BBK or Airaid??? - Mustang Evolution
Old 11-12-2015, 06:15 PM   #1
BBK or Airaid???
thinking of cai but don't know which is better for my 2013 v6 performance package stang. Also is there any other types that are better?
sterlinggrey is offline   Reply With Quote
Old 11-12-2015, 06:16 PM   #2
natestang07's Avatar
It basically all comes down to looks.
Old 11-12-2015, 06:16 PM   #3
DiESeven's Avatar
I like JLT.
Old 11-12-2015, 06:22 PM   #4
Kevin.Cook
Guest
Posts: n/a
If you got the money, get the Steeda one and wait till you get a tuner to put it on.
Old 11-12-2015, 06:30 PM   #5
Voltwings's Avatar
Read this. Maybe by the time you're done we'll be finished with the write up haha.
Age Old question of CAI
Old 11-12-2015, 06:36 PM   #6
Hampton CIT's Avatar
With CAIs, if it's not a larger diameter tube so much that it requires a new MAF sensor you aren't moving but that much more air. For most of what's left, it's more about looks, sound and price. I have the Airraid here. Looking back, I wish I would have gotten one with an aluminum intake tube. +1 on Kevin's remarks, you'll see more increase with a tuner to make the most out of it. Volt however speaks the gospel.
2016 Premium Eco w/ PP - Roush Quarter Window Scoops, Side Scoops, Rear Spoiler; Modded GT Mesh Grilles; FP Strut Tower Brace; Eibach Pro-Kit Springs; Steeda IRS Bushings; BMR Billet Delrin/Spherical Vertical Links; Mishimoto Oil Separator; MAPerformance CAI; Mishimoto Intercooler/Aluminum Charge Pipes; Turbosmart Kompact Dual Port BOV; Turbosmart IWG75 Wastegate (10 PSI); Mishimoto Coolant Tank; JLT Engine Cover; Mishimoto Downpipe with modded MBRP XP Catbacks for TRUE 3" exhaust from turbo to tips; Drilled/Slotted Brake Rotors
Hampton CIT is offline   Reply With Quote
Old 11-12-2015, 06:44 PM   #7
Kevin.Cook
Guest
Posts: n/a
My last post was just to appease you. But if you really want my honest opinion, get the airaid modular intake tube and an aFe drop in filter. That will run you about $170 or so. Then save what you have leftover for an SCT4 tuner from AM or something.
Old 11-12-2015, 08:02 PM   #8
JOberlander's Avatar
You best performance gain for the money will always be gears. For well under $1000, you can dramatically improve your car's acceleration. The V6's top gear maxxes out at about 210mph at redline. It's just way too tall. The optimal gear for that car with manual transmisison is 3.73. That brings the top speed in 6th gear down to about 150-160mph, which is the actual maximum of the car.
NOTE - when changing gears, be aware that the safe limit for your driveshaft drops closer to the 112mph limiter. Very tall gears in a V6 also requires a driveshaft swap if you intend to race it or have disabled the limiter.
OTOH, if you just drive it around town, no worries there...
JOberlander is offline   Reply With Quote
Old 11-12-2015, 08:19 PM   #9
Diehard's Avatar
The "aFe drop in filter" hasn't been Voltwings/Sakib tested yet.
Old 11-12-2015, 11:02 PM   #10
Fintile's Avatar
Stock...keep your stock and get a datalog tune.
Sent from my QTAQZ3 using Mustang Evolution mobile app
“anybody driving slower than you is an idiot, and anyone going faster than you is a maniac”
-George Carlin
Fintile is offline   Reply With Quote
Old 11-13-2015, 07:09 AM   #11
I may be wrong but I think he asked --------
BBK or Airaid???
As far as performance is concerned ===Either one because they don't really work any or much at all better then the stock air cleaner in normal driving.
But when you floor it either one will give such a great sound you will have an orgasm in both ears. They do make accelerating that good with the sound they produce.
I personally like the looks and fit of the AirAid better then the BBK . Both are fine filters and neither one will hurt your car so just get the one you like the looks of .
Stock compare to AirAid
Name:	Strut bar front.JPG
ID:	193536   Click image for larger version
Old 11-14-2015, 01:08 AM   #12
moto113's Avatar
Go with the roush CAI. That's honestly where it's all at
moto113 is offline   Reply With Quote
Old 11-14-2015, 08:08 AM   #13
Voltwings's Avatar
Which of course is a rebranded air raid...
