Wheel Size - Mustang Evolution
Old 10-13-2015, 05:02 PM   #1
PaPa's Avatar
Wheel Size
Hey Friends, Someone tell me what to expect if I change the wheels on my 2014 Premium pony from 18" X 8" which is what it came with to 18" X 8.5" ? Also do I need new tires ? Thanks for the response..
PaPa is offline   Reply With Quote
Old 10-13-2015, 05:54 PM   #2
ponie1992's Avatar
That's a very small change in width and shouldn't effect anything. Should create a slightly wider contact patch from the tires and won't affect their height much at all.
Jeremy
2012 Black PP V6
Jeremy
2016 Ruby Red PP GT
ponie1992 is offline   Reply With Quote
Old 10-14-2015, 02:11 AM   #3
PaPa's Avatar
Thanks, I was kind of thinking that. I have found if you post an idea or project on here, sometimes you get various opinions to think about..
Old 10-14-2015, 06:44 AM   #4
ponie1992's Avatar
Yep, that's what this forum is all about.
Jeremy
2012 Black PP V6
Jeremy
2016 Ruby Red PP GT
Old 10-15-2015, 06:53 PM   #5
Hampton CIT's Avatar
It'll give you some latitude my friend. I think the widest tires you can put on an 8" rim effectively (you can go bigger but you are pushing limits) is 235s. On our sixers, there really isn't a point of packing 305 etc. Now a 255... on a 8.5" rim you're talkin! But what ever you're running now will work fine on both rims.
2016 Premium Eco w/ PP - Roush Quarter Window Scoops, Side Scoops, Rear Spoiler; Modded GT Mesh Grilles; FP Strut Tower Brace; Eibach Pro-Kit Springs; Steeda IRS Bushings; BMR Billet Delrin/Spherical Vertical Links; Mishimoto Oil Separator; MAPerformance CAI; Mishimoto Intercooler/Aluminum Charge Pipes; Turbosmart Kompact Dual Port BOV; Turbosmart IWG75 Wastegate (10 PSI); Mishimoto Coolant Tank; JLT Engine Cover; Mishimoto Downpipe with modded MBRP XP Catbacks for TRUE 3" exhaust from turbo to tips; Drilled/Slotted Brake Rotors
Hampton CIT is offline   Reply With Quote
Old 10-15-2015, 08:21 PM   #6
Voltwings's Avatar
^^ This.
Old 10-16-2015, 05:15 AM   #7
PaPa's Avatar
Thanks
Yea thanks for the info. I just want to get rid of those Pirelli P Zero tires. I don't think that they are one of Fords better ideas. I recently purchased a set of Ford Chrome Bullitt wheels 18 X 8.5. I'm planning on putting a set of Michelin's on them. I think I will stay with the standard 235/50. Ill just try to sell the factory wheels, tires, nuts as a local pick up here. Looks like its going to be a beautiful week end here in eastern NC. Have a good day.
Old 10-16-2015, 08:38 AM   #8
kapcan2k's Avatar
This is a good website if you want to compare different size tires/wheels
https://www.tacomaworld.com/tirecalc
kapcan2k is offline   Reply With Quote
Old 10-16-2015, 10:01 AM   #9
MustangDawg's Avatar
What if the tire manufacturers specifications for a 255/45/18 indicated the minimum wheel width of 8" and the maximum width of 9.5", would this still be OK with the 18x8 wheels?
2013 V6 Auto Premium | Sterling Gray | Pony/Comfort/Security Packages
Borla S-Type AB, Airaid CAI, SR Performance STB, JLT Oil Separator, MPT Tuned, MMD Classic Louvers, Roush Upper & Lower Grilles, BFGoodrich G-Force Sport Comp-2 A/S Tires, Koni STR.T Shocks & Struts, SR Performance Lowering Springs, J&M Stainless Steel Teflon Brake Lines, BMR LCAs w/Brackets, BMR Panhard Rod Support, Whiteline Adj. Panhard Bar, Ford Racing Differential Finned Cover Plate, Philips X-tremeVision LED Fog Lamps, JMS PedalMax
MustangDawg is offline   Reply With Quote
Old 10-16-2015, 10:47 AM   #10
PaPa's Avatar
I would think so . You are in the range.
Old 10-16-2015, 11:06 AM   #11
That's what I think as well. I usually like going with manufacturers specifications as they know what will fit. Besides, the difference in width between the 235 and 255 tires I've been looking at is only a 0.80" increase in width, which is 0.40" on either side of the wheel.
Old 10-16-2015, 12:36 PM   #12
Voltwings's Avatar
Even though you're on the low end of the range, the tall sidewall gives you a little breathing room as far as fitting that tire on there, It may just make the handling a little ... floaty? squishy? It will be fine, i'm just saying its something you MAY notice. Personally i'd prefer to run a 255 on a 8.5" rim minimum, but i understand you're working with a budget.
Old 10-16-2015, 01:39 PM   #13
Papa, I hear ya on the P Zeros. Didn't really ever dislike mine, but I never loved them either. Put on a set of General Gmaxx a few months back and love em'. On the lower range of price, good mileage and grip. I considered going to 255/45-18s tires. Getting back to the original point of your thread, I know if I were going to spring for rims, I'd go 8.5" width with 255/45s on em'. My two cents.
Old 10-16-2015, 04:20 PM   #14
Thanks for the constructive feedback. I'm currently running the stock Pirelli 235/50/18 which has a bit taller side wall which is floaty enough, so stepping down to a 45 side wall should be a wash or maybe a tad bit firmer. I guess I'm splitting hairs, but I just want a wider footprint which the 255s should fit the bill. Dang, anything will be an improvement over the Pirellis
what size rims and what size slicks for 2005 GT? inzain Mustang Wheels & Tires 3 11-30-2013 08:37 PM
Tire size and rim size 96gt Lios 1996-2004 Mustang GT 9 04-22-2012 10:33 PM
Wheel size & tire size help needed for newbie rayramos Mustang Wheels & Tires 14 09-21-2009 11:45 AM
97 v6 Wheel Size Kiljosh Mustang Wheels & Tires 17 11-09-2004 11:26 PM
NEED HELP with Wheel size Linkan Mustang Wheels & Tires 6 04-25-2004 10:00 AM
03:41 PM
