Axleback install on jack stands - Mustang Evolution
Old 12-26-2015, 06:48 PM   #1
Gumbus's Avatar
I'm going to be installing the borla atak axlebacks tonight, but I only have one jack stand. Is it ok to just jack one side up at a time?
2013 mustang v6 premium
Gumbus is offline   Reply With Quote
Old 12-26-2015, 06:50 PM   #2
Zombiefro's Avatar
Shouldn't be a problem, it's a pretty quick job anyways
Zombiefro is offline   Reply With Quote
Old 12-26-2015, 06:51 PM   #3
Gumbus's Avatar
Where do you suggest putting the jack stand?
Old 12-26-2015, 07:34 PM   #4
Camboss123's Avatar
Name:	ImageUploadedByMustang Evolution1451180066.740537.jpg
Camboss123 is offline   Reply With Quote
Old 12-26-2015, 08:04 PM   #5
oxfordwhite's Avatar
Under the axle close to the wheel. Make sure to chock your wheels so she can't roll.
oxfordwhite is offline   Reply With Quote
Old 12-26-2015, 09:35 PM   #6
Gumbus's Avatar
Stock v6 exhaust is pretty worthless right?
Old 12-26-2015, 09:43 PM   #7
DiESeven's Avatar
You can't give it away even if your life depended on it.
Old 12-26-2015, 09:53 PM   #8
Gumbus's Avatar
Ok, Amy tips on installing the axlebacks? We are attempting to do it with jacks at the moment. We got everything but the innermost hanger off and can't seem to get it loose
Old 12-27-2015, 12:02 AM   #9
tym_v6's Avatar
Please tell me you're not under a car that's only supported by a jack (vs. a jack stand)! I once saw a guy doing an oil change on a Jeep with thing supported by a single jack under the transmission...he's lucky he didn't get his head squashed like a grape.
Old 12-27-2015, 12:22 AM   #10
Gumbus's Avatar
I meant to say without jacks. We are just under the car
Old 12-27-2015, 12:24 AM   #11
tym_v6's Avatar
Whew! Autocorrect fail?
Old 12-27-2015, 12:25 AM   #12
Gumbus's Avatar
Probably so. We got the stock axlebacks off. We just can't get the new one on now
Old 12-27-2015, 05:10 AM   #13
RJ13GT's Avatar
I backed my car onto ramps when i changed mine.
Sent from my SCH-I545 using Tapatalk
2013 5.0, Black, Auto, Procharger P1SC stg 2, 4.13'' pulley(8 psi), JMS bap, 3'' x pipe, Circle D 3c, Kooks axleback, BMR control arms. 593rwhp
RJ13GT is offline   Reply With Quote
Old 12-27-2015, 08:34 AM   #14
Try sliding the front hangers into place first then position connectors together then finally the rear hanger, adjust and tighten clamp.
Old 12-27-2015, 09:53 AM   #15
dj2014's Avatar
I used silicone spray on the hangers and that helped a lot.
2014 Ruby Red V6 Premium, Pony Package, Magnaflow Street Axle-backs, MMD Hood Struts, SCT X4 with Steeda lifetime tunes, Boss 302 Strut tower brace, JLT Oil Separator, OEM extended range remote start, Raxiom Navigation.
dj2014 is offline   Reply With Quote
Old 12-27-2015, 11:21 AM   #16
jayochs's Avatar
i actually used dish soap, as per Vig's suggestion. worked well, they slid in easily. only thing that sucked was drying it off once it was in the hanger....i had to wait for it to dry because it kept sliding around lmao.
2014 Ford Mustang 3.7 Premium 6-speed:
MPT Performance Tune, AM Laguna Seca Black 19" Rims, Borla Touring Axlebacks, Boss 302 Strut Tower Brace, Airaid Modular Intake Tube, aFe Pro Dry S Air Filter, Mustang GT Grille w/ Foglight Mesh, Taillight Tint, Tinted Door Ventvisors, Diode Dynamics LED's
jayochs is offline   Reply With Quote
Old 12-27-2015, 11:26 AM   #17
dj2014's Avatar
That is a better idea since the silicone spray would be there for a while. Glad you got it to work.
