Service Advancetrac and ABS lights - Mustang Evolution
Old 01-30-2016, 10:22 PM   #1
BigMike's Avatar
Tonight I was hanging out with some friends. When it was time to leave, I got in my car, turned traction control off, and started to leave. As I was pulling out, I heard a triple beep and looked down at my dash to see a message saying "Service Advancetrac." The traction control lights and ABS light also flashed with the message. Whenever I accelerate hard the message shows again. Whenever I am braking and turning at the same time it displays the message and I can feel the ABS through the pedal. Has this happened to anyone else? Does anyone know the cause or the solution? Thanks
BigMike is offline   Reply With Quote
Old 01-31-2016, 05:40 AM   #2
Strange Mud's Avatar
I would look at the wheel speed sensors....assuming it's still doing it. There have been several incidents of random doing it which is tough to find but if it's constant check the sensors
Old 01-31-2016, 03:36 PM   #3
BigMike's Avatar
Update: After driving some more this morning I realize that the light only comes on when I am turning right.
Sent from my SAMSUNG-SM-G900A using Mustang Evolution mobile app
Old 01-31-2016, 10:21 PM   #4
alrefire's Avatar
if it's kicking in randomly and making it difficult to drive, you can pull the ABS fuse until you can get it to someone who can diagnose the problem for you...
My ABS and traction control don't work (we never reprogrammed it after the tranny swap). The car is definitely a lot more fun to drive lol
Old 05-29-2016, 03:37 PM   #5
Service advancetrac
Check tire pressure make sur all 35psi
Amin bob is offline   Reply With Quote
Old 05-29-2016, 03:47 PM   #6
Sorry my English
Don't waste ur money to change ABS or anything else check ur tire pressure make sure all 35psi if it's stock rims
Old 05-29-2016, 05:44 PM   #7
Abominable Mustang
WhoDat's Avatar
Region: Alaska
Check/clean the wheel speed sensors like Strange said. If that doesn't help, disconnect the battery for 5-10 minutes and then reconnect it. That's a good start.
2012 Kona Blue 3.7L V6:
Service Advancetrac thejohncarlson 2011-2014 Mustang GT 42 12-18-2016 03:24 PM
Service Advancetrac Untamed5.0 2011-2014 Mustang GT 15 01-30-2016 07:28 AM
Help! ABS and Advancetrac problems! melwana 2011-2014 V6 Mustang 5 11-28-2015 10:58 AM
Staggered Wheel sizes and ABS/AdvanceTrac? ArtU Mustang Wheels & Tires 6 03-10-2014 12:52 PM
Advancetrac Service Light silvrbullet2012 2011-2014 V6 Mustang 12 08-09-2013 07:42 AM
11:52 AM
