2016 Mustang V6 won't start - Mustang Evolution
Old 01-25-2016, 08:03 PM   #1
Unhappy 2016 Mustang V6 won't start
Hi Mustang community I really need help!!!!
I Have a 2016 Mustang V6 and it won't start, when i press the puch start button the light on there starts blinking and the car turns off.
Does anyone knows how to start the car??
Anmol6412 is offline   Reply With Quote
Old 01-25-2016, 08:56 PM   #2
stangs4l1f3's Avatar
Press brake then start? That's all I can think of. If not get it checked.
stangs4l1f3 is offline   Reply With Quote
Old 01-25-2016, 09:04 PM   #3
i did press the brake but didn't work
Old 01-25-2016, 09:08 PM   #4
This is pretty basic but I assume you have the key in the area of the driver? Also if its auto make sure the car is in park.
StarzTA17 is offline   Reply With Quote
Old 01-25-2016, 09:10 PM   #5
Is this a manual or automatic transmission car? I haven't driven a 2015+ with push button start but do you need to have the hand brake engaged (for a manual car)? or in P park, not neutral for an auto car.
Old 01-25-2016, 09:10 PM   #6
oxfordwhite's Avatar
Is it auto, in park? Standard, clutch in, all the way to floor? Press and hold brake, hit start? IDK. Owners manual, trouble shooting?
oxfordwhite is offline   Reply With Quote
Old 01-25-2016, 09:13 PM   #7
Not sure how legit this is considering a 6 year old is doing the video lol but might be worth a try if nothing is working.
Old 01-25-2016, 09:17 PM   #8
It's an manual and i do press the clutch all the way in, but it still doesn't work
Old 01-25-2016, 09:51 PM   #9
NewMtang's Avatar
___________________________
Call the dealership and have it towed down and let the warranty cover it.
Old 01-25-2016, 10:35 PM   #10
iguanaman3's Avatar
Could your battery be low? My 2012 will not even try to crank if the battery is weak.
iguanaman3 is offline   Reply With Quote
Old 01-25-2016, 10:36 PM   #11
paintmann111's Avatar
This sounds like a child who wants to take his dads stang for a joy ride...
paintmann111 is offline   Reply With Quote
Old 01-26-2016, 01:54 AM   #12
bucko's Avatar
2016 = under warrantee.
Call the dealership; have the car towed (for free under warrantee) to dealership for repair.
Old 01-26-2016, 05:58 AM   #13
bamaboy2014's Avatar
If you literally just bought it just relax it's the battery, I've got 2 cars and they both went dead just from sitting on the lot. For who knows how long. If not don't freak out it has factory warranty
bamaboy2014 is offline   Reply With Quote
Old 01-26-2016, 06:53 AM   #14
RaceRed3.7's Avatar
Sounds like a PATS problem. Make sure the theft light isnt flashing, if so try the second key.
-SOLD-13.246s@107.81 RaceRed 2013 v6 Mustang, 3.73 gears, MPT 91Race Tune, Axle-Back Straight Pipe, Tower Brace, BMR LCA's, BBK Shorty Headers, BMR Relocation Brackets, Lethal Performance X-Pipe Catless.
-2008 Civic SI...
RaceRed3.7 is offline   Reply With Quote
Old 01-26-2016, 07:23 AM   #15
Like others have said, have Ford tow it to the dealer and let them deal with it. There's a warranty for a reason.
2013 SGM 3.7 | MPT Tune | JBA Shorty Headers | MGW Gen 1 | Blowfish Street Bracket | 18" Charcoal AMR | FRPP 3.55 | BMR LCA | Steeda Panhard Bar | Dynotech 3.5" Driveshaft |
mariusvt is offline   Reply With Quote
Old 01-26-2016, 11:02 AM   #16
Try your second key. See if that works. If not your dealership will fix it for free under warranty.
2013 RedMustang is offline   Reply With Quote
Old 01-26-2016, 11:39 AM   #17
scurfie's Avatar
Just as an aside, I think it's always best to park your car with the car locked too. It should turn everything off except the theft sensors and save your battery from needless drain.
scurfie is offline   Reply With Quote
Old 01-26-2016, 12:38 PM   #18
I do turn t off and lock the car always. I Will call the dealer today to have it fixed because i have tried everything and it won't start but when i press the start button the car just turns off
Old 01-26-2016, 12:47 PM   #19
Jbone007's Avatar
Sounds like the Battery, I see them jumping the cars all the time at the dealership!
Jbone007 is offline   Reply With Quote
Old 01-26-2016, 01:21 PM   #20
24kmach's Avatar
Our 2013 Ford Edge has the push button. You are saying that you push the button and it stops? That is how it works. Push to start and push again to shut the engine off. If this is not the case check the battery in the key fob. I hope this helps. They also in your packet will be a number to call for help from Ford.
24kmach is offline   Reply With Quote
Old 01-26-2016, 07:48 PM   #21
Ok so I got the car to start but now the problem is I have to press clutch and brake on hold the start button to start the car and ik it is not the right way because before i just used to press the clutch and start button to start the car. Any one knows how to get it back??
Old 01-26-2016, 08:56 PM   #22
The kid in the video said to push the clutch and brake also. Did you notice that? Go see the dealer in the morning I guess.
Old 01-27-2016, 05:46 AM   #23
scurfie's Avatar
I'm going to guess you have an issue with a sensor on one or both of your pedals. I would definitely get your car back to the dealership ASAP.
Old 01-27-2016, 06:23 AM   #24
David Young's Avatar
If i had a 2016 Mustang and it wouldn't start, i would be calling the dealer . Be sure to post back and tell us on what the dealer did to fix it.
David Young is offline   Reply With Quote
Old 01-27-2016, 07:25 AM   #25
This although It sounds like a sensor or electrical issue which is going to be hard to pin point 100% remotely
Old 01-27-2016, 08:36 AM   #26
thelastsumurai's Avatar
Let us know what happens with this problem.. I am going to buy a '16, and would like to know of any potential problems and what the fixes are. thanks
'16 Eco-Boost Premium, White, Performance Pkg, 6R80 (again), Pwr Ebony Lthr with Nether Region Cooling, Adaptive Cruise Control, Enhanced Security Pkg., Reverse Park Assist., Big Worm OTT Graphix.
2014 GT Premium 200A, Black on black , leather , 6R80, Nav, Security. Pro Cal, HT catback exhaust 12.54@112
thelastsumurai is offline   Reply With Quote
Old 01-30-2016, 10:05 PM   #27
l0rd_v8r's Avatar
You shouldn't have to press the clutch in. Put the car in neutral and press the brake and then push the button. The brake is what has to be pushed down in order to start. Unless something has changed on the 16s this is how the focus ST are.
"I have brought peace, freedom, justice, and security to my new Empire!"
―Darth Vader
l0rd_v8r is offline   Reply With Quote
TC's Stang :: 2016 Ford 2.3L Turbo equine48 Member Garages 0 01-21-2016 03:16 PM
Mustang Won't Start Please Help brad12 1979-1995 Mustang GT 7 04-15-2010 08:35 AM
2002 mustang runs great and then won't start rhonda New Member Introductions & Greetings 1 04-23-2009 08:40 PM
68 coupe 289 lights come on but won't turn over and headlights won't come on Sixty8 Coupe Classic Mustangs 2 03-07-2009 07:52 PM
my 3.8 2001 mustang won't start sahba22 Pre-2005 V6 Mustang 7 01-19-2004 03:21 PM
03:09 PM
