Driveline question. - Mustang Evolution
Old 10-11-2015, 11:53 AM   #1
Driveline question.
Should my back axle be moving with the car in Neutral ? Cars up on blocks with the wheels and rotors, and mufflers off... started her up to see how the cars sounds without them. Noticed the rear hub going about 15 rpm. Got back in and pushed the clutch in and they stopped... but the car was in neutral the whole time??
Ppkonablue12 is offline   Reply With Quote
Old 10-11-2015, 04:02 PM   #2
Diehard's Avatar
Believe that is not unusual.
Remember that the clutch is engaging the flywheel to the input shaft of the transmission. So I suspect the spinning moves the gear oil enough to turn the gears on the output shaft.
You will probably get a better answer from someone who knows what they're talking about. LOL
Old 10-11-2015, 04:44 PM   #3
VIG
VIG's Avatar
Region: Delaware
No need for concern. This is normal.
IG: workshardplayshard
VIG is offline   Reply With Quote
Old 10-11-2015, 05:16 PM   #4
Voltwings's Avatar
In my experience, you'll find that more or less the inertial transmitting device is mated to the torque acceptance shaft of the transmission. This "intertial" spinning motion is often enough to agitate the associated lubricants and cause collateral movement among the related gears and, torque output device, respectively.
Old 10-11-2015, 07:09 PM   #5
Diehard's Avatar
As in a torque transmitting device.
LOL
Old 10-11-2015, 07:44 PM   #6
Voltwings's Avatar
Old 10-11-2015, 07:59 PM   #7
So nothing to do with the flux capacitor??
Old 10-11-2015, 08:03 PM   #8
natestang07's Avatar
Only have to worry about that if the gigawatts drop below 5
Old 10-11-2015, 08:10 PM   #9
Thanks guys. Out painting my calipers now. Cars are stress relief....
Tremec driveline Angle Finder crroy71 Mustang DIY and Technical 0 12-18-2014 07:47 PM
Stock Automatic Driveline Concerns DtrMustang 2005-2010 Mustang GT 7 08-17-2013 08:02 PM
Rebuilt Driveline and Vibration...Need help/advice vinnie7009 1979-1995 Mustang GT 5 08-08-2008 02:34 PM
Driveline loss gdcpony Pre-2005 V6 Mustang 0 08-17-2003 04:30 PM
06:25 AM
