Rear Axle!! Help - Mustang Evolution
Old 10-09-2015, 10:40 AM   #1
5pointYoBro's Avatar
Rear Axle!! Help
So I've run into problem after problem with my rear end.
Whine/noise when accel/decel.
Bad carrier bearing is what I originally thought.
But after replacing all the bearings and even a new set of gears, it still whines like a b****. Even tried a different brand of gears after the 2nd set of ford racing weren't right and made a clicking noise.
At this point i'm pretty sure its something to do with the housing.
The first time he did the gear change, I didnt have any whine for the first couple months. Then just one carrier bearing went bad on the drivers side, which I believe is where the noise started.
I drove on the bad bearing for quite some time, Could this have damaged my housing or anything else in the rear end?
Before I go ahead and buy a used axel to replace the old one, any thoughtss??
2014 GT. Oxford White.
20" Velgen VMB5s on NT555s.
MBRP Race Series Catback Exhaust
Bama 93 Performance Tune
5pointYoBro is offline   Reply With Quote
Old 10-09-2015, 11:11 AM   #2
shunc01's Avatar
Sorry man, how bad was the whine? It happened to me too they have to replaced the pinion seal twice and bearings. It's all fixed now but now I have a slight noise in the rear but not too bad. I hope it stays that way.
MPT tune, Axle exchange Aluminum driveshaft, 3:73 gears, borla stype, frrp x pipe, Mac ceramic shorty headers, airaid cai, Jlt separator, koni orange shocks and struts, SR Springs, gt500 mounts, J&M Panhard bar, Bmr LCA, 2010 gt500 wheels, roush chin splitter, roush louvers, and RTR stripes... 😎 🚘
2016 GT RACE RED MANUAL aka " RAGING BULL"
Mods:
Borla stypes cat back exhaust, tint kit all lights, 5.0 race red shift knob, MMD V SERIES SPOILER... and more to come...
shunc01 is offline   Reply With Quote
Old 10-09-2015, 11:14 AM   #3
It's pretty bad.. I hate to say.
Im just sick of dumping money into it, I already could have bought this 40k 3.31 rear end (axel/everything) for what i've spent on parts and labor so far
There is also a vibration you can feel when you decelerate from 70-65mph. Like you can hear the gears grinding or hitting something.
And i'm sure its the rear end, not transmission or driveshaft.
Old 10-09-2015, 11:22 AM   #4
Sterlingbeast5.0's Avatar
I had the same wine but no vibration. I will say though that for what it is worth I was told that the aluminum driveshaft transmits more noise so how long have you had the shaft comparatively.
Old 10-09-2015, 11:25 AM   #5
If you rode in the car, I don't think you would say that the noise is coming from the driveshaft, I could be wrong but...
I've had the driveshaft since like 40-45k and she's got 75k now.
Driveshaft was my second mod
Old 10-09-2015, 11:36 AM   #6
shunc01's Avatar
Ouchhhh... You can hear it grinding? That's no good, it might be the gears are gone now too. I think you had a bad install and the shop should stand behind there work, my shop fixed all my problem with NO additional cost even covered the parts that needs replacing. I would go back there and have them replaced it, or get a new set of gears from there pocket and have some shop install it a reputable one.
Mods:
Old 10-09-2015, 11:37 AM   #7
Mean14's Avatar
If the backlash is not set properly, it can cause serious whine
Procharged D1 on 12Lbs, MPT 93 Tune, 73mm BBK TB, Ported Upper/Lower Intakes, BBK Shorty Headers, FRPP Cut n Clamp Xpipe, Borla S-Types, Barton Short Shifter/Blowfish Bracket, SS Clutch Line, Whiteline Trans Bushing, One Piece Driveshaft, Front and Rear Tower Brace, Whiteline Front and Rear Sway Bars, Whiteline Adj LCAs/Adj UCA, BMR Relocation Brackets, BMR adj Panhard Bar, Eibach Sportlines, FRPP Dampers, 20" AMRs, 3.55 gears, Brembos
Mean14 is offline   Reply With Quote
Old 10-09-2015, 11:38 AM   #8
shunc01's Avatar
Does it sound like a jet fighter but in a really faint sound, it sounds like an electric car when decelerating. Cos this is mine sounds like but it's very faint... Plus I have the aluminum ds.
