14' V6 Performance Package PSI? - Mustang Evolution
Old 01-05-2016, 06:42 AM   #1
4lexC's Avatar
Hey guys and gals!
I have been running in my head what the LOWEST PSI number is (I.e)..25psi.. before your tpms kicks in and your indicator light comes on your dash.
Me and my buddy were trying to figure it out. I have a 2014 v6 performance package with the gunmetal 19" wheels as in the picture. Click image for larger version
Name:	ImageUploadedByMustang Evolution1452001297.694565.jpg
ID:	195476I know it's an odd question but I hope someone may know or where the info is. Thanks so much
Alex
4lexC is offline   Reply With Quote
Old 01-05-2016, 07:48 AM   #2
Diehard's Avatar
Originally Posted by 4lexC View Post
Hey guys and gals!
Me and my buddy were trying to figure it out. I have a 2014 v6 performance package with the gunmetal 19" wheels as in the picture. Attachment 195476I know it's an odd question but I hope someone may know or where the info is. Thanks so much
Alex
It is typically 25% lower than the recommended pressure.
For example, if recommended pressure is 35 PSI, the low pressure sensor would kick in at .75 x 35PSI = 26.25 psi. So it would probably be around 25 to 27 PSI depending on accuracy and sensitivity of the sensors.
Old 01-05-2016, 08:21 AM   #3
Diehard's Avatar
FYI...
A general rule of thumb for air pressure change with temperature change is 1 psi for every 10 degrees F change.
A closer approximation is 2% pressure change for every 10 degrees F change.
So if the temp dropped 40 degrees that would be 4 times 2% or .08.
0.08 x say 35 psi = 2.8 psi pressure drop
Old 01-05-2016, 05:27 PM   #4
tym_v6's Avatar
Originally Posted by Diehard View Post
FYI...
Unless you're the NFL, in which case the rules of physics are suspended.
Old 01-05-2016, 06:24 PM   #5
Diehard's Avatar
LOL...They asked me to be an expert witness but I refused. LOL
Old 01-07-2016, 06:06 AM   #6
Siber Express's Avatar
Take an air gauge and drop it down till the light comes on and check it when it does.
Old 01-07-2016, 10:57 AM   #7
iguanaman3's Avatar
You really can't do that because the light does not go out until you drive it a few miles.
iguanaman3 is offline   Reply With Quote
Old 01-07-2016, 11:42 AM   #8
Strange Mud's Avatar
drop it 5....wait a day....drop it 5.....wait a day...etc
Old 01-07-2016, 11:49 AM   #9
Diehard's Avatar
I wonder if running the engine would do it or must you actually be moving???
I'll have to check that out when I have nothing better to do.
Old 01-07-2016, 02:50 PM   #10
iguanaman3's Avatar
The manual says you need to drive it for the light to go out.
Old 01-14-2016, 06:16 PM   #11
same package in 2012 the tpsm turns the lamp on at 29 pounds every time
captchas is offline   Reply With Quote
Old 01-14-2016, 08:24 PM   #12
Diehard's Avatar
I like the system in my '11 Charger. You can view pressure in each of the 4 tires on your dash. Additionally, no reprogramming or learning when tires are rotated. The sensor in the tire communicates with the transmitter located at that location. e.g. R/F - L/F - R/R - L/R. Then the transmitter sends its signal to the dash.
Looking for a New or Used 13' V6 Premium w/ Performance Package & Comfort Package tgmeyer 2011-2014 V6 Mustang 2 10-24-2014 07:21 PM
11 psi Pro Charger citti34 Mustang Parts for Sale and Wanted 4 07-13-2004 06:55 PM
which psi u think oaktonarcher Pre-2005 V6 Mustang 8 04-12-2004 07:04 PM
9 psi super charger oaktonarcher Pre-2005 V6 Mustang 1 02-03-2004 11:45 AM
why would modest psi and 35 shot be so bad on stock motor? tire Pre-2005 V6 Mustang 14 12-21-2003 10:41 PM
04:50 PM
