traction module - Mustang Evolution
Old 12-10-2015, 04:39 PM   #1
traction module
anyone know where the advance traction and traction control module are located at?
jase33 is offline   Reply With Quote
Old 12-10-2015, 05:44 PM   #2
Ish416's Avatar
I believe it's somewhere on the rear axle.
Mine failed in my 2014 and the dealership said they had to replace a module or sensor on the rear axle.
Don't know if it's BS or not, I didn't fix it.
Old 12-11-2015, 08:48 AM   #3
Where both of your lights on when it supposably ddnt work?
Old 12-11-2015, 02:25 PM   #4
jande063's Avatar
It is part of the ABS module. This is one reason why when you install the M-2353-CA module, you no longer have access to those features. It also takes inputs from the PCM, and steering rack. Also input from yaw and roll sensors and the wheels speed sensors.
What they replaced on Ish's axle was likely a wheel speed sensor. If one is bad, the whole system will function improperly.
2014 Mustang V6-Built to run TTB, CAM-C, and ESP
Proving to my fellow racers that the disdain that some GT drivers have for V6 drivers is unfounded, one results archive at a time since 2013.
jande063 is offline   Reply With Quote
Old 12-11-2015, 04:29 PM   #5
Ish416's Avatar
Yes... abs, traction control and stability control all failed at once.
Old 12-11-2015, 07:54 PM   #6
my abs ain't on ..just my traction control ..and traction light are on...it happened when my aluminum driveshaft from American muscle blew up...now I have my car running again but the lights are on still...
Old 12-11-2015, 09:02 PM   #7
jande063's Avatar
Have someone with a good scanner, such as an actual ford scan tool, or a recently updated solus, check to make sure that you have data coming through from the rear wheel speed sensors.
The physical location of the ABS module is that it attaches to the abs pump in the front passenger side of the engine bay, in case you were wondering.
Old 12-12-2015, 05:45 PM   #8
O ok..sounds good...thank you...ill get that checked out..
Old 12-15-2015, 03:22 PM   #9
pwrby4d's Avatar
the abs traction control / advancetrac - module will be here.
btw procharger is being installed now...
Heres a How too if you need to unplug it and want to try to reset it.
With the engine running, cut the wheel all the way hard left and turn the car off and remove key. Reach into the wheel well, and find the speed sensor cable(there's only one wire, and one hose). Then, follow it back to where it goes behind the fender liner. just on the other side of the fender liner, there's a plug/connector. Thats the one you are looking for.
Maybe unplug it and plug it back on or see if it came loose.
If anyone wanted to run hard on a track day and not want to have the computer get involved then this would be the route to take but just be sure to secure the cable so that it doesn't break off.
Chris
pwrby4d is offline   Reply With Quote
Old 12-15-2015, 04:03 PM   #10
jande063's Avatar
I do not recommend disabling the ABS in this car for a track day. Buggy as it is, when it works, it is so good that we get hit by a power to weight penalty for using it. Most people will not have a problem with it reactivating advancetrac or triggering ice mode, unless you are fast on corner entry and exit.
Old 12-15-2015, 05:25 PM   #11
pwrby4d's Avatar
I don't either but just in case anyone wants to get all Gittin Jr. and go drifting that would be how to do it. Heheheh
JET module mitch Pre-2005 V6 Mustang 5 06-18-2007 02:12 PM
Sct Flash Tuner or JET Power Module Chip PB&J Pre-2005 V6 Mustang 3 11-21-2006 07:30 PM
Parting out? I need GEM module I_luv_HP&trq Pre-2005 V6 Mustang 0 01-07-2006 05:32 PM
Venom 400 Control Module greenpony02 Pre-2005 V6 Mustang 1 03-15-2004 03:24 PM
VENON400 Performance Module..How much HP/Torque gain REALLY? yellowgt6 Pre-2005 V6 Mustang 8 10-08-2003 10:29 PM
10:41 PM
