2014 horrible gas mileage - Mustang Evolution
Old 01-05-2016, 06:44 AM   #1
Hi all! Just picked up a 2014 v6 with the performance pack installed. I'm only getting 25 mpg and have even tried keeping off the pedal by cruising at 55-60 mph with and without cruise control on. Seems like always getting this mpg if at 55 or going 70mph. Does anyone know for sure if the 3.31 rear and 19 inch wheels will sacrifice the mpg? Everything I searched doesn't say if so. Also, can I put on a smaller wheel for winter set for winter use tires and how does that affect speedo?
Thanks!
richny is offline   Reply With Quote
Old 01-05-2016, 06:47 AM   #2
4lexC's Avatar
I have the same package and I get roughly the same and my driving is a nice mix of city and interstate. I average (driving considerately) 24 or so but if I do all highway I get about 26-28. In just city about 18.5. Not for sure myself as I can't find anything on it.
How many miles to empty do you get in a full up?
4lexC is offline   Reply With Quote
Old 01-05-2016, 07:28 AM   #3
oxfordwhite's Avatar
We have a 2014 v6 PP. Consistently get 30 on trips @ 70mph with cruise. Live in the mountains of nor-cal, and get 24-25 in the hills. 18X9 Bullits, Nitto 255's with 2:73s
oxfordwhite is offline   Reply With Quote
Old 01-05-2016, 08:03 AM   #4
Strange Mud's Avatar
Yes they will.
2012 V6 PP. I get 21-23 mix..best ever all hwy was 26-27. It is overall OD that affects speedo I have two sets with a difference of 3/4-1" and that changes it by 2-3% not enough for me to worry about. w/o insulting air pressure?
Old 01-05-2016, 08:48 AM   #5
Diehard's Avatar
Thanks!
A smaller diameter TIRE would have the effect of increasing the final drive ratio slightly and result in a minor (possibly unnoticeable) reduction in MPG.
I emphasize TIRE as the wheel/rim size, in itself, does not affect it.
Your tire is 27" dia while the stock tire is either 27.6" or 28" both slightly taller.
So yes both the 3.31 gears as well as your 255x40R19 tires have a higher final ratio than the stock 2.73 gears and slightly larger dia tires. That's what makes it quicker than stock.
Also, keep in mind that not all 3.7L engines are going to get identical mpg.
EDIT: Theoretically, you should be getting better MPG at 55 mph then at 70 mph. Also, the onboard MPG calculation seems to run on the low side, I believe. You may find you do better if you do your own calculations.
Old 01-05-2016, 09:37 AM   #6
bucko's Avatar
Ford's advertisement of MPG was based on the 2:73 gearing; 3:31's are going to lower this a bit, along with a taller tire/rim combination (larger mass to turn). May not seem like much on paper, but you are only seeing a drop of about 4 MPG. I suspect it's more due to the 3:31 gearing.
Also, I would not consider 25 MPG "horrible" gas mileage. After all, it is a Mustang, and you're supposed to have some "spirited" fun with it.
Old 01-05-2016, 10:27 AM   #7
Jon3.7's Avatar
Right foot mod....
2013 GT, A6, VMP Tuned, Lethal O/R H pipe, GT500 Mufflers
2016 EB, A6, Steeda Tuned, Steeda CAI
Jon3.7 is offline   Reply With Quote
Old 01-05-2016, 10:36 AM   #8
are you doing math or relying on car #'s? esp if you are not resetting the car's mpg readout. I'll agree with Hard you should see a real difference at slower speeds.
Old 01-05-2016, 10:45 AM   #9
Gas Mileage
I am getting about 24 MPG on the highway in the winter, and about 18 MPG in the city with the Perf Pkg 6 Spd manual.
2013 RedMustang is offline   Reply With Quote
Old 01-05-2016, 11:01 AM   #10
MustangDawg's Avatar
Just for a comparison, mine is a V6, Auto, 2.73 gears with an MPT 91 performance tune. I just did a 750 mile highway run averaging 75 mph and got 30.3 mpg. I'm currently getting 18.5 to 19.5 around town. I typically don't get too worried about my mileage cause it's a Mustang not a Honda or Toyota. I just keep an eye on the mileage as an early indicator of any issues.
2013 V6 Auto Premium | Sterling Gray | Pony/Comfort/Security Packages
Borla S-Type AB, Airaid CAI, SR Performance STB, JLT Oil Separator, MPT Tuned, MMD Classic Louvers, Roush Upper & Lower Grilles, BFGoodrich G-Force Sport Comp-2 A/S Tires, Koni STR.T Shocks & Struts, SR Performance Lowering Springs, J&M Stainless Steel Teflon Brake Lines, BMR LCAs w/Brackets, BMR Panhard Rod Support, Whiteline Adj. Panhard Bar, Ford Racing Differential Finned Cover Plate, Philips X-tremeVision LED Fog Lamps, JMS PedalMax
MustangDawg is offline   Reply With Quote
Old 01-05-2016, 11:05 AM   #11
Thanks all! That's kinda what I suspected. No, I don't use the on board readout for the calculations, I do the old school math of miles driven between fill ups.
Old 01-05-2016, 11:11 AM   #12
If you have the PP you have 3.31 gears not 2.73.
Sent from my LG-D850 using Tapatalk
2013 SGM 3.7 | MPT Tune | JBA Shorty Headers | MGW Gen 1 | Blowfish Street Bracket | 18" Charcoal AMR | FRPP 3.55 | BMR LCA | Steeda Panhard Bar | Dynotech 3.5" Driveshaft |
mariusvt is offline   Reply With Quote
Old 01-05-2016, 11:32 AM   #13
PP could mean Pony Package as well, that's what I have.
