adj Panhard Bar, Eibach Sportlines, FRPP Dampers, 20" AMRs, 3.55 gears, Brembos
Mean14 is offline   Reply With Quote
Old 09-30-2015, 10:17 AM   #3
tym_v6's Avatar
Also, if you have poly bushings (I assume you do with the aftermarket PHB), they can make annoying noise if not properly lubed.
Old 09-30-2015, 10:25 AM   #4
Gumbus's Avatar
Okay, I just don't want it to be something serious
How long is a mustang rear end compared to a ranger rear end. lenth meaning from tire to tire? macray33 General Mustang Discussion 1 03-14-2010 03:43 AM
Is a 1995 Mustang V6 rear end different from a 1995 Mustang V8 rear end? celyddon Pre-2005 V6 Mustang 2 08-25-2009 06:56 PM
Rear end noise??? woodly1069 Pre-2005 V6 Mustang 2 04-30-2008 07:56 AM
Rear end noise bsmith782 1996-2004 Mustang GT 31 08-23-2006 08:46 AM
rear end noise + PS favor jimmy_beaner The Bar 10 06-21-2005 12:00 AM
10:06 AM
