Supercharger? - Mustang Evolution
Old 12-22-2015, 06:48 PM   #1
asvpedwin's Avatar
Supercharger?
Will a 2013 GT500 Supercharger fit a 2014 Mustang v6 ?
If so what do i need to modify or buy for it to work?
asvpedwin is offline   Reply With Quote
Old 12-22-2015, 07:02 PM   #2
20prima10's Avatar
Oh boy. Who wants to touch this one. I'm calling on the all mighty voltwings.
2013 pp mca 3.7 glass roof
2.5% dl tinted windows
Bbk shortys
20"resonators
Roush ab.
Bama/mpt tunes
More coming visually for now.
20prima10 is offline   Reply With Quote
Old 12-22-2015, 07:08 PM   #3
Diehard's Avatar
No way!
And I know nothing about them.
Old 12-22-2015, 07:08 PM   #4
DiESeven's Avatar
Ummmm........ 🤔
Instagram: @v6beast
Old 12-22-2015, 07:10 PM   #5
Rapinator126's Avatar
Supercharger?
Yup and the headers will also
🍼and 🌽 fed coyote.
Old 12-22-2015, 07:15 PM   #6
20prima10's Avatar
Since voltwings has not gotten to this yet. To put it short.
No
The supercharger from a 5.0 will not work on a 3.7
There are a few different company's online that do produce full complete kits for the 3.7 however
Paxton and pro charger are generally the two used if I'm not mistaken.
These kits are not cheap and they should be tuned by a dyno runner who specializes in the 3.7.
There's a lot and a lot of things that can go wrong it these are not 100% tuned safely for the motor. While these motors will take a lot of abuse. A bad tune will fry the motor asap. Just ask alrefire. He fried a motor due to bad tune on a lpf turbo kit. Big difference between turbos and superchargers.
However a bad tune will produce the same results in both cases.
Bbk shortys
20"resonators
Roush ab.
Bama/mpt tunes
---------- Post added at 02:15 AM ---------- Previous post was at 02:15 AM ----------
Rap I think he's new to the forum. Play nicely lol.
Old 12-22-2015, 07:16 PM   #7
Diehard's Avatar
🍼and 🌽 fed coyote.
Yeah... with a 4 to 3 adapter.LOL
Old 12-22-2015, 07:18 PM   #8
20prima10's Avatar
Lol
Old 12-22-2015, 07:20 PM   #9
oxford5pointoh's Avatar
Like a glove bro!
Old 12-22-2015, 07:23 PM   #10
20prima10's Avatar
I give up. Lol. U guys are either going to cost him a lot of money or scare him away.
Old 12-22-2015, 07:32 PM   #11
asvpedwin's Avatar
Just wondering, this guy selling the supercharger said it will fit with an adaptor. Knew it was fishy just wanted to make sure hehe
Old 12-22-2015, 07:34 PM   #12
Supercharger?
If the adaptor is an engine swap then yes it will fit.
Pick your poison.
Old 12-22-2015, 07:43 PM   #13
asvpedwin's Avatar
Pick your poison.
Haha
Old 12-22-2015, 07:56 PM   #14
A Centrifugal supercharger would be compatible with your car.
Pick your poison.
Old 12-22-2015, 08:14 PM   #15
Fintile's Avatar
Pick your poison.
Would be better than trying to mess with boost on a car that was not ment for it.
“anybody driving slower than you is an idiot, and anyone going faster than you is a maniac”
-George Carlin
Fintile is offline   Reply With Quote
Old 12-22-2015, 08:37 PM   #16
superdrift's Avatar
Is there a roots style supercharger for the 3.7l?
superdrift is offline   Reply With Quote
Old 12-22-2015, 09:11 PM   #17
Voltwings's Avatar
No roots or Twin screw blower will fit this car. The 5.x motors have a 90* separation between the banks, the 3.7 only has 60*, there physically isnt enough room. I feel like we should have covered that enough times for it to be common knowledge by this point lol.
Old 12-22-2015, 11:09 PM   #18
jande063's Avatar
I am going to be the ******* engineer in the room by saying the following.
There IS a way to make that supercharger work on the 3.7, but it involves a LOT of custom designed components. First, vertical clearance must be addressed. You have two options, look for room at the top by redesigning the hood with a higher cowl for extra top clearance. Option two is to convert the engine to a dry sump oiling system with a remote reservoir, and lower the engine by the height of the oil pan (the transmission pan and cooling fins may need redesign for clearance purposes, this will require a new shift linkage and transmission rear mount, and possibly a true two piece driveshaft depending on final angle, and may still require a higher hood cowl, and is not inexpensive).
Once the clearance has been created, then you need to design a mounting bracket for the compressor (simple).
Now for the bit that is really complicated. You have to design and build your own intake plenum and runners. It would take me months of design, prototyping, and testing to get this to flow properly, and package correctly.
Belt path is inconsequential, but me being me, I do like to overcomplicate things, and I would not want to have the boost at all times. To allow for this, I would either find or design a clutched pulley that is electronically controlled.
I have covered a few of the basic design challenges involved with this project (this is by no means a comprehensive list, but rather an overview of some major issues you will have to troubleshoot). Bottom line is that while it is doable (in all honesty, few things are not doable), it is prohibitively expensive.
