Why is it so hard to find OEM wheel weight?? - Mustang Evolution
Old 02-17-2016, 12:40 PM   #1
Hawkstang's Avatar
Region: Iowa
So I just got an OUTSTANDING deal on a set of silver GT style wheels from AM. They arrived Monday and looked perfect, minus one that is being replaced from shipping damage. AM doesn't list wheel weights either, which drives me crazy since unsprung wheel weight makes a very big difference in performance.
For every 1 pound of unsprung wheel weight (only at the rear axle on our cars) is equal to 10 pounds of actual weight on your car. So if you go from 36 pound wheels to 29 pound wheels you just reduced 140 pounds from your Mustang. Sweet huh?
So anyway I weighed the new wheels and they come in a 29 pounds each. Looking at the stock wheels and rotating them, I'm going to guess anywhere from 32-38 pounds.
I've searched all over google but with no luck, so if anyone can give advice where to find the weight of the 19" PP wheels for the 2014 mustang please lmk.
Hawkstang is offline   Reply With Quote
Old 02-17-2016, 07:41 PM   #2
Diehard's Avatar
AM does list wheel weights on some of their tires. You should try asking them.
Here's a little something from the following source.
The Effects of Rotational Inertia on Automotive Acceleration
"Shaving a pound from your tires is equivalent to shaving at most 2 pounds of non-rotating weight. That's PER TIRE, so a pound off each tire could worth close to 8 pounds of weight reduction. For wheels, the multiplier is closer to 1.6, so saving 5 pounds per wheel (20 total) would feel like a static weight reduction of 32 pounds. For brake discs, it can be as low as 1.2. Regardless of the equivalent weight ratio, you're best off reducing weight as much as possible, as you might expect."
I have found many statements on this subject of equivalent weights and they vary from 1.5 lbs per 1 lb rotational weight to 6 lbs / lb to 10 lbs per lb. So I guess you can believe whatever one you want.
I did find a couple of forum people that said the PP wheels were around 26 to 27 lbs.
Old 02-17-2016, 08:28 PM   #3
Hawkstang's Avatar
Region: Iowa
I asked AM and the response I got was "around 30 pounds". As for the stock PP wheels I will be shocked if they are under 30. I've bought a lot if wheels in my time and stock wheels are typically heavy compared to after market. I plan on weighing one when I get them off so we shall see.
As for the unsprung weight difference, Im inclined to believe the 1=10 rule, beings I had put 10 pound heavier wheels on my CTS and could absolutely feel a difference when accelarating.
I guess I will wait til next week to find out the weight dif.
Old 02-18-2016, 07:55 AM   #4
Voltwings's Avatar
GT 19 x 9 with the stock 255 is 59 lbs. That will change a little depending on the tire, but thats factory wheel + tire weight.
Old 02-18-2016, 08:27 AM   #5
Hawkstang's Avatar
Region: Iowa
Thanks Volt. Im going to start calling you the Science Guy. Lol
Do you know the wheel weight of the 19x8.5 PP wheels without the tire? If you figure that out Ill give you two gold stars!!
Old 02-18-2016, 09:35 AM   #6
Diehard's Avatar
I have the 19x8.5 PP wheels with the OE 255/40 Goodyear Eagle F1 Supercar tires in my shed and just weighed them on a bathroom scale. Total was 57 lbs.
Tire Rack says the tires are 26 lbs. so that leaves 31 lbs for the wheel.
Plus or minus a bit for bathroom scale accuracy.
Old 02-18-2016, 10:24 AM   #7
Hawkstang's Avatar
Region: Iowa
Booyah... Thanks bud!
Old 02-18-2016, 11:35 AM   #8
thelastsumurai's Avatar
All after market knock offs from AM have been about 4 to 5 lbs over the weight of factory wheels. My own premium GT wheels 18x8. Weigh in at 28.3 lbs. the knock off I bought from AM weighed in at 32 lbs. same thing with my 11gt.
'16 Eco-Boost Premium, White, Performance Pkg, 6R80 (again), Pwr Ebony Lthr with Nether Region Cooling, Adaptive Cruise Control, Enhanced Security Pkg., Reverse Park Assist., Big Worm OTT Graphix.
2014 GT Premium 200A, Black on black , leather , 6R80, Nav, Security. Pro Cal, HT catback exhaust 12.54@112
thelastsumurai is offline   Reply With Quote
Old 02-18-2016, 02:21 PM   #9
Tire/wheel weights
Diehard Please the next time you go outside to weigh you wheels could you please wear a robe, the woman in the hood are going ballistic! Go baby!
goman is offline   Reply With Quote
Old 02-18-2016, 04:28 PM   #10
Diehard's Avatar
Sorry...Could you hear them from your house?
changed the oil from a 20 weight to 30 weight SangheiliSpecOp General Mustang Discussion 5 01-07-2016 12:14 PM
WHY WHY WHY??? Krustey Monkey General Mustang Discussion 24 08-08-2012 07:22 AM
Why is it really hard to find parts for a 1984 mustang? Chrystal General Mustang Discussion 2 12-23-2011 09:31 PM
Big problem-easy find, small problem-hard to find Dnraiders General Mustang Discussion 0 08-30-2011 11:10 AM
2003 V6 Pony Package Wheel Weight Cope Mustang Wheels & Tires 5 03-16-2008 06:57 AM
10:14 PM