Mods:
Old 10-09-2015, 11:41 AM   #9
That's exactly what he already did. Swapped from Ford racing to a new set of Ford Racing(that made a clicking noise on decel), then put a set of richmonds in it and its still makes noise.
The first time he installed I had no problems. Didn't whine until like 6 months later
---------- Post added at 12:41 PM ---------- Previous post was at 12:40 PM ----------
Nahh like full blown jet fighter. p51 status lol
Old 10-09-2015, 12:05 PM   #10
shunc01's Avatar
That's not good, I feel your pain but I thought mine is bad.. Do you have the leak when it happened? Specially where the vent plug is?
Mods:
Old 10-09-2015, 12:08 PM   #11
It leaks as we speak. from the pinion seal. I have a catch can for the vent plug, so its not that.
I've just run into problem after problem, and at this point feel like buying a used rear axle with factory 3.31 is the way to go. AND NOT CHANGE IT. lol
I've got a small fund that i've saved for emergencies like this.
Old 10-09-2015, 12:21 PM   #12
shunc01's Avatar
This is crazy, can you look for another shop and ask for second opinion? Sometimes when this things happened I think it'd better off to leave it as it is and not mod it but wheres the thrill factor which we all look for. I wish you luck man hope you'll straightened it out. Speaking of the the catch can on the vent plug where did you get those?
Mods:
Old 10-09-2015, 12:42 PM   #13
Latemodelrestoration
I agree. modding is too fun, but at least the rear end I found has 3.31 and not 2.73 like I had from stock
Old 10-09-2015, 01:11 PM   #14
shunc01's Avatar
331 are fun to drive too, that's what I had before way better than 273... Thanks for the link I will try this out. Good luck keep us posted.
Mods:
Old 10-09-2015, 01:29 PM   #15
Oh I will. On this same thread too.
Going monday to pay for part of the axle, and should have it by thursday.
Then Dropping the car off on Friday or the following monday.
Hopefully in a week I'll be posting pictures of her all spiffy clean, not threads on my rear end problems lol
Old 10-09-2015, 01:35 PM   #16
shunc01's Avatar
There's always a way man, but just cost some money.. Can you find a 8.8 rear-end with 373 gears on it already? That will be awesome..
Mods:
Old 10-09-2015, 01:44 PM   #17
There is one on ebay I think, but idk what the heck shipping will cost me.
3.31 is alright I suppose.
Does anyone know if the 3.7 uses the same axle as the 5.0? They advertise the one's on ebay as 5.0 rear ends
Old 10-09-2015, 02:55 PM   #18
Fintile's Avatar
It should work. the rear ends on the V6 and V8 are the same. This makes me seriously reconsider getting 3.73 gears now...I have 3.31 right now and want the extra OOOMPH from the 3.73s but not if these kinds of headaches keep happening. ShunC already had his stock DS break on him after the 3.73 install and you Lava are having noise and grinding issues. I hope you are able to get it all worked out.
Fintile is offline   Reply With Quote
Old 10-09-2015, 07:02 PM   #19
FastFord13's Avatar
You should sell that over priced noise enhancing pos ds, you would be mich better with the stock one like I have! Wanna trade 😁😁😁
Sent from LG G3.
Old 10-09-2015, 08:13 PM   #20
Yeah if I could go back in time I would leave the gears alone haha. But the 2.73s are so lame. The 3.31 in the axle I'm buying should be good enough, not messing with this rear end at all.
I've still got my stock driveshaft too.
