Barton short throw shifter - Mustang Evolution
Old 11-16-2015, 05:21 PM   #1
Cool Barton short throw shifter
Hi all
I'm thinking about buying the barton with 2post bracket for my 2013, my question is is it ideal for daily driving? also does it eliminate the sloppy ness of the stock shifter, such as 1-2 sound like a clunk or the 2-3 sometimes misses, and the 3-4 sometimes sounds loud when shifting at 3k. thanks
tlebron20 is offline   Reply With Quote
Old 11-16-2015, 06:18 PM   #2
Voltwings's Avatar
I loved my Barton shifter. It cleans up the shifting a lot, especially with the two post. The Barton is amazing when you're driving hard, there's the slightest resistance to putting the gear in, and then it basically just sucks it in, super smooth. So, when you're driving hard and driving with a purpose its very nice and crisp, but sometimes after a long day at work that little extra oomph to get into gear can be a bit much. I never contemplated going back to stock, it was never that bad, but it was a comment i made more than once.
Old 11-16-2015, 06:20 PM   #3
Hampton CIT's Avatar
There is a bit of a notchy feel to it but for my part with mine (Barton shifter and two post bracket) there is no comparison and I'm glad I upgraded.
2016 Premium Eco w/ PP - Roush Quarter Window Scoops, Side Scoops, Rear Spoiler; Modded GT Mesh Grilles; FP Strut Tower Brace; Eibach Pro-Kit Springs; Steeda IRS Bushings; BMR Billet Delrin/Spherical Vertical Links; Mishimoto Oil Separator; MAPerformance CAI; Mishimoto Intercooler/Aluminum Charge Pipes; Turbosmart Kompact Dual Port BOV; Turbosmart IWG75 Wastegate (10 PSI); Mishimoto Coolant Tank; JLT Engine Cover; Mishimoto Downpipe with modded MBRP XP Catbacks for TRUE 3" exhaust from turbo to tips; Drilled/Slotted Brake Rotors
Hampton CIT is offline   Reply With Quote
Old 11-17-2015, 01:12 AM   #4
oxford5pointoh's Avatar
Just do it. Worth every penny
Old 11-17-2015, 10:23 PM   #5
Mean14's Avatar
Top five best mods I've done. You won't be disappointed.
Procharged D1 on 12Lbs, MPT 93 Tune, 73mm BBK TB, Ported Upper/Lower Intakes, BBK Shorty Headers, FRPP Cut n Clamp Xpipe, Borla S-Types, Barton Short Shifter/Blowfish Bracket, SS Clutch Line, Whiteline Trans Bushing, One Piece Driveshaft, Front and Rear Tower Brace, Whiteline Front and Rear Sway Bars, Whiteline Adj LCAs/Adj UCA, BMR Relocation Brackets, BMR adj Panhard Bar, Eibach Sportlines, FRPP Dampers, 20" AMRs, 3.55 gears, Brembos
Mean14 is offline   Reply With Quote
Old 11-19-2015, 05:52 AM   #6
I've got the Barton and the BlowFish ( street version) ... shifter is better than stock no doubts about that, but with the solid trans mount- it rattles. Tore the dash apart looking for that sound, and it came down to the shifter. Called Barton and they are aware of the issue, told me how to fix it by filling the shifter tube with grease . That was a temp fix as the grease wears away... I finally fixed it 90% of the way by putting a sliver of foam inside the spring that operates the reverse push down. It's quite now, except for really hard pulls, I will still get a little rattle around 3500rpm. If you're not picky no worries, but if you are... just something to think about with the above combination.
Ppkonablue12 is offline   Reply With Quote
Old 11-19-2015, 07:14 AM   #7
Sterlingbeast5.0's Avatar
I was driving down the street shifting and my Barton snapped in half. Had to pull over and take off center console goof around to get home. Loving my MGW though!! If dont wanna spring for that it is supposed to be good according to most. I have pics and all.
Barton shifter snaps in half??!!!??
Hurst billet shifter plus two or Barton short throw shifter?? hdez41 2011-2014 Mustang GT 25 01-26-2015 09:01 PM
Barton short throw shifter 2013mustang5.0 2011-2014 Mustang GT 78 05-27-2013 02:25 PM
For Sale: SR Short Throw Shifter W/ Barton Bracket SilverBullet12 Mustang Parts for Sale and Wanted 4 02-09-2013 01:16 PM
Barton Short Throw Shifter PBrown92 2011-2014 V6 Mustang 2 12-11-2012 03:10 PM
MGW vs Barton Short Throw Shifter Brock23 2011-2014 Mustang GT 26 10-26-2012 04:21 PM
04:40 AM
