Slight sound during hard turns after Eibach rear Sway Bar Install - Mustang Evolution
Old 02-28-2016, 03:07 PM   #1
moto2000's Avatar
I just installed Eibach adjustable rear sway bars, made sure all bushing were lubed up and torqued all to spec under load.
The only issue I have, is under hard turning, I hear a slight click in the passenger side rear, almost as if something is moving around in my trunk back and forth. Its very faint and only during hard turns...
All other suspension parts are stock.
Any idea what this could be?
Thanks in advance!
moto2000 is offline   Reply With Quote
Old 02-28-2016, 03:29 PM   #2
elkoritaNAY's Avatar
U gotta put I forgot what it is but wax or something... For the "creaking noise". I had similar noise when I installed mine (front and rear). Whenever I'd go over a bump or anything, it'll creak... Not sure if it's the same or not
Flowmaster force 2 exhaust, procharger supercharger, carbon fiber dash overlay kit, modern retro shift knob, mmd hood and side scoops, classic quarter louvers, gt500 spoiler, 3.7 and pony emblems, mustang rocker stripes, eibach anti sway roll bar kit, Bbk shorty ceramic tuned headers
elkoritaNAY is offline   Reply With Quote
Old 02-28-2016, 03:36 PM   #3
moto2000's Avatar
It's fine over regular bumps including speed bumps (haven't tested on big inclines like steep driveways). But it's only reproducible when I forcefully jerk the car left and right...
Old 02-28-2016, 06:18 PM   #4
tym_v6's Avatar
Not to be insulting, but have you double checked that everything is torqued right?
Old 02-28-2016, 07:13 PM   #5
moto2000's Avatar
No insult taken! I actually have! I torqued the brackets to 52lb/ft and the end links to the body to 85lb/ft.
Old 02-28-2016, 08:24 PM   #6
moto2000's Avatar
Is there a torque spec for the hex bolts that lock the bushing of the end link that connects to the sway bar? Could it be sliding? My assumption is that it is play in the end link connecting to the body...but it is torqued...so I'm puzzled!
Old 02-28-2016, 08:27 PM   #7
Voltwings's Avatar
Honestly, i've found in situations like this the best thing to do is remove the part and see if it still does it. If it does, you can try to identify what it actually is, if it doesnt, you know the sway bar is in fact the problem, and typically just removing something and reinstalling it is enough to subdue any squeaks or creaks.
Old 02-28-2016, 09:30 PM   #8
moto2000's Avatar
I think I may have figured out the problem:
I had to order a replacement hardware kit for the rear sway bars, and it looks like they sent me the kit as described as "2005 & Up" for rear bar part #: 35101.320R.
Well my rear sway bar was designed for 2011+, it is part #: 35129.320R. So I think the end link's are slightly different. I should have realized when the provided bushings were too small!
Either way, I emailed Eibach, so hopefully they will be able to send me a new hardware kit.
Old 03-23-2016, 11:23 PM   #9
moto2000's Avatar
Quick question: When installing the endlinks to the chassis of the car, do the two supplied washers (per endlink) go on the inside of the bracket (sandwiched between the bushing and bracket), or outside touching the bolt and nut?
Old 03-25-2016, 06:55 PM   #10
tym_v6's Avatar
Pic?
Old 03-30-2016, 06:24 PM   #11
moto2000's Avatar
I found a photo with it installed and with the washer on the outside of the bracket. My kit comes with two washers. I saw a video of the installation in which he mentions that the washers should be on the inside? The problem with that, is that its already a pretty tight fit, so it would be pretty difficult to fit washers in there...but I feel like thats why I might be getting too much play/movement/clunking.
Poly bushing replacement in PH bar and sway bar rear 5LHO 2011-2014 Mustang GT 0 02-21-2015 12:38 PM
Rear sway bar relocation bracket; hard to install? jrolivo1975 General Mustang Discussion 4 04-19-2014 05:12 PM
Front end noise after sway bar install mmike87 2011-2014 Mustang GT 12 04-18-2014 01:09 PM
For a 1966 mustang, should I get a 1' sway bar or a 1' 1/8 sway bar, does it matter? Carthage Classic Mustangs 1 12-16-2011 06:37 PM
**Slight WW** Triumph the Insult Comic Dog @ American Idol **Slight WW** Seph The Bar 3 01-29-2006 02:13 PM
05:02 AM
