effect of wheel size on performance - Mustang Evolution
Old 11-29-2015, 02:51 AM   #1
Location: Camp Pendleton North (San Clemente/Orange County
Once i bought my 19" staggered tires i felt as if i slowed my car down significantly like if i tried to floor it from a stop id rip my drivetrain apart, an it got me thinking maybe its too much wheel an tire for the car (using the mickey thompson street tires) i tried looking into the performance difference between 17 18 and 19 inch, as well as tire size and i havent had much luck.
for starters i havent checked if the total wheel diameter between the stock and new 19in wheels with mickey thompsons are actually the same, or really looked at the weight comparison for rotational mass difference.
Im not talking about cornering ability or handling but is there a difference in acceleration and overall speed performance between the 18 and 19's thats worth a swap? just using the 18 and 19 as a refrence considering those are the two AM offers the most options for. (however i did notice when reading through a lot of guys with FI 4 cylinders perfered 17in rims with street tires for performance DD)
swhitfield2013 is offline   Reply With Quote
Old 11-29-2015, 03:57 AM   #2
Siber Express's Avatar
I have 275/40 19's on all 4 corners of mine in the Ford Racing Boss 302's wheels, the biggest think I noticed was a slight drop in MPG with more rubber on the road, but they make up for it with much better handling.
Go make a quick trip to Elsinore across Ortega Highway and see how it does
Old 11-29-2015, 04:40 AM   #3
It's not so much the larger diameter wheel but generally when you go up in wheel diameter and width you are adding a fair amount of weight. While it may seem small since wheels are rotating mass it's even more critical. This is one of the big reasons I am keeping my stock 17s although I may consider going up to a set of 18x8s. Although not the best looking rims the 225s do complement the stock performance the best IMO.
StarzTA17 is offline   Reply With Quote
Old 11-29-2015, 08:46 AM   #4
Fintile's Avatar
Likewise, I really love the look of 20" wheels on our cars but my 18" allow for up to a 255 tire and too be honest o don't think anything wider is going to help me in any way on the streets. If you drag a lot then great it will help. You also want to look at the weight of each wheels as Starz is saying. It's critical on your acceleration.
“anybody driving slower than you is an idiot, and anyone going faster than you is a maniac”
-George Carlin
Fintile is offline   Reply With Quote
Old 11-29-2015, 09:12 AM   #5
Voltwings's Avatar
Really everyone here has already answered your questions, i would just like to tack on a bit.
1. Assuming you did get a combination that is taller than stock, you have effectively added more gear. For example, if you still have 2.73s and add a taller tire you may now have a 2.70, or 2.65 for example. That may be a bit of an exaggeration, i havent actually bothered to do the math, but you get the idea.
2. Also, as someone mentioned, the added weight. That weight is rotational so it will make every part of driving your car harder, acceleration, stopping, turning. Another thing to consider though is you've now moved a large majority of that weight into both a wider arc (17" diameter to 19") as well as further from the center point (the hub). Both of those factors as well make it harder to cope with the additional weight.
We had a thread on it a while back, and i cant quite remember what it was called, but there were some very good links in there discussing this. I was quoting just the rule of thumb that i had heard that "1 lb of rotational is about the same as 4 lbs of static weight," but some of the links we found proved otherwise. Maybe someone will remember what thread that was, but im drawing a blank.
Old 11-29-2015, 10:36 AM   #6
VIG
VIG's Avatar
Region: Delaware
For me, I was actually able to make going from 18s to 19s lighter and smaller diameter which really helped.
I went with the 19" premium GT rims and continental contipro 255/40/19s. I was able to shave ~5 lbs per wheel and they're almost 1" smaller in diameter.
I forget exactly how much it shaved off in the 1/4 mile, but it was noticeable.
IG: workshardplayshard
VIG is offline   Reply With Quote
Old 11-29-2015, 07:05 PM   #7
Thank you I really appreciate the help with the questions once again I I think I will look into downsizing to 18's possibly right now I have the 19in staggered setup with Mikey Thompson tires and a 4.10 different ratio with the exact lsd, I just ordered a set of 3.55's since I plan on supercharging in the near future, also the 4.10 makes first gear pretty useless for the most part thanks for the advice though it's much appreciated
Sent from my E5306 using Mustang Evolution mobile app
Old 11-29-2015, 07:07 PM   #8
I've got my old stock wheels in storage right now I'll have to take a look at diameter an weight as well as my old 2 piece driveshaft and compare that to the new stuff I'll post it on this thread to show the difference incase anyone is interested
Old 11-29-2015, 07:10 PM   #9
Off topic but for this forum it might be a bit easier if we categorize things down even more in each forum so the parts group of the cars
ie if I'm looking for info on drivetrain I go to that section or wheels or interior etc
Might not work or be too complicated but just a thought, I did have trouble finding stuff online even when I took voltwings advice an searched in Google
"wheel size affect on performance Mustang evolution"
Old 11-29-2015, 07:56 PM   #10
Voltwings's Avatar
Use google. I typed exactly: Wheel weight performance mustangevolution
Into google and pulled up these threads, including others:
Performance Difference 19" VS. 20" Wheels?
what's the ideal wheel weight?
Wheel Weight Perform. Notes
What's the real story with wheel size and acceleration?
Does The Diameters of Rims Affect Car Performance ?
Old 12-02-2015, 04:17 AM   #11
audioAl's Avatar
I upgraded my 17's to 18x9" American Racing razor's helping my gear to a 2.86:1 as the height of my setup is 26 instead of 28, wheels are 24 lbs instead of 28 and I too have the 1 piece shaft by DSS 3.5" shaving 20 lbs. Also did Bassani exhaust 30 lbs vs stock mufflers @ 40 lbs apiece.
2014 DIB 3.7 "Blue Cyclone" /Sold
2016 ruby red GT 300 A with 3.55:1 gear/SVE resonator delete X-pipe/ UPR catch can/Airaid/AEM/Steeda/ BMR CB005/BMR CB006 brace/BMR cc plates/SVE springs/
Humidity and its effect of performance. Fintile 2011-2014 V6 Mustang 13 04-23-2015 07:38 AM
Weathers effect on performance Speed_Mister General Mustang Discussion 1 04-26-2013 06:25 AM
Wheel size & tire size help needed for newbie rayramos Mustang Wheels & Tires 14 09-21-2009 11:45 AM
The Ram Air Effect Myth. Dom Pre-2005 V6 Mustang 38 01-16-2007 08:56 PM
How much do Spring Insulators effect me? domin8stang Pre-2005 V6 Mustang 27 11-12-2003 10:01 PM
07:55 PM
