Suspension Issue - HELP - Mustang Evolution
Old 10-09-2015, 11:33 AM   #1
Got a 2014 Stang v6 about a month ago with 29k miles. I never noticed it at first until I put my after market wheels on but the passenger side FRONT wheel sticks out further and closer to the fender than the drivers side. Is there a fix for this? WTF ford...
ID:	192100   Click image for larger version
Gammer2015 is offline   Reply With Quote
Old 10-09-2015, 11:35 AM   #2
Mean14's Avatar
Do you have pictures?
Procharged D1 on 12Lbs, MPT 93 Tune, 73mm BBK TB, Ported Upper/Lower Intakes, BBK Shorty Headers, FRPP Cut n Clamp Xpipe, Borla S-Types, Barton Short Shifter/Blowfish Bracket, SS Clutch Line, Whiteline Trans Bushing, One Piece Driveshaft, Front and Rear Tower Brace, Whiteline Front and Rear Sway Bars, Whiteline Adj LCAs/Adj UCA, BMR Relocation Brackets, BMR adj Panhard Bar, Eibach Sportlines, FRPP Dampers, 20" AMRs, 3.55 gears, Brembos
Mean14 is offline   Reply With Quote
Old 10-09-2015, 11:51 AM   #3
Pics posted, very noticeable from top view of fender
Old 10-09-2015, 11:55 AM   #4
5pointYoBro's Avatar
wheel spacers on one side?? idk honestly
2014 GT. Oxford White.
20" Velgen VMB5s on NT555s.
MBRP Race Series Catback Exhaust
Bama 93 Performance Tune
5pointYoBro is offline   Reply With Quote
Old 10-09-2015, 11:56 AM   #5
Nope, all factory except for wheels...
Old 10-09-2015, 12:03 PM   #6
Socal Stangman's Avatar
Maybe get an adjustable panhard bar?
Old 10-09-2015, 12:04 PM   #7
It's his front wheels though
Old 10-09-2015, 12:16 PM   #8
Yes this is on the Front wheels..
Old 10-09-2015, 12:17 PM   #9
I'd take the 2 front wheels off and look. Or at least the one that stick out
Old 10-09-2015, 12:19 PM   #10
Oh missed that. My 2014 is like that too. I use a 5/16' spacer and its not so noticeable.
Old 10-09-2015, 12:24 PM   #11
Diehard's Avatar
Look at the inside of the new rims for the amount of offset, to make sure they agree with each other.
If you still have the original wheels did you try them?
Old 10-12-2015, 05:56 PM   #12
iamcesarmiranda's Avatar
This is strange, I would agree with @diehard on this one.
iamcesarmiranda is offline   Reply With Quote
Old 10-12-2015, 06:32 PM   #13
More Info
Pulled the wheel and measured and all 4 are the same. I did notice that a part of the suspension bolted to the bottom of the frame and control arm does stick out 1/4 more then the drivers side which could explain some of the issue. Pics are attached. On the drivers side the black part is flush with white frame.
ID:	192267   Click image for larger version
Old 10-12-2015, 10:24 PM   #14
Mean14's Avatar
My guess is that it was in an accident at one point and the body work isn't perfect.
Old 10-12-2015, 10:39 PM   #15
hope not
Well I sure hope not, has 2 clear vehicle reports..not to say a wreck was not reported.
Old 11-16-2015, 02:40 PM   #16
Took it to the dealer, they were able to shift the sub-frame over and front end alignment so all is good now.
Old 11-16-2015, 03:48 PM   #17
VIG
VIG's Avatar
Region: Delaware
Glad they fixed that for you.
I'd never seen something like that before.
IG: workshardplayshard
VIG is offline   Reply With Quote
Old 11-16-2015, 05:08 PM   #18
rmb427r's Avatar
Did the dealer give any indication as to why it was like that??
Ron..
2008 Roush 427R
2014 V6 Prem
rmb427r is offline   Reply With Quote
Old 11-16-2015, 07:47 PM   #19
tym_v6's Avatar
They ain't never gonna tell.
Fuel issue? Ignition issue? jriccard 1979-1995 Mustang GT 7 07-04-2015 12:42 AM
Suspension Upgrades/issue paintmann111 2011-2014 V6 Mustang 11 03-11-2014 10:58 AM
Suspension issue 13 stang22 2011-2014 V6 Mustang 15 02-22-2014 06:18 AM
BMR Suspension parts with 1 issue Coyote 5 2011-2014 Mustang GT 26 10-03-2012 10:10 AM
will trade fairings and lowered suspension for stock suspension vincent1 1996-2004 Mustang GT 2 06-22-2009 07:34 AM
07:11 PM
