differential cover - Mustang Evolution
Old 03-04-2016, 10:24 AM   #1
differential cover
I want to replace my differential cove and change to royal purple gear lube. How do I know what size cover I have without getting under to measure it. It's a 2014 V6 'vert. Are the all 8.8 regardless?
Logan541 is offline   Reply With Quote
Old 03-04-2016, 10:27 AM   #2
Voltwings's Avatar
all 11+ cars have the same 8.8 rear end. Any 8.8 diff cover for those years will work. Why are you wanting a new diff cover?
Old 03-04-2016, 10:33 AM   #3
Have to take it off to drain it, so figure get a finned one and powder coat it grabber blue I cam in third at the shiners car show last time trying to move up to second or first plus the fins will cool it and make things last a bit longer I drive all my cars till the have like 250,000 or more miles on them
Old 03-04-2016, 11:40 AM   #4
Voltwings's Avatar
This is what i have. Has the ports for fill / Drain, which is kind of nice.
Ford GT500 Finned Mustang Differential Cover - 8.8 in. DR3Z4033B (86-14 V8; 11-14 V6, Excludes IRS) - Free Shipping
Old 03-04-2016, 11:49 AM   #5
paintmann111's Avatar
I paid $60 shipped for mine from Levittown Ford, shipped. Buy it here instead: http://www.fordpartsgiant.com/parts/...3z-4033-a.html
looks like most stores jacked the price.
You will also need two packs of ARP 651-1250 bolts since the cover is a different thickness and the stock bolts don't work.
They are all tapped for drain and fill plugs now. The part number I bought was DR3Z-4033-A, if you want to search google for pictures. Same. exact. cover.
paintmann111 is offline   Reply With Quote
Old 03-04-2016, 11:56 AM   #6
Voltwings's Avatar
Indeed. It is an OEM part, so if you can find it used somewhere or at a wholesale price i'd jump on it.
Old 03-04-2016, 02:36 PM   #7
smurf stang's Avatar
Got that cover also. I think I paid like $80 bucks shipped with bolts.
2016 VW GTI 2.0 Turbo
Old 03-04-2016, 02:57 PM   #8
Originally Posted by paintmann111 View Post
I paid $60 shipped for mine from Levittown Ford, shipped. Buy it here instead: DR3Z-4033-A - Genuine Ford COVER - REAR AXLE HO
Does it come with a gasket?
Old 03-04-2016, 05:55 PM   #9
Jza1736's Avatar
When i do mine i use rtv silicone. It makes a gasket.
Sent from my SM-N920P using Tapatalk
Jza1736 is offline   Reply With Quote
Old 03-04-2016, 05:58 PM   #10
Jza1736's Avatar
https://youtu.be/jIXoRbIIK_o
Here's a good video
Old 03-04-2016, 06:39 PM   #11
Robostang's Avatar
These are the parts that I used when installing this cover on my 2012 GT.
REAR COVER | Genuine Ford | DR3Z-4033-B
http://m.summitracing.com/parts/ARP-651-1250
https://lmr.com/item/LLR-F880/lubelo...l-Cover-Gasket
Amazon.com: Royal Purple 01301 Max Gear 75W-140 High Performance Synthetic Automotive Gear Oil - 1 qt.: Automotive
http://m.summitracing.com/parts/VPE-11147
2012 Kona Blue GT Premium 401A, Manual, 3.55, Steeda Pro-Action Shocks, Struts, Sport Springs, LCAs, Adjustable Swaybars, Adjustable Panhard Bar, BMR Relocation Brackets and Adjustable UCA, Driveshaft Shop Aluminum Drive Shaft, Airaid CAI, MGW Shifter, GT500 Axle-Backs, 3M Clear Bra and Tint, Side Window Louvers, JLT Oil Separator, Staggered MMD Zeven Wheels and Mickey Thompson Street Comp Tires, Bama 93 Race Tune
Robostang is offline   Reply With Quote
Old 03-04-2016, 06:51 PM   #12
Jza1736's Avatar
Get yourself a couple cans of Brake cleaner and a can of gasket remover. Makes removing the old gasket /rtv much easier.
Also a small hand pump to put the oil back in comes in handy too. I have this one:
https://www.google.com/search?q=oil+...Gcvd-QHqooqQAw
Old 03-04-2016, 07:55 PM   #13
tym_v6's Avatar
I went a slightly different direction with my diff cover: https://lmr.com/item/M4033G2/Ford-Mu...rential-Girdle.
Stupidly I didn't measure the pipe thread size for the drain plug before filling as I'd like to get a magnetic drain plug for good measure.
Old 03-08-2016, 07:45 PM   #14
Thanks for al the help guys now another question how oftn do you change that fluid?
Old 03-08-2016, 07:49 PM   #15
Jza1736's Avatar
I track mine, it gets changed every 6 track days roughly 12 hours of tracking.
Old 03-08-2016, 07:50 PM   #16
Thanks, Jza but I dont track mine
Old 03-08-2016, 08:40 PM   #17
Voltwings's Avatar
Is that with the Factory fill 75w140 + friction modifier, or do you use something lighter? I typically use redline 75w90 but wasnt 100% certain on my intervals.
Ford rates their 75w140 as a "one time" thing. Not sure how i feel about that...
Old 03-08-2016, 08:50 PM   #18
After being married twice I can you nothing lasts forever,lol
I want to swap it out with royal purple anyone got any pros or cons
Old 03-08-2016, 09:02 PM   #19
Voltwings's Avatar
I use redline or Amsoil personally. Not saying Royal Purple isnt good, but its just never been one to tickle my fancy.
Old 03-09-2016, 03:00 AM   #20
Jza1736's Avatar
I use the 75w140 no friction modifier. But i have the torsion dif. It's not needed. And i use RP
04:19 AM
