H-Pipe Install - Mustang Evolution
Old 11-05-2015, 08:16 PM   #1
H-Pipe Install
Sup guys, so im getting ready to install my new Lethal Performance H Pipe this weekend. My question is, would the guides for GT's apply to the 6? The only guides I see are for X Pipes and not many at that for the v6
martinez8191 is offline   Reply With Quote
Old 11-05-2015, 08:57 PM   #2
DiESeven's Avatar
You can follow the X-Pipe guides. It's the exact same install.
Old 11-05-2015, 09:04 PM   #3
Mean14's Avatar
The installation will be similar for GTs and V6s. It's quite simple. Unbolt the mid pipe from the headers (2 bolts on each side for a total of 4.) Make sure to unplug your O2 sensors, you will be transferring them to the new pipe (mark which side is which so you don't get them confused.) Then unbolt the mid pipe from the over axle pipes. Installation of new hpipe is reversed. Be sure to put your O2 sensors back on before installing the hpipe to ease the installation.
Procharged D1 on 12Lbs, MPT 93 Tune, 73mm BBK TB, Ported Upper/Lower Intakes, BBK Shorty Headers, FRPP Cut n Clamp Xpipe, Borla S-Types, Barton Short Shifter/Blowfish Bracket, SS Clutch Line, Whiteline Trans Bushing, One Piece Driveshaft, Front and Rear Tower Brace, Whiteline Front and Rear Sway Bars, Whiteline Adj LCAs/Adj UCA, BMR Relocation Brackets, BMR adj Panhard Bar, Eibach Sportlines, FRPP Dampers, 20" AMRs, 3.55 gears, Brembos
Mean14 is offline   Reply With Quote
Old 11-06-2015, 04:35 AM   #4
I have no lift but I do have a pair of Rhino Ramps. Shoud I lift it from the front or back?
Also what extension is it that I need? I will go get it tomorrow beofre I start the install
Old 11-06-2015, 07:23 AM   #5
DiESeven's Avatar
Lift the front. Get like 1 foot extension AND a swivel connection. You'll have the stock midpipe off in under 5 mins.
Instagram: @v6beast
Old 11-07-2015, 04:05 PM   #6
So i might have to take it to a shop. I couldnt get this bolt off on the passengers side. The top one of the headers. Its almost out. its just now smoother so i have no idea what to do to take it off. I can replace it if i can take it off. Anyone have any ideas on how to take it off even if its by forcing it?? Il buy a a new nut if i have too. I just dont want to take it to the shop. I want to do it myself. Pleeeeeease help! tomorrow I will continue
Old 11-07-2015, 06:44 PM   #7
Mean14's Avatar
Take some penetrating fluid to it. PB blaster works great. WD-40 will work too. If that doesn't work, try heating it up. I actually got the passenger nut off by reaching it from the engine bay.
Old 11-07-2015, 07:48 PM   #8
Yeah I was thinking of taking out the battery to get easier access to that. Wish me luck tomorrow! im gonna try hammering in a 14mm to get it out
Old 11-07-2015, 11:24 PM   #9
Mean14's Avatar
I would suggest against that as you may dig yourself into a deeper hole. Stick with the correct size of 15mm and some patience.
Old 11-07-2015, 11:27 PM   #10
alrefire's Avatar
go ahead and rent an O2 sensor removal tool.
It will make your life 1000000x easier
also buy some PB blaster, or WD40. If you haven't removed those bolts before, they are a real PITA to get out.
---------- Post added at 12:27 AM ---------- Previous post was at 12:26 AM ----------
good advice here!
also, to heat them up, run your car for like 30 seconds. be careful not to burn yourself! haha
Old 11-08-2015, 01:10 AM   #11
Crescent wrench worked for me for the O2s
Old 11-08-2015, 05:43 AM   #12
I can't. The 15 just goes round and round
Old 11-08-2015, 08:33 AM   #13
Diehard's Avatar
When OP said, "its just now smoother so i have no idea what to do to take it off.", I took that as saying he rounded off the nut. Hence the "im gonna try hammering in a 14mm to get it out".
That indicates to me that he may have been using a 12 point socket insteasd of a 6 point, which is what must be used on tough nuts. If this is true, I'd suggest he gets the 15mm - 6 point socket.
Old 11-08-2015, 03:28 PM   #14
Guys its done! Here is the link to the original post where I was going to update everyone on how it sounded. Enjoy!
Borla ATAK's with Lethal Performance H-Pipe. Thoughts?
H pipe vs x pipe vs straight pipe 509pony 2005-2010 Mustang GT 100 02-15-2015 08:35 AM
Off-road x-pipe install notes and video Napoleon85 2011-2014 Mustang GT 12 07-25-2013 07:13 AM
how hard to install o/r x pipe? how much to get x pipe install? MustangForEver 2011-2014 Mustang GT 9 02-05-2013 07:01 PM
Header and x pipe install! Benzo 2011-2014 Mustang GT 50 11-30-2011 04:01 PM
need help with x pipe install ordotrio 1996-2004 Mustang GT 1 08-02-2009 07:37 PM
05:04 PM
