Headlight question - Mustang Evolution
Old 01-19-2016, 03:49 PM   #1
Headlight question
Will the HID headlights (not bulbs the entire casing) fit/work on a base mustang?
(2012 V6 Mustang)
raykrieg is offline   Reply With Quote
Old 01-20-2016, 05:24 AM   #2
TrevorMCA's Avatar
If you have the whole setup, i see no reason why it wouldn't. Same car just different headlight set up that's all.
2012 Kona Blue MCA 3.7
Ford Racing Axelbacks
Airaid CAI
TrevorMCA is offline   Reply With Quote
Old 01-20-2016, 06:58 PM   #3
20prima10's Avatar
Trevor nailed it. Although if I'm not mistaken the 11/12 uses a slightly different bumper than the 13/14. I might be wrong if I am someone correct me.
20prima10 is offline   Reply With Quote
Old 01-20-2016, 08:19 PM   #4
TrevorMCA's Avatar
I think you're right. AM said the 13-14 lights wouldn't fit the housing for the 11-12
Airaid CAI
Old 01-21-2016, 08:18 AM   #5
20prima10's Avatar
I believe if you swap bumpers it will work. Not positive though. Ask around. The guys from am would be able to tell you. Maybe pm Alex or will they r always great help
Old 01-21-2016, 08:50 AM   #6
CodyC's Avatar
The exterior dimensions of both headlights (10-12 vs. 13-14) are the same. What's different are the internals and one mounting tab. The 10-12 headlights have a tab on the top that stands up and is used to mount part of the bumper. The 13-14 headlights do not have this tab. But you can still use the 13-14 headlights by coming up with a different way to support that part of the bumper, such as this:
The cut piece of metal is taking the place of the missing mounting tab in that picture.
I imagine the connectors and ballasts would need to be transferred over as well, but I can't say that with certainty.
CodyC is offline   Reply With Quote
Old 01-21-2016, 09:02 AM   #7
20prima10's Avatar
Good information. The ballast and connections definitely need to be transferred as hid lights require different things.
Headlight question Kcochran0010 Pre-2005 V6 Mustang 10 06-22-2012 12:02 PM
Headlight and center fog lights question BossFiveOh 2011-2014 Mustang GT 16 05-13-2012 08:03 AM
headlight quick and simple question eddie1 1996-2004 Mustang GT 2 06-13-2011 07:47 AM
headlight question! NotoriousSPG Pre-2005 V6 Mustang 3 07-13-2006 10:16 AM
Headlight question. Dom Mustang Audio & Video 14 03-17-2005 03:32 PM
12:21 PM
