Question on what to buy? - Mustang Evolution
Old 02-15-2016, 06:39 PM   #1
Cameron2581's Avatar
So I have a 2012 V6 Premium with the stock 17" wheels. I'm thinking of just getting some new 17's that look a little better. My question is, if I use my tires I have now, would I need to purchase new TPMS sensors or can I use the existing ones?
Cameron2581 is offline   Reply With Quote
Old 02-15-2016, 07:57 PM   #2
oxfordwhite's Avatar
Smile
You can use your TPMS sensors from your old wheels to the new wheels. You will still need to program the sensors to your car so they know where they are.
oxfordwhite is offline   Reply With Quote
Old 02-15-2016, 08:12 PM   #3
Diehard's Avatar
Side Questions
If the sensors were put back in the same location on the car, would they have to be programmed?
If they're put back in different locations, what would happen?
I would think they would just give a general low pressure alarm either way but I'm not familiar with Fords crazy system. They're already been tied into the cars computer system.
My Dodge requires no programming and tells me which tire is low regardless of it's location on the car.
Old 02-15-2016, 08:53 PM   #4
JOberlander's Avatar
The 2011-2014 V6 models were set up to use the 18" wheels from the factory. If you carefully check your speed with a GPS, you'll notice that with the 17s it runs a few percent high (IME, when it said 70 I was going ~68.5)
Switching to 18s makes everything dead-on. The suspension is also set up with the 18" in mind and works much better.
I suggest the new 15/16 GT rims. The silver and dark gray ones that come stock on them.
2015 Ford Mustang Oem 18" Magnetic Gloss Wheels With Pirelli 235/50/zr18 Tires | Mustang Forums at StangNet
I'm not selling these - It's just a good example of what they look like on these years. They look almost custom and yet people have these as take-offs all over the place for low prices. They bolt directly on.
JOberlander is offline   Reply With Quote
Old 02-15-2016, 09:02 PM   #5
I've thought about going up but I really don't wanna pay for the tires
Old 02-15-2016, 09:46 PM   #6
Also what width do I need to look for in the new rims?
Old 02-15-2016, 09:59 PM   #7
The interesting thing with the take-offs is that you can get them for typically 700-800 cash ( 17" and 18" ). You can often sell your stock rims for $150-200 or so, and that brings the new rims and tires to about the cost of new tires alone. In my experience it was that same cost and I got new rims out of it - a win-win scenario.
Old 02-15-2016, 10:35 PM   #8
Do you know what width I'd need to use the tires I have now?
Old 02-16-2016, 05:13 AM   #9
Im on the same boat. Im ordering a pair of Konigs for my 12 v6.
https://www.treaddepot.com/#!productGroup/wheels/intmb
Im getting them 18x9 i believe is the width with some Nitto tires. So now that you guys say that, Im guessing a tune will not be necessary for the new size? When I order tunes it always asks for wheel size and i choose stock which would be 17".
Sorry dont mean to highjack your thread xD but i guess this info could be useful for both of us? hehe
martinez8191 is offline   Reply With Quote
Old 02-16-2016, 06:55 AM   #10
Waylap1's Avatar
Region: New Hampshire
Do it right or you will just wish you did every time you see other Mustangs with larger nicer wheels with wider tires.
YES it will take longer to save the money for a whole new set of wheels AND new tires since most likely you would go larger if money wasn't an issue. I've had a 2011 and now a 2014 and I don't know why you guys are talking about programming the tpms!.... Mine have connected all by themselves every time on both and it doesn't matter where you put them.
Why not make a decision to mod your Mustang with the parts, wheels, tires etc that REALLY makes it your dream car and then STICK to that commitment even when you have to wait longer to save the money.
Just putting on same diameter wheels that have a different design so you can still use your current dinky size tires to save money isn't really what you want is it? If it kinda isn't.....you will always wish you did it right the first time when you see yours and Then you see someone else's that gets your attention. It's like plasti-dipping your wheels for a "better" look. Skip all the boy racer, hood rat mods and go big boy.
Waylap1 is offline   Reply With Quote
Old 02-16-2016, 08:16 AM   #11
Cooolbreeez's Avatar
I didn't need to program my tpms either, they synced right up when I put the new wheels and tires on by themselves. I've rotated them too with no problem either. I think some 17's would look good, I like they way they look with all the side wall. Although if I was buying new 17" wheels I wouldn't buy the same width as factory wheels just to use the same tires. I would definitely go wider. If the factory 17's on my car would have sat out closer to the fender I would have liked them better. I think they sit too tucked inside the fender from factory.
Cooolbreeez is offline   Reply With Quote
Old 02-16-2016, 08:52 AM   #12
Diehard's Avatar
According to my info the 2012 V6 with the standard 17" wheel was a 235/55R17 X 8" wide with 48mm offset.
When looking at possible effects on your speedometer, it's not the wheel size but the tire size. In your case, assuming it's as I stated above, it's about 27.2"dia.
Old 02-16-2016, 09:09 AM   #13
Diehard's Avatar
Same size wheels you have now- 8". Why not just look to confirm your current wheel size? Should be able to find it on the inboard side of your wheel.
Could go to 8.5" if you wanted to.
For example, this one is an 18" dia X 8" wide with a 55mm offset.
Old 02-16-2016, 12:46 PM   #14
Yes, you guys are right, you most likely wont have to reprogram your TPMS when using your old ones. If you get a fault, that's when you would have to reprogram. this only happens rarely. Ones on our Mustang don't seem to be as sensitive as the ones on our 300.
Old 02-16-2016, 01:57 PM   #15
Well my ultimate question is, what width new wheels should I get that will fit the tires I have now??
Old 02-16-2016, 02:26 PM   #16
Abominable Mustang
WhoDat's Avatar
Region: Alaska
Dude. Diehard have you a pretty good answer like two posts above. Should be able to look on the inside of one of the wheel spokes.
2012 Kona Blue 3.7L V6:
65 coup 69 mach 1 To buy or not to buy? Booner170 Classic Mustangs 42 12-15-2012 01:19 PM
Rebuilt Title 2001 Cobra : TO BUY OR NOT TO BUY FordAddict SVT Mustang 20 07-16-2012 10:32 PM
Mustang GT Insurance? Buy or no buy? HELP? gail General Car Discussion 2 12-16-2011 12:45 PM
If i buy a 1967 mustang fastback body from year one do i have to buy a frame? cingeswiella Classic Mustangs 2 08-25-2009 10:06 PM
12:16 AM
