fuel pump 11-14 - Mustang Evolution
Old 11-02-2015, 06:44 PM   #1
fuel pump 11-14
anyone know why a fuel pump would not wanna turn on?..does it have a reset somewhere in the vehicle?
jase33 is offline   Reply With Quote
Old 11-02-2015, 06:51 PM   #2
dave73's Avatar
fuel pump 11-14
I think there is a reset in the trunk at least with the older mustangs. I have never checked for it on my 12
dave73 is offline   Reply With Quote
Old 11-02-2015, 07:27 PM   #3
I've called d dealership..they say no..but under the driver side of d car there's a reset sign...but idk if its a fuse or a switch...ford says these come out with modules now...
Old 11-02-2015, 07:30 PM   #4
dave73's Avatar
Try behind the left kick panel (drivers side)
Old 11-02-2015, 08:17 PM   #5
Diehard's Avatar
Found this in the owner's manual...
WARNING: Fuel pump shut-off switch: In the event of an
accident the safety switch will automatically cut off the fuel
supply to the engine. The switch can also be activated through sudden
vibration (e.g. collision when parking). To reset the switch, refer to the
Fuel pump shut-off switch in the Roadside Emergencies chapter
FUEL PUMP SHUT-OFF
In the event of a moderate to severe collision, this vehicle is equipped
with a fuel pump shut-off feature that stops the flow of fuel to the
engine. Not every impact will cause a shut-off.
Should your vehicle shut off after a collision due to this feature, you may
restart your vehicle by doing the following:
1. Turn the ignition switch to the off position.
2. Turn the ignition switch to the on position.
In some instances the vehicle may not restart the first time you try to
restart and may take one additional attempt.
WARNING: Failure to inspect and if necessary repair fuel leaks
after a collision may increase the risk of fire and serious injury.
Ford Motor Company recommends that the fuel system be inspected
by an authorized dealer after any collision.
Did you check the fuel pump relay and the fuel pump relay fuse?
See your owner's manual for locations and warnings.
Old 11-02-2015, 09:25 PM   #6
But am I gonna look for a switch or a fuse?...
Old 11-02-2015, 09:28 PM   #7
Yea ill check it tomorrow...ot shut off since my aluminum driveshaft exploded
Old 11-03-2015, 10:33 AM   #8
What exact year is your car?
Kingkong
Chris44117 is offline   Reply With Quote
Old 11-03-2015, 10:37 AM   #9
2011
should i have to change fuel.pump and fuel filter?? jmpark527 2005-2010 Mustang GT 11 11-11-2011 09:38 AM
Pruchased my Fuel Injectors and Fuel pump today Brent Pictures and Videos 36 12-14-2010 03:22 PM
Where is the fuel filter and fuel pump in a 1966 mustang 289? brant General Mustang Discussion 6 03-04-2010 04:18 PM
WTB: Electric Air Pump (smog pump) MagnuM Mustang Parts for Sale and Wanted 0 05-16-2007 10:10 AM
19LB Fuel Injectors; 190-255LPH Walbro Fuel Pump Brent Mustang Parts for Sale and Wanted 5 05-11-2005 11:04 PM
01:56 PM
