What is this? - Mustang Evolution
Old 12-12-2015, 12:51 PM   #1
Entities19's Avatar
What is this?
It's on the drivers side next to the downstream O2 sensor. I'm putting spark plug non foulers on the O2 sensor due to my high flow cats, but I'm trying to figure out what this is, because with the non foulers the back of the O2 sensor is hitting this thing, it goes in but it sits right on the object in the picture
Name:	ImageUploadedByMustang Evolution1449949735.927460.jpg
Entities19 is offline   Reply With Quote
Old 12-13-2015, 09:17 PM   #2
You talking about the driveshaft?
ALLYDRIVER1 is offline   Reply With Quote
Old 12-13-2015, 11:22 PM   #3
oxford5pointoh's Avatar
Looks like some sort of shift linkage or solenoid.
Driveshaft? Mmmmm I don't think so
Old 12-14-2015, 06:06 AM   #4
tym_v6's Avatar
I don't see any driveshaft in that picture. Looks like a boot over some sort of line or linkage.
Old 12-14-2015, 06:09 AM   #5
Maybe the emergency brake cable?
Ppkonablue12 is offline   Reply With Quote
Old 12-14-2015, 11:08 AM   #6
Mean14's Avatar
Procharged D1 on 12Lbs, MPT 93 Tune, 73mm BBK TB, Ported Upper/Lower Intakes, BBK Shorty Headers, FRPP Cut n Clamp Xpipe, Borla S-Types, Barton Short Shifter/Blowfish Bracket, SS Clutch Line, Whiteline Trans Bushing, One Piece Driveshaft, Front and Rear Tower Brace, Whiteline Front and Rear Sway Bars, Whiteline Adj LCAs/Adj UCA, BMR Relocation Brackets, BMR adj Panhard Bar, Eibach Sportlines, FRPP Dampers, 20" AMRs, 3.55 gears, Brembos
Mean14 is offline   Reply With Quote
Old 12-14-2015, 07:50 PM   #7
Diehard's Avatar
Attachment 194761
Do you have a manual or auto?
Old 12-14-2015, 07:55 PM   #8
That's an auto. Manual doesn't have a trans pan like that
Old 12-15-2015, 08:45 AM   #9
VIG
VIG's Avatar
Region: Delaware
Attachment 194761
It's the muffler bearing.
IG: the_notorious_vig_
IG: workshardplayshard
VIG is offline   Reply With Quote
Old 12-15-2015, 01:42 PM   #10
Diehard's Avatar
Shift control cable for automatics. Goes from shifter to transmission.
Had to crawl under car to find out.
It looks a lot bigger in the picture then it is.
Old 12-15-2015, 07:11 PM   #11
GHEEZE, WAS A JOKE FELLOWS
10:04 AM
