Weird evap failure - Mustang Evolution
Old 01-28-2016, 01:58 AM   #1
jande063's Avatar
Weird evap failure
For the last three months, I have had an intermittent evap leak. Went to the dealer (still have a warranty, might as well use it) three times in two weeks because it kept coming back. They replaced the canister (2nd visit), purge valve and solenoid (1st visit), and the line leading to intake manifold (3rd visit).
After the first visit, I noticed a louder pop from the back of the car, and filed it away as a dry sway bar bushing (that is a problem on my car). Turns out that the idiot tech disassembled my watts link, and did not reassemble it correctly, and as a result, not only was there bind, but the driver side axle clamp went through the fuel filler neck (small hole in rubber hose over axle).
The weird bit is that this should definitely result in first an incomplete for the evap system, and trigger an evap leak code, since the filler neck is federally mandated to be a monitored portion of the system. I only get a code and light VERY irregularly (1 day out of 45 gives a p0442), and the system states that it is confirmed good. Has anyone else run into anything similar?
jande063 is offline   Reply With Quote
Old 01-28-2016, 08:02 AM   #2
Siber Express's Avatar
I still need to take mine back in, they replaced the Purge valve and the code was back on before I left the dealer.
BTW that is an 8 year 80,000 mile warranty since it is Emissions.
Old 01-28-2016, 11:45 AM   #3
alrefire's Avatar
Do you get the "check fuel fill inlet" warning light as well?
I'm fixing to delete the evap canister, and I'm going to disable all the codes in my tune. This is all part of the wire tuck that Terry (TB Built) is going to do in the beginning of summer.
EVAP issuing plaguing Mustangs! fluffyGT06 2005-2010 Mustang GT 0 12-01-2011 12:48 PM
1996 Mustang V6 3.8l Evap Code xxxchaos 2.3 Mustang 0 07-30-2011 03:24 PM
1996 Mustang P1443 Evaporative Emissions (EVAP) Canister Purge (CP) Valve Brent Pre-2005 V6 Mustang 33 01-30-2011 09:32 PM
2004 GT EVAP Questions SSgt Dan 1996-2004 Mustang GT 16 09-25-2009 02:20 PM
Evap leak Small jmarcinko00gt 1996-2004 Mustang GT 6 09-03-2008 11:26 AM
10:11 AM
