water injection - Mustang Evolution
Old 11-04-2015, 08:20 PM   #1
water injection
anyone know how much hp a water injection gives to a car?
jase33 is offline   Reply With Quote
Old 11-05-2015, 06:15 AM   #2
Voltwings's Avatar
water injection gives negative horsepower. Alcohol injection, or water / methanol injection can give some power, but really its only beneficial in boosted applications.
The water acts as a chemical intercoolant because it absorbs nearly double the heat methanol does before evaporating. You only want enough water to disperse the heat though, any additional water displaces either fuel or oxygen in the combustion chamber and therefore impacts horsepower.
Methanol has an octane of about 110 and, is an oxygenated fuel, so it can be tuned to give more power but again its really not beneficial unless you are boosted. If you want a bump above pump gas just use E85.
Assuming you are boosted however, WMI is a tremendous benefit and can help the car run significantly better over all and i would highly recommend running it.
Old 11-05-2015, 02:06 PM   #3
NewMtang's Avatar
____________
So is that a Yes or No?
Old 11-05-2015, 02:45 PM   #4
VIG
VIG's Avatar
Region: Delaware
Originally Posted by NewMtang View Post
____________
The OP's question wasn't really a yes or no question. It was a "how much". And volt pretty much nailed the answer. As usual.
IG: workshardplayshard
VIG is offline   Reply With Quote
Old 11-06-2015, 11:09 AM   #5
Methanol gives about 30-90 hp if done right....
Anybody running water/ methanol Injection Mzilla 1996-2004 Mustang GT 0 07-03-2013 08:13 PM
Water methanol injection rviews Jesse Bach General Mustang Discussion 1 04-05-2012 09:17 AM
Water methanol injection Jesse Bach General Mustang Discussion 1 03-20-2012 11:16 PM
water methanol injection (snow kit) k28gt 1996-2004 Mustang GT 0 03-01-2008 01:42 PM
Alky/water injection kit for sale Monkey Mustang Parts for Sale and Wanted 0 03-13-2006 08:42 PM
09:04 PM