Old 01-05-2016, 11:48 AM   #14
1Mustang805's Avatar
I would be happy if I was getting 25mpg I get 14 mpg on the streets and 19mpg on highway and I think it just dropped even more since I installed my new gt500 17x9 255/50/17 wheel and tires and I only have a CAI, Flowmaster axelbacks and 87 bama tune
1Mustang805 is offline   Reply With Quote
Old 01-05-2016, 11:54 AM   #15
DiESeven's Avatar
I wouldn't exactly call 25mpg horrible...
Old 01-05-2016, 12:12 PM   #16
iguanaman3's Avatar
Certainly not for a car with over 300hp.
iguanaman3 is offline   Reply With Quote
Old 01-05-2016, 12:14 PM   #17
I bought my '14 V6 with the Performance Package new in 2014. City mileage is a bit over 18, combined about 25, and pure highway close to 28. However, the milage includes a carrying a full-size spare and wheel in the trunk, and luggage when I'm on a long distance run.
I'd check directly with Ford before switching tire sizes.
Enjoy your roadster - as someone posted above, it's a Mustang, not a Fiesta!
cheval is offline   Reply With Quote
Old 01-05-2016, 12:41 PM   #18
You are turning 500 RPM over factory on the highway at 70mph, your gas mileage will drop accordingly.
Old 01-05-2016, 03:21 PM   #19
b2673ad's Avatar
Hello
I get 24 mpg around town and have gotten as high as 30 mpg on the interstate rolling at 78.
Kevin C.
2015 Roush RS1 Premium w PP
Roush Performance upgrade-- Tinted Windows
JLT Catch Can--Ford Racing Strut Brace
Flowmaster scavenger "Y" pipe resonator delete
b2673ad is offline   Reply With Quote
Old 01-05-2016, 04:01 PM   #20
What I meant by "horrible" was getting 25mpg over the advertised 31 mpg. Everything is stock and will probably stay that way and I absolutely love the car. It is quick...very quick and the small sacrifice in mileage is worth it! This is my fifth stang ('69, '76, '77, '79, '94gt) and is the best with the '69 about equal.
Old 01-05-2016, 04:46 PM   #21
Yes! Premium Package. We have winter blend gas in Calif., so our mileage goes down in winter. I typically see a drop by 1or2 mpg.
Old 01-05-2016, 05:08 PM   #22
iamcesarmiranda's Avatar
I'm so lost rn. I have a 2013 Club of America with 2.73. I get 15.7!!!!!
Bbk intake
Bbk tb
Bbk shorty headers
Roush Axleback
91 mpt tune
Automatic
iamcesarmiranda is offline   Reply With Quote
Old 01-05-2016, 05:57 PM   #23
Colburt195's Avatar
Are you always getting on it with mostly city driving? When I run my 91 octane race tune and drive in my usual "spirited style", I get around 15 mpg in the city.
2014 Oxford White FP6 - K&N CAI, BAMA Tune, SR Strut Tower Brace, JLT Oil Separator, Barton Shifter Bracket, C&L Billet Aluminum Shift Knob, Interior LED Lighting
Colburt195 is offline   Reply With Quote
Old 01-05-2016, 06:13 PM   #24
kgallowaypa's Avatar
3.73 gears here and I mostly just do city driving...averaging 17-19 MPG haha I really dont care about MPG, the things fun
2014 Sterling Grey V6 Manual
PMods: Steeda CAI // MPT 93 Octane Tune // 3.73 Gears // Roush 4" Axelbacks // Ghost Cammed by MPT
AMods: Dome Bulbs // Mirror Covers // Hood Pin Kit // Roush Upper & Lower Grille
kgallowaypa is offline   Reply With Quote
Old 01-05-2016, 06:23 PM   #25
I also saw a 2 mpg drop on mine, always using premium, with this year's winter fuel mix. Hi way mileage went down to 24 from 26 mpg.
2012 GT 5.0 - MT82 - 3.55 rear axle ratio - Air aid CAI - Hypertech programming set to premium fuel - Borla ATAK exhaust system - BBK 90 mm TB - one piece driveshaft from DSS
*previous 2002 Trans Am GT 5.7L LS1
*previous 1994 Trans Am GT 5.7L LT1
*previous 1990 Taurus SHO 3L Yamaha Shogun
*previous : life was boring !
UP North is offline   Reply With Quote
Old 01-05-2016, 11:32 PM   #26
JOberlander's Avatar
The biggest factor is likely to be tire pressures. Keep it close to the maximum and your MPG will imporve a lot. Traction will suffer a tiny bit, though.
JOberlander is offline   Reply With Quote
Old 01-06-2016, 05:46 AM   #27
I believe tire pressure is one of the most neglected things out there. I used to be the manager at our local H-D and just about every bike that came in had incorrect tire pressure. Usually too low. I run 35psi all around. Seems to be working well where we drive and live.
Old 01-06-2016, 06:10 AM   #28
papivo's Avatar
I live right outside Philly and commute in each day. I average about 14-15MPG all city driving. I only use 86 and tires are checked once a week and topped off.
2014 V6 Convertible Ruby Red Tint, Borla S-Types
papivo is offline   Reply With Quote
Old 01-06-2016, 06:16 AM   #29
That's what the Schuylkill will do to mileage... I ****ing hate the highways around Philly, its worse than NYC sometimes.
Horrible gas mileage gasgusler2000 Mustang DIY and Technical 11 07-06-2014 09:36 PM
Horrible gas mileage nhrider 1996-2004 Mustang GT 11 04-04-2013 06:45 PM
Horrible fuel mileage Nicolosi11480 1979-1995 Mustang GT 6 07-24-2012 08:56 PM
horrible gas mileage angelofrat42 2005-2010 V6 Mustang 7 03-10-2012 10:04 AM
04:05 AM
