Help! ABS and Advancetrac problems! - Mustang Evolution
Old 11-26-2015, 10:56 PM   #1
I seem to be having some serious problems. When it rains, my ABS begins to make my brake pedal stiffen and pulsate, and even my engine will hesitate for up to 2 to 4 minutes, and then 'service advancetrac' lights come on, and the ABS is disabled and all other symptoms dissappears. Is there a way to fix this? Should the ABS be permenantly disabled (if possible), or is there any other solutions.? I have a 2012 V6, with automatic transmission. Thanks in advance!
melwana is offline   Reply With Quote
Old 11-27-2015, 01:06 PM   #2
Strange Mud's Avatar
I'm assuming driving slow when it shouldn't be engaging...if so I would check the wheel speed sensors/esp the connectors. That is thinking rain/wet is a good clue.
Old 11-27-2015, 03:13 PM   #3
I have had the wheel speed sensors all checked. All appear to be working properly.
Old 11-28-2015, 07:30 AM   #4
could you go into more detail on when it happens gas/brake/turn/etc/how often?
Old 11-28-2015, 10:38 AM   #5
jande063's Avatar
Plus one on the sensors. This looks like a case of intermittent signal loss between a sensor and the abs module. If the sensors look good, find someone with a good scan tool (not sure if a flash tuner can access other modules on the can bus, but I have used a friend's solus ultra to get that same data from my car) and record the data from the abs inputs while driving. Look for any data loss, or weird spikes or drops that the car does not physically exhibit. If any are seen, focus all efforts on the corresponding corner.
2014 Mustang V6-Built to run TTB, CAM-C, and ESP
Proving to my fellow racers that the disdain that some GT drivers have for V6 drivers is unfounded, one results archive at a time since 2013.
jande063 is offline   Reply With Quote
Old 11-28-2015, 10:58 AM   #6
thelastsumurai's Avatar
Are all your tires the same size? What fault codes are you getting? How much tread on your tires? If your hydroplaning you could get pulsating when braking.
'16 Eco-Boost Premium, White, Performance Pkg, 6R80 (again), Pwr Ebony Lthr with Nether Region Cooling, Adaptive Cruise Control, Enhanced Security Pkg., Reverse Park Assist., Big Worm OTT Graphix.
2014 GT Premium 200A, Black on black , leather , 6R80, Nav, Security. Pro Cal, HT catback exhaust 12.54@112
thelastsumurai is offline   Reply With Quote
Abs rear to non abs rear? misterpancho95 Pre-2005 V6 Mustang 0 01-21-2015 09:29 AM
Staggered Wheel sizes and ABS/AdvanceTrac? ArtU Mustang Wheels & Tires 6 03-10-2014 12:52 PM
Difference with advancetrac and sport mode Maverick2004054 2011-2014 Mustang GT 11 02-07-2013 03:33 PM
2011 mustang gt advancetrac Jack Israelyan 2011-2014 Mustang GT 16 02-06-2012 07:34 PM
abs on non abs sledgehammer General Mustang Discussion 4 01-28-2010 11:30 PM
02:20 PM
