Weird TPMS thing - Mustang Evolution
Old 02-24-2016, 07:21 PM   #1
Hawkstang's Avatar
Region: Iowa
Weird TPMS thing
Okay, so I just had my new wheels mounted with new TPMS sensors, and it just occurred to me that no warning lights have went off yet. I have drove probably 30 miles so far...
Does anyone know if it takes 50 miles or something? I figured I would get a warning immediately. I bought the damn sensor set up thingy, so do I bother to do anything if no lights ever go on?
Hawkstang is offline   Reply With Quote
Old 02-24-2016, 07:27 PM   #2
If it's not warning you of low tire pressure, I probably wouldn't bother. But just to be sure, let some air out of one tire just to make sure. I've had my sensors out of my wheels for a whole year, and after just having them put back in, they worked right away.
2013 v6, performance pack, mt82 manual, MGW Race Spec shifter, SVE Drifts 19x9.5, H&R Supersport springs, Koni yellows, BMR panhard bar, adjustable UCA and LCA, shorty antenna, GT500 strut mounts, black painted roof, Roush splitters all around, GT hood and fog lights.
Josh_101 is offline   Reply With Quote
Old 02-24-2016, 07:28 PM   #3
FastFord13's Avatar
It takes some milage before it comes on.
Mine is always on now but its been 3 years lol.
Sent from the future.
Old 02-24-2016, 07:33 PM   #4
Diehard's Avatar
I had a case where I put on take-off Mustang wheels/tires and the warning light came on but went away after a day or so. No reset tool.
Personally, if you're not getting any warning lights, I'd leave it alone. I suppose, if you wanted to check to see if they were, in fact working, you could let air out of one of the tires.
Old 02-24-2016, 07:50 PM   #5
oxfordwhite's Avatar
Did you install the wheels your self or have a shop put them on? If a shop put them on for you, they probably have a tool and programmed the TPMS for you.
oxfordwhite is offline   Reply With Quote
Old 02-24-2016, 08:21 PM   #6
Siber Express's Avatar
I could go between my winter and summer wheels and never get a light.
Old 02-24-2016, 08:31 PM   #7
Cooolbreeez's Avatar
I put some new wheels, tires and tpms on from AM about 4K miles ago and no light ever came on. Installed them myself. I even took them off for a trip to California. About 1200 miles and no lights ever came on.
Cooolbreeez is offline   Reply With Quote
Old 02-24-2016, 08:33 PM   #8
No sync tool used either.
Old 02-24-2016, 08:38 PM   #9
Hawkstang's Avatar
Region: Iowa
Yeah I put the wheels on myself. Im wondering if the 2014 has some sort of auto read for the sensors?
I watched a video on how to use the tool, but I think it was a 2012 they did it on. Hell idk, I almost want to use it to make sure everything is working proper. Its the OCD in me. Lol
Old 02-25-2016, 12:20 AM   #10
iguanaman3's Avatar
Don't the 2014's tell you which tire is low? My 2012 does not. I don't see how the car could know which tire sensor was which without programming it manually when new ones were installed. Here is the link to a guide for the relearning procedure. It's on american Muscle. http://1.cdn.lib.americanmuscle.com/...structions.pdf
iguanaman3 is offline   Reply With Quote
Old 02-25-2016, 12:33 AM   #11
You shouldn't worry if it's working properly just because a dummy light never came on, what you should be doing is checking your tire pressure on a weekly basis. That's not an insult to you by the way. That's just going to give you the most bang for the buck you just spent on those new tires.
Old 02-25-2016, 04:17 AM   #12
Hawkstang's Avatar
Region: Iowa
Ive watched the process video, which is why I bought the tool and was ready to hit my brakes and turn my car off and on a hundred times. lol
And I do check my tire pressure weekly, I added that to my OCD list a long time ago. But weekly checks dont help you know you're losing air while driving know what I mean?
Im guessing the warnings will pop up today and I'll get the pleasure of going through the rediculous relearning process. Lol
Old 02-25-2016, 07:07 AM   #13
Strange Mud's Avatar
side note: If I store my set with the TPMS (I have one with & one without) in the garage it takes 15 miles or so for my warning to come one when I'm wearing the winter shoes.
Old 02-29-2016, 12:59 AM   #14
NewMtang's Avatar
Same with my sensors. Only time they went off was after a trip to the 2014 American Muscle Car Show. Turns out after I got back I was losing some air. I had run over a piece of metal used to fasten the metal plates down, so they then can pour the asphalt down. I new it was in the tire but it was about 8 inches long and there was no way to get it out of the tire with a pair of pliers. Local Tire barn pulled it out for free. Not a problem since.
I only had to use my tool to set it with the Summer tires. The Winter ones were put on and I have never had to use my tool to reset them.
Old 02-29-2016, 03:46 AM   #15
Grabber Blue5.0's Avatar
You don't need a tool because they're self learning.
Old 02-29-2016, 06:29 AM   #16
Hawkstang's Avatar
Region: Iowa
Not that I'm doubting you, but how do you know this for certain?
I went to Omaha and back this weekend and still no lights. If they are self learning Im going to be a little irritated that I bought that damn learning tool.
I guess I'll have to let some air out of my tire and see if it works.
Old 02-29-2016, 06:48 AM   #17
I've seen more folks NOT have to use the tool ie what Grabber said about self learning is what I would say too.
Old 02-29-2016, 07:32 AM   #18
Hawkstang's Avatar
Region: Iowa
Just let some air out and got the light.. Confirmed.
Now what do I do with this damn tool??
Old 02-29-2016, 08:01 AM   #19
when you put it in the classifieds (assume you can't return it) make sure to post a pic that shows item along with the piece of paper showing screen name & date
Old 02-29-2016, 08:15 AM   #20
Hawkstang's Avatar
Region: Iowa
10-4. Thanks!
Old 02-29-2016, 08:35 AM   #21
Mine is in the center console. My wheels came from Ford Racing with the sensors and the tool
Old 02-29-2016, 09:15 AM   #22
Because I'm pretty smart.
Sell it. The tool is a big ripoff that was never needed.
Old 02-29-2016, 09:28 AM   #23
Mine came with a piece of Velcro so now it is Velcroed to the inside of the glove box.
Old 02-29-2016, 02:12 PM   #24
Diehard's Avatar
I'm not doubting you, but how do you know this for certain? LOL
Old 03-01-2016, 08:09 AM   #25
I read it on the internet.
Old 03-01-2016, 08:12 AM   #26
Hawkstang's Avatar
Region: Iowa
That's very helpful lol... How do you like your 15 GT?
Old 03-01-2016, 08:46 AM   #27
I like it a lot.
Old 03-01-2016, 04:17 PM   #28
Diehard's Avatar
I was questioning how he knew he was pretty smart. So his answer was a good one.
Weird brake thing that happened RVAStang05 2005-2010 Mustang GT 0 11-12-2011 06:51 AM
TPMS Darkhorse_MD 2005-2010 Mustang GT 1 04-11-2008 09:38 AM
another weird thing on ebay oaktonarcher The Bar 13 03-06-2005 03:03 PM
OMG.. WEIRD.. so weird.. wiarumas The Bar 14 02-17-2005 12:45 PM
Im having a weird thing happen to me.... Zim The Bar 36 12-05-2003 10:21 PM
08:52 AM