Old 12-27-2015, 12:59 PM   #18
Gumbus's Avatar
Would it be dangerous to drive with one stock and one atak axleback installed? I can't install the other one until tomorrow
Old 12-27-2015, 01:17 PM   #19
Location: Camp Pendleton North (San Clemente/Orange County
Not true I sold mine on here
Sent from my E5306 using Mustang Evolution mobile app
swhitfield2013 is offline   Reply With Quote
Old 12-27-2015, 01:21 PM   #20
I did my axel backs by lying on my back on a towel in a Parking lot lifting will give you more room but I'd say isn't essential, I would suggest it though maybe check to make sure your underbody is in good condition (no leaking differential case) but I'd say keep the stock just incase you sell the car you'll want to swap them before a sale
Also you can sell them I sold them on here apparently the manual axel backs have better flow than auto?
Also if you wreck your car and total it you will want to swap the stock back on to sell the aftermarket ones
Old 12-27-2015, 01:35 PM   #21
DiESeven's Avatar
Won't hurt the car at all. May just sound a little weird.
Old 12-27-2015, 04:18 PM   #22
Gumbus's Avatar
I must have been doing something wrong Bc it took forever to get the stick axleback out and get the new one in.
Old 12-27-2015, 04:35 PM   #23
oxford5pointoh's Avatar
It's way easier to unbolt the hangers and take them down with the mufflers. Then you swap the hangers over to the new mufflers and bolt it all back together. If you have a 13mm gear wrench you are golden.
Old 12-27-2015, 05:01 PM   #24
Gumbus's Avatar
That's what I ended up doing. I was using a 13mm ratchet. The problem was, when I went to put it back in place with the new axleback, it was hard to fit the ratchet in there to tighten up the bolts
Old 12-27-2015, 05:42 PM   #25
Gumbus's Avatar
Name:	ImageUploadedByMustang Evolution1451259731.952811.jpg
I wish I could get the tip to stick out further, but that's all it's giving me
Old 12-27-2015, 05:45 PM   #26
Attachment 195221
That's what she said
Old 12-27-2015, 05:46 PM   #27
Gumbus's Avatar
Hahahahhahahahahahaha also, the single hangar closest to the tip is barely in the rubber thing at all. I guess that's how it's supposed to be
Old 12-27-2015, 05:54 PM   #28
There is some play based on the over the axle pipes but for the most part that's how they should look. I also have ataks but mine are obviously for the 5.0 looks about the same
Name:	ImageUploadedByMustang Evolution1451260429.085732.jpg
If you end up doing the boss/CS diffuser it will give them a little more depth I think
Old 12-27-2015, 08:24 PM   #29
Diehard's Avatar
That's funny because she told me that's what you said.
Old 12-27-2015, 08:32 PM   #30
Gumbus's Avatar
Name:	ImageUploadedByMustang Evolution1451269912.901813.jpg
I got everything done, but for some reason the right muffler hangs down as you can see
Old 12-27-2015, 11:06 PM   #31
tym_v6's Avatar
^Sometimes one side hangs a little lower than the other...said the actress to the bishop.
Old 12-28-2015, 07:15 AM   #32
Diehard's Avatar
Attachment 195227
Try loosen the clamp enough to allow you to move the pipe up a bit, prop it a bit further than need be, to allow for spring back and retighten clamp.
Old 12-28-2015, 07:55 AM   #33
You need to loosen it and then adjust and re-tighten.
Also, go to the local autozone or wal mart or get on amazon or whatever and buy a set of ramps. If you do ANY maintenance at all on your car they are pretty much a required item.
Old 12-28-2015, 09:46 AM   #34
tym_v6's Avatar
Ramps are a must. I'm cheap, so I use a stack of 2x10s with the short edge cut on a bevel so it's easy to drive up. The cull lumber section of your local home center is your friend.
Old 12-28-2015, 10:37 AM   #35
Yep I'm going to be making my own "long ramps" for driving up onto when this 2000 is done. I'm sick of having to carefully line up a pair of 1x8s on the ramps I have and hope they don't move as I drive up.
Where to buy a good floor jack and stands? MachMan1017 General Mustang Discussion 17 03-06-2013 05:12 PM
jack stands Son_of_Zeus 2011-2014 V6 Mustang 5 08-19-2012 06:27 PM
Need help fast car on jack stands!!!! black9D5 2011-2014 Mustang GT 20 07-07-2012 11:08 AM
Jacks, jack stands and late model Mustangs CurbRash General Mustang Discussion 18 04-29-2012 09:36 PM
jack stands 04_GT 1996-2004 Mustang GT 4 10-10-2009 11:54 AM
06:07 AM
