Gas mileage drop - Mustang Evolution
Old 02-13-2016, 06:59 AM   #1
Gas mileage drop
Ok so I drive over 100 miles a day going back and forth to work and now have 75k on my 3.7. When I hit the 70K mark my gas mileage went down like a sack of rocks. Did anyone else have this problem? If so what did you do to fix it?
konablue912 is offline   Reply With Quote
Old 02-13-2016, 07:40 AM   #2
jek57's Avatar
I would start with a tune up new sparks plugs ,,clean the the throttle body maf sensor .At 75000 miles if the plugs never been changed that might help
jek57 is offline   Reply With Quote
Old 02-13-2016, 07:50 AM   #3
Does your state have a "winter gas" configuration? The oxygenated gas here during the winter months drops the mpg by as much as 15 to 20%.
And yes, at 75,000 miles, it's time for a tune up, regardless of the 100,000 mile claim in the owner's manual for the spark plugs. Things like a compression check or checking the output of the capacitive coils, the spark plug wiring, and the MAF could come later if the mpg does not recover after a minor tune.
Old 02-13-2016, 05:43 PM   #4
If you are in GA, I don't think you would have Winter Fuel. Spark plugs, Wires, TB Cleaning and air filter should be the first things you do.
2013 RedMustang is offline   Reply With Quote
Old 02-14-2016, 04:22 AM   #5
I pulled the OE plugs on mine at 42k and found copper tip motorcraft plugs in it.not platinum . all were well worn. never hurts to check, number 4 [ls front] is the easiest to pull and check
captchas is offline   Reply With Quote
04:52 PM
