Advice on best 1/4 - Mustang Evolution
Old 10-02-2015, 01:09 PM   #1
mckhammer's Avatar
Advice on best 1/4
I am looking for some advice on getting my quarter mile times down using the best technique. I have a manual v6 and still consistently at 14 flat. My mods are steeda cai, mpt tune, Aluminum one piece, and the 3.55 gears
Sent from my XT1080 using Mustang Evolution mobile app
2012 pp, 20% tint all around, caliper covers, Roush ab, ford racing 3.55's, MPT tuned, Steeda cai, boss 302 strut tower brace, 1 piece aluminum Axle Exchange DS
mckhammer is offline   Reply With Quote
Old 10-02-2015, 01:25 PM   #2
Voltwings's Avatar
Whats your trap speed
Whats your 60'
Where are you shifting
Have you checked the DA on the days you're running?
Old 10-02-2015, 01:45 PM   #3
Mean14's Avatar
Lower control arms and a good set of tires
Procharged D1 on 12Lbs, MPT 93 Tune, 73mm BBK TB, Ported Upper/Lower Intakes, BBK Shorty Headers, FRPP Cut n Clamp Xpipe, Borla S-Types, Barton Short Shifter/Blowfish Bracket, SS Clutch Line, Whiteline Trans Bushing, One Piece Driveshaft, Front and Rear Tower Brace, Whiteline Front and Rear Sway Bars, Whiteline Adj LCAs/Adj UCA, BMR Relocation Brackets, BMR adj Panhard Bar, Eibach Sportlines, FRPP Dampers, 20" AMRs, 3.55 gears, Brembos
Mean14 is offline   Reply With Quote
Old 10-02-2015, 01:52 PM   #4
Diehard's Avatar
Here's some stuff to read on the subject...
http://www.hardtail.com/techtips/analizingtimeslip.html
EDIT: Actually this is for Bracket racing. It really doesn't entirely apply.
Old 10-02-2015, 02:03 PM   #5
Voltwings's Avatar
Good link, nice stuff in there.
Old 10-02-2015, 02:06 PM   #6
Diehard's Avatar
Well it's good for me who's trying to learn all this stuff. LOL
Not exactly what the op needs but gets him thinking.
Old 10-02-2015, 02:09 PM   #7
Voltwings's Avatar
Hence, all the questions i asked lol, that link explains why i asked them.
Old 10-02-2015, 02:10 PM   #8
mckhammer's Avatar
Interesting to read. Did not know you get better traction when the sun goes down.
Old 10-02-2015, 02:12 PM   #9
mckhammer's Avatar
But does anyone have a recommendation for what rpms I should launch at with my 235 perllis?
Old 10-02-2015, 02:13 PM   #10
Diehard's Avatar
Yeah my thoughts as well.
Old 10-02-2015, 02:23 PM   #11
smurf stang's Avatar
Whats your 60'
OP start by answering these questions to see where you are deficient.
2016 VW GTI 2.0 Turbo
Old 10-02-2015, 02:24 PM   #12
Voltwings's Avatar
Whats your 60'
^^ Start there. Honestly, on 235 street tires on stock suspension you shouldnt be "launching" at all. I'd typically stage around 1500-2000 rpms, then slip the clutch for a second with about half throttle, then release the clutch completely and floor it. Was typically cutting around 2.0 60', which isnt great for street tires, but isnt terrible either.
Old 10-02-2015, 02:30 PM   #13
mckhammer's Avatar
Whats your 60'
Trap speed is right around 95-100 with my 60' being 2.3-2.6. I do not know what DA stands for but the temperature has been 70 degres or below with the humidity being 60-70 percent
Old 10-02-2015, 02:32 PM   #14
It is a delicate balance between ever so slightly slipping the clutch to get a good launch with street tires.
You should be able to crack a 2.0 60' time which should net you at least a 13 second time slip. The rest will depend on suspension and tires and finally practice.
