Gauge Mod - Mustang Evolution
Old 10-09-2015, 03:08 PM   #1
AngryTech's Avatar
Gauge Mod
Hey Guys, Wanted to share my newest DIY mod. I was in the market for a new gauge cluster. But all I'd want it for was the newer gauge look. Not really interested in the track apps. So before I went spending 300+ just for a newer look. I decided to improve the one I had. Was pretty easy to do. Wired them into the headlight switch, so whenever I unlock or open the door, they come on.
$20 later... Let me know what you guys think.
ID:	192106   Click image for larger version
AngryTech is offline   Reply With Quote
Old 10-09-2015, 03:09 PM   #2
Voltwings's Avatar
Just change the lights?
Old 10-09-2015, 03:11 PM   #3
AngryTech's Avatar
Would have but I would need to solder the colored LED's on the board itself. This was much less invasive and cheaper.
Edit: I bought red halos and installed them to the Gauge cover. My car is a Base V6 and did not come with the My color option.
Old 10-09-2015, 03:26 PM   #4
Fintile's Avatar
Track apps? They didnt have that for 2011' or 12's. WOuld that have even worked?
Fintile is offline   Reply With Quote
Old 10-09-2015, 03:30 PM   #5
AngryTech's Avatar
It would have, but you'd need the "as built" codes for a car that did have them. Once you have those, it would allow you to access the apps. Plus, you'd need the steering wheel that has the D pad to control it normally.
Old 10-09-2015, 03:42 PM   #6
Fintile's Avatar
NO ****?! not a bad idea...wouldnt mind that. i though they installed sensors everywhere on the car, you mean its all just in the gauge? Very cool to know. Is it the whole steering wheel or just the left hand insert with the D-pad?
Old 10-09-2015, 03:48 PM   #7
AngryTech's Avatar
That's what I thought too. But reading a whole bunch of other forums and Google searches. It's just the apps that run from the cluster. A ford dealer would have to install the codes for you, or you could buy the software that Ford uses and do it yourself. If you have a premium wheel, then it would just be the controls on the left side of the wheel. So that's why I just went with buying red halos and installed them myself. Such an easy project and love the way it looks at night.
Old 10-09-2015, 06:09 PM   #8
Kevin.Cook
Guest
Posts: n/a
I did a cluster swap on my 2014 😂
You need the Ford VCM II tool, steering wheel button, cluster, as built codes, and 2 keys.
Old 10-09-2015, 06:25 PM   #9
AngryTech's Avatar
That's the one.
Old 10-09-2015, 06:47 PM   #10
FastFord13's Avatar
Good job, looks really good!!
Sent from LG G3.
Old 10-09-2015, 08:23 PM   #11
AngryTech's Avatar
Sent from LG G3.
Thank you sir!
Old 10-09-2015, 08:27 PM   #12
Kevin.Cook
Guest
Posts: n/a
Originally Posted by AngryTech View Post
Thank you sir!
You are very welcome
Old 10-09-2015, 08:32 PM   #13
AngryTech's Avatar
Strikes again!
Old 10-09-2015, 08:36 PM   #14
ponie1992's Avatar
Details on which halos and how you installed them, please!
Jeremy
2012 Black PP V6
Jeremy
2016 Ruby Red PP GT
ponie1992 is offline   Reply With Quote
Old 10-09-2015, 09:01 PM   #15
AngryTech's Avatar
Halo rings 130mm
http://pages.ebay.com/motors/link/?n...044355&alt=web
Already had the led dimmer from a different project.
http://pages.ebay.com/link/?nav=item...037061&alt=web
How to:
I pulled off the gauge cover and glued the halo rings facing me. I then soldered the Leds together to the dimmer controller. I ran two wires from the headlight switch behind the gauge cover(YouTube video on how to expose the wires I describe
https:// youtu.be/x2aKeaEjpLc.)
I connected the first wire to the black/purple wire(ground). Then connected the second wire to purple/orange wire(power). I then soldered the ground and power wires together to the dimmer controller and reattached the cover into the dash. Pressed the unlock button on the fob and bam! These are bright! So I turned up the car dimmer wheel and then dimmed the halos with the little switch until it was comfortable. All done! Took me about 30min to complete.
Old 10-09-2015, 09:25 PM   #16
Kevin.Cook
Guest
Posts: n/a
Strikes again!
