My rod bearing:( - Mustang Evolution
Old 10-18-2015, 04:55 PM   #1
Geok.91's Avatar
My rod bearing:(
Pretty sure I threw out my rod bearing 21k miles on my car with me doing my first 2 oil changes on the car with mobile 1 full synth 5w 20 pretty sure warranty is going to be void because of that any body know about how much I will be paying out of pocket to get this fixed?
Geok.91 is offline   Reply With Quote
Old 10-18-2015, 05:05 PM   #2
natestang07's Avatar
They are going to void your warranty due to the oil you use,
---------- Post added at 04:05 PM ---------- Previous post was at 04:04 PM ----------
Old 10-18-2015, 05:11 PM   #3
Geok.91's Avatar
Fml I screwed up this time pretty big what if I change my oil out for something recommend before complaining they will still void my warranty because I have been the one doing the oil changes?
Old 10-18-2015, 05:11 PM   #4
Find another dealer then
Old 10-18-2015, 05:13 PM   #5
Geok.91's Avatar
I haven't went yet I'm just assuming they're going to say it's my fault
Old 10-18-2015, 05:13 PM   #6
If they do call corporate. That is the dumbest thing I have heard.
Old 10-18-2015, 05:20 PM   #7
Geok.91's Avatar
Okay so what your saying is they shouldn't void my warranty just because I do the oil change myself . if I remember correctly when I bought the car the salesman popped the hood and sayed u see those two yellow things that's all you can touch oil dipstick and I forget what the other is
Old 10-18-2015, 05:25 PM   #8
Slap that salesman and call him a dip**** while you are at it
Old 10-18-2015, 05:31 PM   #9
Geok.91's Avatar
Guess I'll call down tomorrow and see what they say and dammmmmm how the f do u spin a rod on a 20k miles car I got it brand new I do go wot occasionally but besides for that it gets babied . **** I've beat the piss out of my 92 integra over 230 k miles and never managed to do something this tragic to the car only blew a head gasket but that took about 30 k
Old 10-18-2015, 05:31 PM   #10
PaPa's Avatar
As long as you had the service done at the proper times, I don't see there should be a problem with the warranty. I would not accept anything other than Ford is going to repair it..
PaPa is offline   Reply With Quote
Old 10-18-2015, 05:35 PM   #11
alrefire's Avatar
it shouldn't be a problem.
Old 10-18-2015, 05:46 PM   #12
Geok.91's Avatar
My rod bearing:(
Which oil should I switch to before I take the car to them so the don't void my warranty for that natestang??
Old 10-18-2015, 05:48 PM   #13
Geok.91's Avatar
I hope it's not a problem I just get screwed in everything in my life that's where my mentally is right now
Old 10-18-2015, 06:04 PM   #14
Using the oil that's in it now should not and absolutely IS NOT grounds for voiding the warranty. If that's the only thing done to the car and you did the motor oil and oil filter change correctly you have nothing to worry about. Besides, who can prove that the oil itself was the cause of a spun bearing? No one! Because that almost never happens.
EDIT: I should've asked, how many miles are on the current fill of oil?
2013 v6, performance pack, mt82 manual, MGW Race Spec shifter, SVE Drifts 19x9.5, H&R Supersport springs, Koni yellows, BMR panhard bar, adjustable UCA and LCA, shorty antenna, GT500 strut mounts, black painted roof, Roush splitters all around, GT hood and fog lights.
Josh_101 is offline   Reply With Quote
Old 10-18-2015, 06:10 PM   #15
Just put the recommended weight of Motorcraft oil before you take the car in. And don't volunteer any information! Tell them that your engine is making a strange noise, and nothing else.
It is perfectly acceptable to change your own oil, but you should always keep the receipts,
I don't think that you will have any problem with them covering this under warranty.
Old 10-18-2015, 06:52 PM   #16
mark_ash0426's Avatar
My car had 31K miles and i had a rod bearing break. They never asked me for service records they are giving me a new short block engine at the moment hope for it to be done by this week. It sucks *** but just gotta talk to them make them feel its their fault like an engine failure and not your fault. And just in case change the oil so they don't make a big deal out of it. And if you have hookups in a shop or with somebody that does oil changes for you if they ask for maintenance reports just ask them to help you out if you know what i mean 👌🏼 goodluck bro i know it sucks
And as far as rebuilding it would be more expensive, buying a new used engine would be your best bet. About $4500 for engine and another $1500 for engine. OR look at your insurance policy and see if they cover engine or transmission failure. That would be your last bet.
mark_ash0426 is offline   Reply With Quote
Old 10-18-2015, 06:57 PM   #17
VIG
VIG's Avatar
Region: Delaware
You're fine.
You used 5w-20 which is what is required for the car. It doesn't matter what brand it is.
As long as you're not tuned, and you changed the oil at the recommended intervals then you're fine.
No need to switch the oil out in your car. Give it to them as is. They will be more suspicious if they see fresh oil.