Old 10-02-2015, 02:37 PM   #15
Voltwings's Avatar
Im not a very avid drag racer, but whats the general rule of thumb? .1 in the 60' is about .2 off the ET? Taking his 2.5 ish 60' down to about 2.0 works out to about a 13 second slip give or take. Sounds like its all in the launch, which is murdering your trap speed as well, i'd expect your car to be trapping at least 105
And DA is density altitude. Basically factors in things like height above sea level, the heat and humidity in the air ... a 9 second car at sea level may struggle to run mid 10s at 6000 feet you know. Obviously i pulled that example out of my ***, but you get the idea.
Old 10-02-2015, 04:07 PM   #16
mckhammer's Avatar
My elevation is 700 ft above sea level approx. If anyone is familiar with summit raceway, that is where I am
Old 10-02-2015, 04:08 PM   #17
mckhammer's Avatar
I'll be trying that tactic tonight. I'll let you know how it goes
Old 10-02-2015, 04:17 PM   #18
mckhammer's Avatar
What am I doing wrong??? I launched this time at idle.
Old 10-02-2015, 04:56 PM   #19
Ish416's Avatar
My car has the 2.73's with a manual and I managed a 1.96 60' and ran a 13.6 @ 105.2 on the stock Pirellis.
I ran 35 PSI in all my tires (normal street driving), removed my spare tire and other junk. Completely disabled Advancetrak and traction control, that was it.
I launched my car around 3800 rpm, slipping the clutch nearly the entire way, no-lift shifted each gear and ended up with a time and trap that was very close to some of the Coyote drivers that were there.
It's all about skill and experience.
A launch is all about keeping wheel spin to a minimum and not letting the engine bog. The first 60' are really the most important. After that, just bang those gears and make a clean pass.
I would also think your car should be trapping a bit higher. What gear and RPM are you in when you go through the last trap?
Old 10-02-2015, 07:07 PM   #20
Voltwings's Avatar
Or just to add, what rpm are you shifting at in each gear? WIth your mods you're leaving an easy 5-7 mph on the table.
Old 10-02-2015, 08:51 PM   #21
Ish416's Avatar
I shifted around 7300 to 7500.
Old 10-02-2015, 11:17 PM   #22
Harm_3.7's Avatar
Uh isn't that way past red line lol
IG: justaslow3.7
Harm_3.7 is offline   Reply With Quote
Old 10-02-2015, 11:23 PM   #23
Ish416's Avatar
IG: justaslow3.7
Slightly.
Old 10-02-2015, 11:38 PM   #24
Harm_3.7's Avatar
Slightly.
I believe you shouldn't be shifting that high up. Someone else will chip into this thread soon but I believe that is way to late for shifts.
IG: justaslow3.7
Old 10-03-2015, 07:49 AM   #25
IG: justaslow3.7
Doesn't hurt anything but without long tubes and ported IMs definitely well into where the power starts to fall off. Shifting 71-7200 might yield better results.
2013 SGM 3.7 | MPT Tune | JBA Shorty Headers | MGW Gen 1 | Blowfish Street Bracket | 18" Charcoal AMR | FRPP 3.55 | BMR LCA | Steeda Panhard Bar | Dynotech 3.5" Driveshaft |
mariusvt is offline   Reply With Quote
Old 10-03-2015, 11:47 PM   #26
Harm_3.7's Avatar
Advice on best 1/4
Shifting that far up in the RPMs won't cause any damage?
IG: justaslow3.7
Old 10-03-2015, 11:55 PM   #27
natestang07's Avatar
I get this inkling that he knows what he is doing lol
Old 10-04-2015, 08:23 AM   #28
mckhammer's Avatar
I am shifting between 6400-6800. On my gauges I have a shift light so its mostly spot on every time. When I get to the end of the track I'm in 4th at about 5800 rpm
Need advice for the best way to take care of.. AZ Trey Mustang Paint, Appearance & Detailing 1 05-08-2014 03:40 PM
Best advice to buying a USED 2005-2009 FORD MUSTANG -- ANY FORD EMPLOYEE'S?--? pierre General Mustang Discussion 5 03-14-2010 01:58 AM
Dating Advice From The Best of Coaches Brent The Bar 4 09-24-2008 07:29 AM
May's Best Picture! Post the best pic of your car and win! SpectorV Pictures and Videos 35 06-06-2006 01:34 PM
desire advice... stock investment type advice... dark The Bar 4 04-23-2006 06:07 PM
02:37 AM
