Power Stop Z23 Brakes - Mustang Evolution
Old 11-16-2015, 04:41 PM   #1
PaPa's Avatar
OK , I'm seeking some help on this. I installed the Power Stop Brakes on my pony this week end. I had no issues with the pads or return clips. They did not seem to be dragging to me when I spun the wheel prior to lowering the jack. My concern is after the first ride across town it seems like they are producing a lot of heat... I'm not on the brakes hard. Will this get better with time ?
PaPa is offline   Reply With Quote
Old 11-16-2015, 04:51 PM   #2
Voltwings's Avatar
Why do you think they're producing a lot of heat, and how are you getting this information?
Old 11-16-2015, 05:29 PM   #3
PaPa's Avatar
Well when I got out of the car they were smelling like heat and when I got close to the wheel I could feel what I thought was excessive heat... Also a terrible amount of brake dust. It was almost like you had been on a circle track for a 50 lap race... I have looked at them today after work and all the spring clips are still in place... If I get off early tomorrow I'm going to clean the brake dust off and take her for another ride just to see..
Old 11-16-2015, 06:14 PM   #4
Voltwings's Avatar
Did you seat the pads? You mentioned your first drive across town is when you found this "issue."
Old 11-16-2015, 06:26 PM   #5
PaPa's Avatar
Yes I went through the pad break in process..
---------- Post added at 08:26 PM ---------- Previous post was at 08:25 PM ----------
Sorry, the recommended seating process
Old 11-16-2015, 07:51 PM   #6
Diehard's Avatar
I think the question is, was a brake dragging while/after you went for your ride.
Was the heat you felt limited to one wheel?
Your description makes it sound pretty darn hot.
When you take another short ride, try coming to ALMOST a full stop but allowing it to roll very slowly. If a brake is dragging you should be able to feel it stop you when you're barely moving.
Being a 2014, I wouldn't think it would be a sticky piston or sticky slider bolt. But I would try to rule out dragging pads first.
Old 11-16-2015, 08:01 PM   #7
Tyoung68's Avatar
Mine smelled for a bit after I installed them on my jeep. But if your concerned about it then jack up the car and try to spin the tires
Old 11-17-2015, 02:07 AM   #8
PaPa's Avatar
Thanks for the ideas, I will try it again today or tomorrow keeping all suggestions in my mind. Will let u know the out come. I don't drive this car everyday. I was attracted to the Power Stop so the rotors would not rust maybe as bad. I guess if they stop better they may build a little heat. After the ride , It was all the brake dust on both front wheels that got my attention first and then looking closer was when I discovered what I thought was excessive heat.
Old 11-17-2015, 02:12 AM   #9
Tyoung68's Avatar
My rear pads was getting hung up on my jeep and turned the rotor blueish, might wanna just do a visual before anything
Old 11-17-2015, 09:20 AM   #10
PaPa's Avatar
Great idea, Thanks Ty
Old 11-18-2015, 07:45 AM   #11
Power Stop Discs
Powers Stops are thicker than stock or other types. This creates heat, they will swell and create more heat. I do not know what brake pads you are using, but, you need to use their pads to go with their rotors. I have had this problem with my Fox Body and my F150. Eventually, they warp from the heat.
Michael Bettis is offline   Reply With Quote
Old 11-18-2015, 10:50 AM   #12
Diehard's Avatar
The OP said, "They did not seem to be dragging to me when I spun the wheel prior to lowering the jack."
One would think some dragging would show up at this time.
Old 11-18-2015, 10:57 AM   #13
Strange Mud's Avatar
w/o insulting.....was the heat/dust from the bedding in (seating) process? That will build up lots of heat & dust.
Old 11-18-2015, 11:12 AM   #14
PaPa's Avatar
I hope that's the case mud. I used the shoes & rotors that were in the kit. When I return from this trucking trip Im going to jack it up and make sure nothing's dragging. Clean the brake dust off and go again. Will let u know. THANKS
Old 11-20-2015, 01:57 PM   #15
PaPa's Avatar
Update, So I get in from work today and go for a ride and a few stops about 10-15 miles. Get home and can lay my hand on both rear rotors and the right front. But when I got to the left front it was really hot. Jacked it up and it is dragging on something. I'm going to let it cool down and take it apart in the morning and see what's up. Later
Old 11-20-2015, 03:47 PM   #16
Kevin.Cook
Guest
Posts: n/a
I have the Powerstop kit on my 2014 and the pads or rotors have been noisy for the past couple of months. Unfortunately, my wife primarily drives the car so I don't get much time in it anymore. Which is why I haven't checked it out yet. I did mention it to Alex but it is difficult finding time as it is for the 2011.
Old 11-20-2015, 03:58 PM   #17
PaPa's Avatar
Good luck with that noise. Yep I have a problem with time myself. Mostly gone during the week. I installed the power stop brakes last weekend. Got something dragging on the left front. Going to ck it out in the morning. I had to scrape the paint from the back of the shoes on the rear to get the calipers back on . It's like the pads are almost to thick . But anyway not having any problem except that left front which I intend to cure that tomorrow ..
Old 11-21-2015, 11:08 AM   #18
PaPa's Avatar
Smile Final Analysis
Final Analysis, This morning I put the car on jack stands and removed both front wheels. After checking the install on both wheels I found that (1) my left front rotor was .007 thicker than the right. (2) This along with the thick black paint that's on the back of the pads was the reason for my left front getting hot. I had to wire brush the paint from the back of the pads to get some free spin in my left front wheel. I also had to do the same to even get the rear calipers on. The Power Stop brakes were just a tight fit for me but all is well now. Also not trying to insult A/M but Summit has the set for $ 289. if anyone is interested...Thanks for all who helped...
Old 11-22-2015, 10:04 AM   #19
PaPa's Avatar
Just 4U
Power stop brakes? Tyoung68 The Bar 12 10-10-2014 01:38 PM
Brakes won't stop squealing KARgt13 2011-2014 Mustang GT 13 07-31-2014 04:49 PM
Svt power!cant stop the bit of the snake VENOMOUS ONE General Mustang Discussion 11 03-22-2011 06:27 PM
Electronic Wedge brakes gonna change the way we stop Zim The Bar 3 11-11-2006 06:27 PM
Ah!ah! Stop! Stop It!!! chips The Bar 21 09-24-2004 05:09 PM
02:26 AM
