Suspension - Mustang Evolution
Old 01-07-2016, 05:52 PM   #1
Gumbus's Avatar
Suspension
Is there anything wrong with running just springs and a panhard bar? That's what I've been running for about 10 months and there's been some creaking in the back end lately and it's got me concerned
2013 mustang v6 premium
Gumbus is offline   Reply With Quote
Old 01-08-2016, 12:58 AM   #2
Cooolbreeez's Avatar
Maybe it's time to upgrade those shocks?
Cooolbreeez is offline   Reply With Quote
Old 01-08-2016, 06:52 AM   #3
Voltwings's Avatar
If your LCAs are still relatively parallel to the ground, then maybe not. If the body mounted side of the LCA is higher, even a little, than the axle mounted side of the LCA, then yes.
Also, what brand PHB, and did you grease the bushings when you installed it?
Old 01-08-2016, 07:17 AM   #4
Gumbus's Avatar
I was pretty naive and got the cheapest one, which was the Sr phb. And my local ford dealership installed it so idk
Old 01-08-2016, 08:26 AM   #5
Mean14's Avatar
The problem that most people don't understand when changing one or two suspension components and not the rest of them that is that it puts a lot of strain on the OEM parts. You are changing the geometry of the car and putting in stronger parts leaving a lot to be desired from the OEM stuff. If you're going to lower a vehicle the correct way, at least get a set of cc plate (or camber bolts) panhard bar, shocks/struts, and LCA relocation brackets. Eventually changing out the sway bars, ball joints, LCA + UCA, and a bumpster kit is a good idea. Again, these OEM components will wear out a lot faster than aftermarket because they are not built the the standards and quality of an aftermarket part. This is just my opinion on the matter. Also, STAY AWAY FROM THE SR SUSPENSION CRAP! Thats exactly what it is is crap. Cheaply made and not made to last. Stick with name brands such as BMR, STEEDA, or WHITELINE who actually specialize in suspension components.
Procharged D1 on 12Lbs, MPT 93 Tune, 73mm BBK TB, Ported Upper/Lower Intakes, BBK Shorty Headers, FRPP Cut n Clamp Xpipe, Borla S-Types, Barton Short Shifter/Blowfish Bracket, SS Clutch Line, Whiteline Trans Bushing, One Piece Driveshaft, Front and Rear Tower Brace, Whiteline Front and Rear Sway Bars, Whiteline Adj LCAs/Adj UCA, BMR Relocation Brackets, BMR adj Panhard Bar, Eibach Sportlines, FRPP Dampers, 20" AMRs, 3.55 gears, Brembos
Mean14 is offline   Reply With Quote
Old 01-08-2016, 09:10 AM   #6
Gumbus's Avatar
Can you install cc bolts without plates? That may be a dumb question. Another dumb question, why do the lca's need relocating?
Old 01-08-2016, 09:57 AM   #7
Mean14's Avatar
Yes. You can install camber bolts without plates. Also, I forgot to mention, if you're upgrading struts, you will need to get a set of new strut mounts preferably to gt500s. Otherwise the stock mounts will eventually start to clunk.
The job of a lower control arm is to keep the axle planted during heavy acceleration. When you lower a vehicle, you actually throw the angle of the LCA off. So instead of the LCA being pitched the correct way to keep the axle planted under acceleration, it is pitched the other way resulting in the axle actually being lifted under acceleration resulting in poor traction and wheel hop. By getting a set of relocation brackets, you are able to relocate the pitch of the LCA in order to get the correct angle angle again to keep the axle planted. The correct pitch will be determined on what you use the vehicle for. If it is your dd I would recommend a parallel setting (or something close to it preferably with slight negative angle) if you are going for a drag setup I would recommend a decent negative pitch (the rear part of the LCA that connects to the axle should be lower then the front that connects to the body.)
Hope this helps.
Old 01-08-2016, 10:05 AM   #8
Gumbus's Avatar
I understand now. So it's basically useless to get lca's without the relo. brackets on a lowered vehicle? Also, what is the job of the cc plates?
Old 01-08-2016, 10:22 AM   #9
Mean14's Avatar
These are all basic questions that can be found using google. Relocation brackets are a good idea if you are going to be beating on the car and expecting optimum performance from it. If it is your daily driver and you drive it like a grandma, then I wouldn't worry about it. But if you like to have fun, it is a good $100 investment. I would recommend BMR relocation brackets as they give you three options to choose the pitch you would like. Might as well get a good set of lower control arms while your at it because the OEM stamped metal pieces are trash and tend to flex leaving room for improvement.
As for the cc plates.. here is a link I found in 3 seconds using google...
What do caster camber plates do for my Mustang? | AmericanMuscle
Old 01-08-2016, 01:10 PM   #10
Diehard's Avatar
Here's a visual on the subject of LCA positioning.
Name:	LCA relocation bracket.jpg
Old 01-08-2016, 03:35 PM   #11
Robostang's Avatar
The LCA is what connects the body of the car to the axle and its main purpose is to push the body of the car forward.
2012 Kona Blue GT Premium 401A, Manual, 3.55, Steeda Pro-Action Shocks, Struts, Sport Springs, LCAs, Adjustable Swaybars, Adjustable Panhard Bar, BMR Relocation Brackets and Adjustable UCA, Driveshaft Shop Aluminum Drive Shaft, Airaid CAI, MGW Shifter, GT500 Axle-Backs, 3M Clear Bra and Tint, Side Window Louvers, JLT Oil Separator, Staggered MMD Zeven Wheels and Mickey Thompson Street Comp Tires, Bama 93 Race Tune
Robostang is offline   Reply With Quote
Soften up suspension: for those post suspension mods Jvibe92 2011-2014 Mustang GT 14 03-03-2015 02:05 PM
will trade fairings and lowered suspension for stock suspension vincent1 1996-2004 Mustang GT 2 06-22-2009 07:34 AM
suspension help 35thAniVertible Pre-2005 V6 Mustang 23 10-31-2003 12:54 PM
Stang Suspension Laser02 The Bar 14 10-30-2003 09:15 AM
Duals or Suspension? Killer Squirrel Pre-2005 V6 Mustang 1 05-13-2003 03:36 AM
05:29 AM
