I parked my car under a tree... - Mustang Evolution
Old 01-25-2016, 07:22 PM   #1
Stevenbones's Avatar
So I parked my car under a tree for a day and this tree s*** got all over the trunk. Any advice on how to get it off? I tried scrubbing the hell out of it when washing it but no luck.
I don't know what kind of tree it was in case some of you ask.
Thank you.
Name:	ImageUploadedByMustang Evolution1453771264.660590.jpg
ID:	196222Click image for larger version
Name:	ImageUploadedByMustang Evolution1453771279.794492.jpg
ID:	196223Click image for larger version
Name:	ImageUploadedByMustang Evolution1453771293.231137.jpg
Stevenbones is offline   Reply With Quote
Old 01-25-2016, 07:27 PM   #2
2011 Kona Blue's Avatar
Bug and tar remover. Also try magic eraser. Don't worry, it won't scratch the paint.
Non 🍼and non 🌽fed. I $uck!
Old 01-25-2016, 07:32 PM   #3
DiESeven's Avatar
Damn. That almost looks like someone ashed their cigarette over and over and over again on your car.
Old 01-25-2016, 08:00 PM   #4
I'll try this tomorrow. Thank you.
Old 01-25-2016, 08:04 PM   #5
Yeah it sucks lol hopefully I could get it all off
Old 01-25-2016, 08:32 PM   #6
Ish416's Avatar
Mine looked like that too over the summer. I had to use a clay bar to get it off.
For my issue, bug and tar remover did nothing.
Old 01-25-2016, 08:54 PM   #7
JOberlander's Avatar
The last time I got sap on my car, it took me half an hour of gently using a clay bar. It will come off. Just be patient.
JOberlander is offline   Reply With Quote
Old 01-25-2016, 08:55 PM   #8
oxfordwhite's Avatar
A little bit of diesel saturated on a soft cloth, will melt the stuff right off, then wash car. Diesel will not hurt the paint, just leaves an oily residue. We live under a bunch of Doug Firs and Oaks, at certain times of the season it can be a mess. Gone outside and the car will have a yellow fuzzy coat on.
oxfordwhite is offline   Reply With Quote
Old 01-25-2016, 09:14 PM   #9
The bug and tar remover is a hit or miss!
Old 01-25-2016, 09:57 PM   #10
+1 on the clay bar. Had similar contamination on an F150 I had and it removed it. Best to clay the entire surrounding surface/area and not just the affected spot. Do remember to wax the area immediately after to protect the paint.
Old 01-25-2016, 10:24 PM   #11
oxford5pointoh's Avatar
Clay will for sure get it off.
Vote Ox Mustang of the Year 😬👍🏻
Old 01-26-2016, 11:58 AM   #12
I went to You Tube for this problem on my wife's car. One video recommended WD-40, which quickly and easily dissolved and removed the dried sap. I also used it to get tar off the fender of my Mustang. Presto, off immediately, and no harm to either finish. Just spray it onto the sap and gently rib off with a soft cloth. You can wax over if you're concerned about the finish, but the WD-40 really did no harm.
cheval is offline   Reply With Quote
Old 01-26-2016, 12:26 PM   #13
Hi, My daughter visits all the time,every time her car is covered with pine sap. This is the worst sap to tangle with. Years ago I found Goo Off, this stuff is lethal to sap, glue, adhesives of all types. Just dampen a clean cloth, and wipe it right off. Don't douse the car and leave it ! This stuff is very strong, the smell will take your breath away. Just don't scrub it, a little elbow grease is all it takes. Comes in a bright yellow can with red letters. It's never harmed the paint on the cars I used it on.
goman is offline   Reply With Quote
Old 01-26-2016, 01:10 PM   #14
I agree with the Goo Off.
shotzie4 is offline   Reply With Quote
Old 01-26-2016, 02:57 PM   #15
3.
Yep! WD-40 works great, can't believe I'm the only one to use diesel though. Just like WD.
Very safe and no work, just melts it and wipe off.
Old 01-26-2016, 08:05 PM   #16
Diehard's Avatar
Originally Posted by oxfordwhite View Post
3.
Thought you old timers used Mystery Oil for everything. JK(I'm older than you.)
Old 01-26-2016, 10:09 PM   #17
I use Marvel Mystery on my old arthritic joints!
Old 01-27-2016, 12:25 AM   #18
Thanks for all the recommendations, everyone. I'm finally going to have some time off tomorrow to tackle this issue.
IG: @stevenbones
Old 01-27-2016, 09:41 AM   #19
thelastsumurai's Avatar
Remember the longer you wait the more the possibility of stain.. I have used Diesel on my cars for many years. Make sure you wax your car afterwards.
'16 Eco-Boost Premium, White, Performance Pkg, 6R80 (again), Pwr Ebony Lthr with Nether Region Cooling, Adaptive Cruise Control, Enhanced Security Pkg., Reverse Park Assist., Big Worm OTT Graphix.
2014 GT Premium 200A, Black on black , leather , 6R80, Nav, Security. Pro Cal, HT catback exhaust 12.54@112
thelastsumurai is offline   Reply With Quote
Old 01-27-2016, 10:50 AM   #20
jek57's Avatar
Light rubbing compound will work
jek57 is offline   Reply With Quote
Old 01-27-2016, 11:01 AM   #21
I personally would not use rubbing compound on clear coat.
Old 01-27-2016, 11:37 AM   #22
jek57's Avatar
They do make compound that is clear coat safe ..Used it before with no problem
Old 01-27-2016, 12:03 PM   #23
sid719e's Avatar
Meguiar's makes one.
http://www.meguiars.com/en/automotiv...bing-compound/
But then again, it shouldn't take a rubbing compound to get this out.
sid719e is offline   Reply With Quote
Old 01-27-2016, 08:32 PM   #24
WD-40 and some elbow grease seemed to do the trick. Thanks for the suggestions, everyone!
IG: @stevenbones
Old 01-28-2016, 06:50 AM   #25
i might be older then you at 68 .yes we have used MO on almost everything! 4 qts of mystery and 1 qt of 30w helps clean up a sludge'd motor. helps a old 4 speed shift easier, great for noisy door hinges
then MO is almost like atf which works just as well most of the time
captchas is offline   Reply With Quote
Does your anti-theft light flash when the car is parked? escottcarp 1996-2004 Mustang GT 7 12-12-2013 05:42 PM
Battery drained after 1 week parked the_stig 2011-2014 V6 Mustang 2 08-05-2012 09:35 PM
vac tree under upper intake Travis B 1979-1995 Mustang GT 3 07-29-2012 06:07 PM
parked Devil5711 2005-2010 V6 Mustang 0 01-10-2012 04:43 PM
storm+parked under tree=owned Bane- Pictures and Videos 2 06-02-2006 01:05 PM
02:31 PM