I aim to please!!!
Old 10-09-2015, 11:26 PM   #17
ponie1992's Avatar
Halo rings 130mm
How to:
Thanks for the info!
Jeremy
2012 Black PP V6
Jeremy
2016 Ruby Red PP GT
Old 10-09-2015, 11:28 PM   #18
CodyMustang3.7's Avatar
Love it so much looks Great!!
CodyMustang3.7 is offline   Reply With Quote
Old 10-10-2015, 05:34 AM   #19
Fintile's Avatar
2 keys? Do they need to be special 2013-14 keys or something? It does sound like a lot just to have a 0-60 and 1/4 mules app. I've seen stand alone units that you can plug into your OBDII port and run the same thing there. They some times can even give you a hp and trq number too (it's all estimated)
“anybody driving slower than you is an idiot, and anyone going faster than you is a maniac”
-George Carlin
Old 10-10-2015, 08:00 AM   #20
Kevin.Cook
Guest
Posts: n/a
Just the two keys that came with the car. Or if you had to get a 2nd one made.
Old 10-10-2015, 08:16 AM   #21
Fintile's Avatar
Oh shoot, so you would need the keys that came from the car that had the gauges?
Or just 2 keys that came with your own car?
Sorry it could just be too early for and im over thinking this.
Old 10-10-2015, 09:04 AM   #22
Kevin.Cook
Guest
Posts: n/a
Just 2 keys for your car. Because the tool needs to resync the keys to the new cluster but only does it if you have 2.
Old 10-10-2015, 09:35 AM   #23
AngryTech's Avatar
Hence why I chose to go this route. Nothing wrong with the experience in getting this to work. Just wasn't for me. Another way someone could change the look is to order a new gauge background from blackcatcustom.com. But just for looks.
Old 10-10-2015, 10:07 AM   #24
Fintile's Avatar
AAAhhhh...ok ok I got it...well thats not too bad except for the Ford tool and the codes
Old 10-10-2015, 01:20 PM   #25
3.7Muscle's Avatar
I LOVE IT! Sorry for the caps, this kind of DIY makes me happy in my pants!
See my Baby Here
2012 101a Mustang V6 M/T 6-Speed
3.7Muscle is offline   Reply With Quote
Old 10-10-2015, 01:27 PM   #26
ponie1992's Avatar
Checked them out a bit ago. They can do some pretty cool stuff. Maybe in the future.
Jeremy
2012 Black PP V6
Jeremy
2016 Ruby Red PP GT
Old 10-10-2015, 01:54 PM   #27
AngryTech's Avatar
Thank you sir! Yeah, I was super excited to get this done. They have different colors available too. I did think about doing the RGB color changing. But my theme is red on the inside.
Old 10-10-2015, 01:59 PM   #28
AngryTech's Avatar
Jeremy
2012 Black PP V6
Yeah. I liked the GT500 version. But for 125... Maybe later when I want to change the gauge again.
Old 10-10-2015, 06:32 PM   #29
ponie1992's Avatar
If I were to get a set, I'd have them add a running pony and my forum name. That'd be pretty cool.
Jeremy
2012 Black PP V6
Jeremy
2016 Ruby Red PP GT
Old 10-10-2015, 06:42 PM   #30
AngryTech's Avatar
Jeremy
2012 Black PP V6
I like the running pony too. Was going to pull the trigger until I realized what I actually liked about the new gauge. Then I thought of this mod.
Old 10-10-2015, 07:33 PM   #31
ponie1992's Avatar
I'm wondering, would the pony light up? Now, that would be sweet!
Jeremy
2012 Black PP V6
Jeremy
2016 Ruby Red PP GT
2005 4 gauge cluster upgrade to 6 gauge wessstblvdd 2005-2010 Mustang GT 6 07-07-2014 08:29 AM
Best Mod and Worst Mod Rcary 2011-2014 V6 Mustang 30 06-04-2012 06:26 AM
Gauge mod 813floridaracin Pre-2005 V6 Mustang 27 03-31-2012 04:27 PM
20 gauge to 18 gauge XXSTEVEO66 General Mustang Discussion 0 08-16-2011 06:58 PM
Gauge Wire Routing w/CDC gauge pod tripod_2005 2005-2010 Mustang GT 13 04-30-2010 11:46 AM
04:58 AM