IG: workshardplayshard
VIG is offline   Reply With Quote
Old 10-18-2015, 07:23 PM   #18
Geok.91's Avatar
Mark you just made me feel a lot better .everyone else thanks for your comments gotta love the mustang community... Btw mark did they give you a loaner car because this is currently my only car running
Old 10-18-2015, 07:24 PM   #19
MC770's Avatar
I just wouldn't mention you changed the oil yourself, can't void the warranty (which I doubt they would anyway) if they don't know that
~2003 Zinc Yellow Terminator Cobra~
~482 RWHP / 487 LBS Torque~
MC770 is offline   Reply With Quote
Old 10-18-2015, 07:32 PM   #20
Mean14's Avatar
Am I missing something here? 5w20 is what is recommended for our cars. Why are you tweaking out? Take it in and get it covered. Why would they void your warranty?
Procharged D1 on 12Lbs, MPT 93 Tune, 73mm BBK TB, Ported Upper/Lower Intakes, BBK Shorty Headers, FRPP Cut n Clamp Xpipe, Borla S-Types, Barton Short Shifter/Blowfish Bracket, SS Clutch Line, Whiteline Trans Bushing, One Piece Driveshaft, Front and Rear Tower Brace, Whiteline Front and Rear Sway Bars, Whiteline Adj LCAs/Adj UCA, BMR Relocation Brackets, BMR adj Panhard Bar, Eibach Sportlines, FRPP Dampers, 20" AMRs, 3.55 gears, Brembos
Mean14 is offline   Reply With Quote
Old 10-18-2015, 07:34 PM   #21
VIG
VIG's Avatar
Region: Delaware
Exactly what I was getting at.
Old 10-18-2015, 07:43 PM   #22
Geok.91's Avatar
No the guy Nate said at the beginning of the thread Mobil 1 will void the warranty that's why I was asking should I change it . And I'm wondering because there is no proof of as when the oil changes were made the can use that to there advantage I'm tweaking out because for the past 3 years it seems like I take 2 steps forward to get thrown 3 steps back
Old 10-18-2015, 07:45 PM   #23
VIG
VIG's Avatar
Region: Delaware
Mobil 1 will absolutely not void your warranty.
You don't keep any receipts for oil filters or oil?
Old 10-18-2015, 07:49 PM   #24
Geok.91's Avatar
Something I should have done lol life lesson learned save all receipts
Old 10-18-2015, 07:51 PM   #25
Geok.91's Avatar
And I honesty thought my warranty would be up before anything major happened
Old 10-18-2015, 07:52 PM   #26
VIG
VIG's Avatar
Region: Delaware
My rod bearing:(
Definitely a good rule to live by.
Quick question: what oil filter were you using?
EDIT: Also, what makes you think you spun a rod bearing?
Old 10-18-2015, 07:54 PM   #27
Geok.91's Avatar
Mobile 1 extended performance
Old 10-18-2015, 08:05 PM   #28
Geok.91's Avatar
My rod bearing:(
I'd did some search today and I found a guy on a thread here and I have the same exact symptoms he was having he didn't know what it was though then later in his thread he found it was the rod bearing ...... Then my friend stopped by my work a couple hours ago he's a bit of a mechanic . He pulled out the stethoscope and said it was definitely coming from bottom down there
Drivers side
Old 10-18-2015, 08:13 PM   #29
When the f did I say that lol
Old 10-18-2015, 08:15 PM   #30
Geok.91's Avatar
If you wanna know the symptoms there's a loud metal rattle from the motor between 2300 to 2800 rpm it's feint when there motor is cold but gets louder when she warms up
Old 10-18-2015, 08:16 PM   #31
Geok.91's Avatar
Here
Old 10-18-2015, 08:18 PM   #32
VIG
VIG's Avatar
Region: Delaware
He was asking a question not making a statement.
He put the question mark in late. Lol
Old 10-18-2015, 08:23 PM   #33
Geok.91's Avatar
Lmao didn't pay attention to that
Old 10-18-2015, 08:26 PM   #34
Geok.91's Avatar
I was never worried about what brand oil til he said that lol I was just worried about me doing it personally
Old 10-18-2015, 08:28 PM   #35
VIG
VIG's Avatar
Region: Delaware
They can't void a warranty because you did it yourself.
They'd have to prove that you screwed it up somehow, and an oil change is really hard to screw up.
Poly, Rod, or Poly/Rod panhard bar? Mustang Coyote 2011-2014 Mustang GT 2 12-19-2014 11:03 AM
Spun a rod bearing :(...need ideas 98MustangGT 1996-2004 Mustang GT 8 09-20-2012 08:34 PM
2010 HD V-Rod Muscle :: 2010 Harley Davidson V-Rod Muscle Jetag93 Member Garages 0 08-12-2012 05:47 PM
Rod bearing Niko Cherad Pre-2005 V6 Mustang 5 11-22-2011 07:50 AM
Rod bearing noise? OH NO!!! In2dreamingbig 1996-2004 Mustang GT 12 04-28-2006 12:22 PM
07:56 PM