2014 Mustang V6-Built to run TTB, CAM-C, and ESP
Proving to my fellow racers that the disdain that some GT drivers have for V6 drivers is unfounded, one results archive at a time since 2013.
jande063 is offline   Reply With Quote
Old 12-22-2015, 11:13 PM   #19
Ubnbit's Avatar
Or you could just buy it, send it here and I'll test it out! Just playin bro, kinda.
Old 12-23-2015, 07:47 AM   #20
Voltwings's Avatar
Wastegate. K.I.S.S
Old 12-23-2015, 07:50 AM   #21
20prima10's Avatar
Waste gates are the easy road. Why not use and electronic clutch Pully. Makes sense to me.
Slap some fairy dust in the intake while your at it
Old 12-23-2015, 07:51 AM   #22
Voltwings's Avatar
Mercedes has a few, and they're buggy, but as long as we're living in fantasy land we may as well.
Old 12-23-2015, 07:54 AM   #23
Cooolbreeez's Avatar
Did you find it on Craigslist? I saw one on the local craigslist here, probably the same one you saw.
Cooolbreeez is offline   Reply With Quote
Old 12-24-2015, 11:43 AM   #24
Location: Camp Pendleton North (San Clemente/Orange County
When I was at a shop doing my exhaust I had a mechanic tell me I should put a twin screw on I told him it'd be a pain in the *** cause how narrow the engine is he simple said cut a big *** hole in the hood like a muscle car and plop that baby on there, although it sounds kinda nuts it would be pretty funny to have a v6 with a supercharger and intake scoop coming out of the hood, also probably piss off a lot of classics fans
Sent from my E5306 using Mustang Evolution mobile app
swhitfield2013 is offline   Reply With Quote
Old 12-24-2015, 11:46 AM   #25
Also I think super six motorsports announced they were finishing up on a new plenum for the 3.7 if I'm not mistaken? I've heard of the idea of using the ginetta g55 intake (bad idea) but seems like those are options other than the centerfugal supercharger
Old 12-24-2015, 09:47 PM   #26
mustang ninja's Avatar
Pro charger would be the best plan if you have $5500.00 just lying around.
mustang ninja is offline   Reply With Quote
Old 12-24-2015, 09:48 PM   #27
Spray it. Or turbo. Leave the procharger at the store.
Come to Houston and for $5,500 I will have your car ALOT faster then the same amount of $ for a procharger.
🍼and 🌽 fed coyote.
Old 12-24-2015, 10:41 PM   #28
Thank God super six motorsports is 30 minutes away lol. I'm going to try and get a nitrous kit installed soon. But serious question, can I spray and turbo at the same time because super six has different forging packages for turbo and supercharge/nitrous?
2013 mustang v6 premium package
Powder coated gold metallic wheels
Bama tune
Quarter window louvers
2.73 gears manual
2008 fz1
Chris44117 is offline   Reply With Quote
Old 12-26-2015, 02:48 PM   #29
Eric e's Avatar
Actually there is a guy working on making the adapter to fit a roots sc on this engine. He's still testing and figuring some stuff out but he says once he has it complete he will sell kits
Ig: 3.7_THOR
2011 3.7 mustang
Eric e is offline   Reply With Quote
Old 12-26-2015, 02:53 PM   #30
JimC's Avatar
1
I think that you will be the first one to try boost plus nitrous. I will be watching to see how you fare. The 4.0 couldn't handle it, many tried only to blow up.
JimC is offline   Reply With Quote
Old 12-26-2015, 08:17 PM   #31
No reason you can't have nitrous and a turbo and it's actually pretty common on cars running larger turbos to help compensate for turbo lag. Just make sure the engine can handle the power.
StarzTA17 is offline   Reply With Quote
Old 12-26-2015, 08:47 PM   #32
Worked for these guys.
http://youtu.be/VcuXLuUI8wg
Pick your poison.
Old 12-27-2015, 08:44 AM   #33
Abominable Mustang
WhoDat's Avatar
Region: Alaska
Definitely not the first. Killer6 was turbo'ed and spraying a 100shot pretty successfully if I remember correctly.
Sent from my HTC Desire 610 using Mustang Evolution mobile app
2012 Kona Blue 3.7L V6:
Old 12-27-2015, 09:26 AM   #34
JimC's Avatar
I don't think he was on a stock engine though.
Sent from my SM-T217S using Tapatalk
Old 12-27-2015, 01:19 PM   #35
Voltwings's Avatar
Cylinder pressure is cylinder pressure, regardless of where it comes from.
If a 3.7 is safe to say 600 whp for the sake of example, you can get there with any combination: 450 whp from turbo and 150 from nitrous, 500 whp from turbo and 100 from nitrous, 575 whp from turbo and 25 whp from nitrous.... it makes no difference what you run to get to a certain power level, a motor is going to let go when it does regardless of what got it there.
Root style Supercharger vs Centrifugal Supercharger jackiegnat 2015 Mustang GT 12 03-27-2015 11:05 AM
Next Gen Electric Supercharger??? Rellik Pre-2005 V6 Mustang 31 10-13-2003 07:03 AM
supercharger el cheapo Pre-2005 V6 Mustang 0 08-20-2003 10:34 PM
$200+ complete supercharger, help Stang01 Pre-2005 V6 Mustang 3 07-20-2003 04:07 PM
Supercharger or Nitrous? ERICK Pre-2005 V6 Mustang 8 05-12-2003 02:41 PM
10:10 PM