Old 11-14-2015, 09:19 AM   #14
Kevin.Cook
Guest
Posts: n/a
I was about to say that same thing. LOL
Old 11-14-2015, 11:14 AM   #15
moto113's Avatar
Yea but I had the air raid and just didn't feel any difference just the sound. But with the roush I noticed the sound and an actual low end difference even before the MPT tune...I think roush gets the best batch of air raids stuff, at least looked like the inside was smoother and a lot nicer then the air raid...just looked and and felt better put together
Old 11-14-2015, 11:43 AM   #16
Kevin.Cook
Guest
Posts: n/a
Probably just more refined so there are some differences between the two. I cant imagine they could resell the same exact product and other companies be ok with it. Most places change it JUST enough to get by.
Old 11-14-2015, 07:18 PM   #17
Mean14's Avatar
Personally, I like AirAid because the tubing is plastic. The BBK one has an aluminum tube which tends to retain heat more than plastic would. Hotter air = less power. Also, the BBK one looks cheap to me. Like something you'd get off of eBay. The AirAid has the looks, power, and design IMO.
Procharged D1 on 12Lbs, MPT 93 Tune, 73mm BBK TB, Ported Upper/Lower Intakes, BBK Shorty Headers, FRPP Cut n Clamp Xpipe, Borla S-Types, Barton Short Shifter/Blowfish Bracket, SS Clutch Line, Whiteline Trans Bushing, One Piece Driveshaft, Front and Rear Tower Brace, Whiteline Front and Rear Sway Bars, Whiteline Adj LCAs/Adj UCA, BMR Relocation Brackets, BMR adj Panhard Bar, Eibach Sportlines, FRPP Dampers, 20" AMRs, 3.55 gears, Brembos
Mean14 is offline   Reply With Quote
Old 11-14-2015, 07:36 PM   #18
Leave the stocker in, take the money you would have spent on it and get a gym membership and workout clothes. Your performance will be the same.
Old 11-14-2015, 09:33 PM   #19
Cooolbreeez's Avatar
Don't listen to Scotty he's from jersey, next thing he'll tell you to do is get a tan and it will make your car faster. Lol
Cooolbreeez is offline   Reply With Quote
Old 11-14-2015, 09:47 PM   #20
Fintile's Avatar
I keep saying this to people, no one listens.
The air isn't in the intake long enough to lose more than 1 maybe 2 degrees before entering the combustion chamber which is hotter than the air in the engine bay.
BBK I think has better design, then again I don't feel a difference between my ebay intake and my airaid.
-George Carlin
Old 11-15-2015, 07:22 AM   #21
VIG
VIG's Avatar
Region: Delaware
It would be nice if someone did a comprehensive write up on cold air intakes.
IG: workshardplayshard
VIG is offline   Reply With Quote
Old 11-15-2015, 08:04 AM   #22
Fintile's Avatar
I know right?
-George Carlin
Old 11-15-2015, 08:18 AM   #23
Yes, But you already know that someone is
The only problem I can foresee is the report will be so scientific and complicated, You won't know anymore then before.
Old 11-15-2015, 03:00 PM   #24
Diehard's Avatar
Here's a sneak preview...
Old 11-15-2015, 07:16 PM   #25
Ha! Ha! Ha! Ha!
Good one,
Old 11-15-2015, 08:24 PM   #26
Voltwings's Avatar
Originally Posted by Fintile View Post
I know right?
You guys got Jokes lol.
Old 11-15-2015, 08:30 PM   #27
Voltwings's Avatar
I know right?
Old 11-15-2015, 09:09 PM   #28
Fintile's Avatar
LOL
-George Carlin
Old 11-16-2015, 05:05 AM   #29
VIG
VIG's Avatar
Region: Delaware
Haha 😉
Old 11-16-2015, 06:46 AM   #30
Lol I'm saving that pic.
Airaid Throttle Body Spacer/ Airaid CAI Question MP0986 2011-2014 V6 Mustang 39 09-17-2015 08:21 AM
Compatibility between BBK 73mm increased throttle body & AIRAID POWERAID Spacer grom80 2011-2014 V6 Mustang 17 08-14-2014 11:22 AM
BBK vs. Airaid CAI for 2010 GT mustangman5345 2011-2014 Mustang GT 50 03-18-2014 04:13 PM
CAI help!! (BBK or Airaid) MVP u eNVy ME 2005-2010 Mustang GT 17 08-09-2013 01:49 AM
07:16 AM
