setting speedo with SCT - Mustang Evolution
Old 10-28-2015, 04:18 PM   #1
randyg's Avatar
Region: Iowa
Hey everyone,
I changed the tune on my 13 and cant remember where the setting for the speedo is. I have 4.10 gears in back so needless to say the speedometer is waaaay off. Can anyone help me? SCT from Steeda.
Thanks
Randy
2013 Premium Pony.Race Red Steeda CAI and tune, 4.10
randyg is offline   Reply With Quote
Old 10-28-2015, 04:24 PM   #2
sticks123's Avatar
Change the tune shouldn't change the speedo. Bama gives you 3 tunes...but there all set up for the same gear ratio.
sticks123 is offline   Reply With Quote
Old 10-28-2015, 04:28 PM   #3
Fintile's Avatar
Yeah, the tune should already be set to your gear ratio based on the info you provided them.
4.10s eh? manual or auto?
Do you have the stock drive shaft still installed?
“anybody driving slower than you is an idiot, and anyone going faster than you is a maniac”
-George Carlin
Fintile is offline   Reply With Quote
Old 10-28-2015, 04:31 PM   #4
DiESeven's Avatar
When you press next on the tuning device, it should bring you to a menu that gives you options to mess with such as gear ratio, idle rev limit, speed limiter, etc. You'd select what you want there before pressing Next to start the actual tuning process.
Old 10-28-2015, 04:35 PM   #5
Fintile's Avatar
Ok i just reread it...I think you meant to say that you just changed gears, not tune am i right?
-George Carlin
Old 10-28-2015, 04:49 PM   #6
Diehard's Avatar
The way I interpret it...
1. The tunes did not include the higher gear ratio.
2. He previously corrected a tune for the gears.
3. He just installed a new tune, which also didn't include the gears, and now can't remember how/where he adjusted for it previously.
This is all assuming it's adjustable by the user, of course.
Old 10-28-2015, 05:28 PM   #7
randyg's Avatar
Region: Iowa
Sorry for the confusion.....
Yeah, the tune was for octane rating and I had to manually set the gear ratio for the 4.10 which was added after the tune. Long story short, I changed the tune to another octane but went back to original and forgot where the setting is for the speedo. Called Steeda but they were closed for the day.
Randy
Old 10-28-2015, 05:48 PM   #8
Fintile's Avatar
AHHH, gotcha. Well hopefully you were able to get it figured out. Are you running those 4.10s with the stock drive shaft? if so how long have you been running them for?
-George Carlin
Old 10-28-2015, 06:00 PM   #9
randyg's Avatar
Region: Iowa
I'm running the stock drive shaft. Had the 4.10 for about a year and a half now. I don't hot rod the car hardly ever (only has 14000 miles) and on the hiway I usually run no more than 70 mph. Car is an automatic.
Randy
Old 10-29-2015, 05:47 AM   #10
Fintile's Avatar
Nice good to know.
-George Carlin
Snow and Wet setting in under 40 degree setting plus OE Summer Tires retiredf5 2015 Mustang GT 12 09-16-2015 11:32 PM
Good SCT setting? Ezra General Mustang Discussion 16 02-05-2014 12:12 AM
Speedo Off w/ SCT Tune Aggiesrok 2005-2010 Mustang GT 33 03-01-2012 12:52 PM
Break in for new gears?? SCT tuner to change speedo?? Camaro Eater Pre-2005 V6 Mustang 3 06-25-2010 07:03 AM
AMD setting the pace again... dark The Bar 8 08-23-2006 11:04 PM
12:28 AM