This has been a nightmare though, I you are right on money, leave the rear end alone
Old 10-09-2015, 08:18 PM   #21
FastFord13's Avatar
I must of lucked out with my gears. I have read some scary gear install stories in the last little while.
Sent from LG G3.
Old 10-10-2015, 07:45 AM   #22
shunc01's Avatar
I had feeling that the sound that I am hearing in mine is not from the rear end but it might be from the 1 piece aluminum ds I have, cos I don't have the whine but it sounded like a hollow sound very faint, it seems like when the ds is turning kinda sound hollow, I don't know if I'm describing it right.. But do you guys think rotating it from a different hole would solve the problem? Because when I had my gears changed at first there was zero noise until they have to replace my pinion seal and bearings and now the noise is there..
Mods:
Old 10-10-2015, 07:56 AM   #23
Fintile's Avatar
is the Alum DS hollow?
Old 10-10-2015, 09:33 AM   #24
shunc01's Avatar
I don't know man.. It sounds like it though.
Mods:
Old 10-10-2015, 10:36 AM   #25
Fintile's Avatar
LOL if it is see if you can fill it with calking foam...that'll fix the hallowed out sound LOL
Of course it would throw the balance WAY off...
Old 10-10-2015, 02:12 PM   #26
shunc01's Avatar
Of course it would through the balance WAY off...
Lol... Dang right.. No Bueno for me lol..
I called axle exchange and they advise to put sound deadening In the housing where the driveshaft is.. They also said that it is normal to hear some noise from the driveshaft since it is aluminum and lightweight.
Mods:
Old 10-12-2015, 09:07 PM   #27
Are the rear axle's the same on the GT and V6?
Basically, does it matter if I buy a rear axle that came off of a 5.0?
Old 10-13-2015, 06:14 AM   #28
JimC's Avatar
Yes, they are the same.
JimC is offline   Reply With Quote
Old 10-13-2015, 09:38 AM   #29
Thanks ^^^
If all goes to schedule, I'll have the rear end by Friday and in the shop that same day or Monday
Old 10-13-2015, 09:46 AM   #30
shunc01's Avatar
Goodluck man, hope everything will squared away.. How much was the rear end you found? If you dont mind me asking.
Mods:
Old 10-13-2015, 01:43 PM   #31
Like 800. eBay is like 600-700 plus God knows what for shipping.
I got a warranty on it too, for the axle and labor in case they have to install again if the one I buy is damaged
Old 10-13-2015, 02:02 PM   #32
shunc01's Avatar
Oh nice they supply there own parts, thats pretty good is that included with the install for 800?
Mods:
Old 10-13-2015, 02:10 PM   #33
No I got it from a pullnsave or parts salvage. I have to pay for install too, dealership isnt cheap
Old 10-13-2015, 02:15 PM   #34
shunc01's Avatar
Oh wowww.. Hopefully this will be the last at least it's not the transmission. How many miles on the rear end?
Mods:
Old 10-13-2015, 02:43 PM   #35
Haha yeah. My trans is good so far. This noise is forsure my rear end.
75k on my car and 28k on the rear end I'm getting Friday
2013 V6 Rear Axle FULL ASSY Swap to 2013 GT Rear Axle FULL ASSY sprdave 2011-2014 V6 Mustang 2 06-16-2015 12:14 PM
For Trade: Roush Axle-Backs for 13+ GT500 Axle-Backs SecretAgent Mustang Parts for Sale and Wanted 3 06-07-2014 06:41 PM
Difference between 2.3 rear axle gears and 5.0 rear axle gears 93mstnglx 2.3 Mustang 9 07-07-2013 05:12 PM
does the hub on the rear axle have a gasket between it and the axle? stangcobra Pre-2005 V6 Mustang 15 11-06-2012 04:16 PM
Help, rear axle bearing is bad Banshee 1996-2004 Mustang GT 1 02-13-2011 05:33 PM
05:04 PM
