The key thing is understanding the difference in the tunes. A 93 tune is pushed harder than 91 because the higher octane fuel can take it. If you try running a more aggressive tune on gas that isnt up to snuff you will damage your engine.
But on the bright side, you can run 93 octane on an 87 tune safely lol. In all seriousness listen to these guys. I raced a slow maro a couple weeks back and I had the 93 tune on 87 octane. After the race I was getting gas and the car was barely turning over, also it felt like I was driving a 1997 civic. I started freaking out and my check engine light came on a few minutes later and my AFR was at 10.00 and it usually idles around 14 or 15 so I immediately cut the car off and installed the 87 tune and after the car got readjusted it finally started running normal and the check engine light went off. I will tell you this though, that was one of the scariest moments of my life.
Not 100% but you can take certain steps to make sure. For example look at exhaust bolts for signs of being recently replaced, if you buy off a forum see what the guys posts look like. Now at to be 100% sure but there are things you can do that may provide signs that the car was recently put back to stock.
you could use a good octane booster but that could get expensive but cheaper than rebuilding your engine from running the wrong gas. You can use a higher octane than tune calls for but never less
why would you want a tune that you can't get gas for? I understand if you were concerned about traveling but get it for what you can get at the local gas station.
I'm thinking this was already asked but I gotta ask myself.
Exactly. In Florida, I had a 93 tune, and an 87 tune for when I went on road trips. It came in handy on my way up here to Alaska. North Texas and Colorado had 89 at the highest. Here in Alaska, 90 is our Premium octane. :banghead:
Related Threads
Mustang Evolution Forum
2.1M posts
50.8K members
Since 2003
