Dynotech One piece driveshaft - Mustang Evolution
Old 12-14-2015, 06:43 PM   #1
Does anyone know of any issues with a Dynotech driveshaft? There is currently one for sale on eBay for $500 with free shipping.
mwirtz11 is offline   Reply With Quote
Old 12-14-2015, 07:38 PM   #2
14mustang's Avatar
I have one and it is good. It clicks a little at low speed from the joint. Other than that it is smooth and makes a noticeable difference
Sent from my HTC One M9 using Mustang Evolution mobile app
14mustang is offline   Reply With Quote
Old 12-14-2015, 08:53 PM   #3
Thanks! I am debating on putting a Procharger on it in the spring and knew I would need a new driveshaft if I was going to do it.
Old 12-20-2015, 07:17 PM   #4
My car has 3.31 gears, and I am experiencing the 2500-3000 RPM deceleration vibration issue. The Dynotech driveshaft I tried made it worse and drone a little bit. However, I suspect this is just a rare case.
Other than that, it seems to be a quality piece. I heard many good things about Dynotech as well.
2014 Mustang 3.7L cyclone engine with 6 spd transmission. Mods: 93 MPT Race Tune, 3.31 Gears, Airaid CAI, BBK Shorty Ceramic Headers, Corsa Sport axle backs, Strut Tower Brace, Steeda rear seat X-brace, BMR Rear LCAs, GT wheels, MGW race spec shifter, Passenger seat delete, spare tire delete, Moroso battery relocation to the trunk.
liv4spd is offline   Reply With Quote
Old 12-21-2015, 09:40 AM   #5
Mean14's Avatar
The decal vibration is normal with a one piece on a six speed. This is because of the dual mass flywheel. I have the same thing on mine as well. Thought the DS was out of balance but if it was, it would get worse at higher speeds and this isn't the case. I've had the dynotech for about a year and I love it. No issues at al
Procharged D1 on 12Lbs, MPT 93 Tune, 73mm BBK TB, Ported Upper/Lower Intakes, BBK Shorty Headers, FRPP Cut n Clamp Xpipe, Borla S-Types, Barton Short Shifter/Blowfish Bracket, SS Clutch Line, Whiteline Trans Bushing, One Piece Driveshaft, Front and Rear Tower Brace, Whiteline Front and Rear Sway Bars, Whiteline Adj LCAs/Adj UCA, BMR Relocation Brackets, BMR adj Panhard Bar, Eibach Sportlines, FRPP Dampers, 20" AMRs, 3.55 gears, Brembos
Mean14 is offline   Reply With Quote
Old 12-21-2015, 10:12 AM   #6
14mustang's Avatar
The one piece of all brands will increase the noise of the vibration. The two piece absorbed a lot of it. I have a slight clicking from mine at very low speeds but it is the nature of the beast when you go for performance over comfort.
Old 12-21-2015, 07:14 PM   #7
tym_v6's Avatar
I have a DSS one-piece aluminum shaft and also have an increase in noise from the rear end (it's a thin-walled hollow tube, so it amplifies any noises that are already there). That said, the shaft is smooth as glass at all speeds with my auto.
dynotech 4 aluminium driveshaft vinnysantoni 2011-2014 V6 Mustang 18 06-02-2015 12:44 AM
Used Al Dynotech Driveshaft Question DiESeven 2011-2014 V6 Mustang 13 05-05-2015 09:51 PM
For Sale: 11-14 Dynotech aluminum driveshaft Cold Silence Mustang Parts for Sale and Wanted 7 05-04-2015 04:22 PM
Opinions between Driveshaft Shop and Dynotech 1 piece MOOSEDAWG29 2011-2014 Mustang GT 61 05-04-2015 07:32 AM
Dynotech Aluminum Driveshaft Installed Scotty 1 Roush Mustang 11 05-07-2014 07:04 AM
06:41 AM
