Need help fast! - Mustang Evolution
Old 12-10-2015, 07:45 PM   #1
mustang ninja's Avatar
Need help fast!
Hello everyone. So here's my problem. My car is making a loud squealing/whistling sound starting in 2nd gear and thru out the rest(4,5,& sometimes 6). When I push in the clutch it dies down some but, you can still hear it. I think it is either the alternator or maybe something to do with the air conditioning. I'm not sure, I'm not a mechanic. I was wondering if anyone else had this problem before? I really want my car to run right. I miss driving it on the nice weekends but, I won't drive it until it gets fixed. I would really appreciate any input from anyone. Thanks.
mustang ninja is offline   Reply With Quote
Old 12-10-2015, 08:36 PM   #2
tym_v6's Avatar
More info would help. Where is the sound coming from? Front of engine (might be a belt) or transmission (might be flywheel or pressure plate).
Old 12-11-2015, 03:06 AM   #3
Abominable Mustang
WhoDat's Avatar
Region: Alaska
If it happens in some gears but not others, I don't think it would be the alternator or a/c. Something like the alternator is driven by your accessory belt which turns based off engine rpm.
2012 Kona Blue 3.7L V6:
Old 12-11-2015, 07:17 AM   #4
Belt pulley tensioner probably needs replacing. Bearing is worn out.
Old 12-11-2015, 01:35 PM   #5
GRREEN's Avatar
If pushing in the clutch pedal changes the sound, I would suspect something wrong in the clutch area, but start off by removing the drive belt and see if the noise goes away. If it does , you have a bad pulley on the front of the engine somewhere or a noisy drive belt. Keep in mind if it is belt noise the most common cause is a leaking water pump getting coolant on the belt.
GRREEN is offline   Reply With Quote
Old 12-12-2015, 04:40 PM   #6
It is the tensioner and belt. Taking my car this week to get it fixed. Thanks for the replies. I hope that nothing else messes up, the warranty is over in may 2016. Hood scoop and tail wing are next on the list. See ya.
Fast (Fast n Ferious) Brett Greene The Bar 0 10-13-2011 07:46 AM
fast and furious 3- fast food run Kyle The Bar 7 04-13-2006 12:56 AM
I need Chemistry help...and fast. Dom The Bar 12 08-31-2004 09:48 PM
need help fast!! can't find the plug a1yola Pre-2005 V6 Mustang 2 10-14-2003 05:30 AM
snapped bolt with underdrive pulley, need help and fast 062stang Pre-2005 V6 Mustang 0 07-16-2003 12:46 AM
10:03 PM
