Rear end noise - Mustang Evolution
Old 03-16-2016, 12:23 PM   #1
Region: Utah
Rear end noise
I have had a noise in coming from the back of my car since purchase. It sounds like a bearing or rotor, it gets faster as the car does. It is becoming a high pitched sound at cruising speeds. I have had it to two dealer service departments, both say it is the tires..as they have unusual wear. The both say they have checked the alignment and it is good. One of the dealers replaced two of the worse tires, approx. 7000 miles ago. The car has 15600 miles on it. I believe the sound is coming from the differential but the tire wear has to be a misalignment. Any one had this problem?
Corydad is offline   Reply With Quote
Old 03-16-2016, 12:30 PM   #2
ZombieSlayer's Avatar
Well, if you had the rear tires rotated up or replaced and you still get a whine from the rear, it MAY be the differential. Not saying 100% that is what it is. But I have heard of newer Mustangs/cars coming from the dealer with some gear whine.
Have you got the car on the lift and spun the rear wheels to see if you could pin point it yourself?
Also, definitely want to make sure no brake pads or brackets are rubbing the rotor or anything.
ZombieSlayer is offline   Reply With Quote
Old 03-16-2016, 12:33 PM   #3
Region: Utah
I have not had it on a lift yet. I was trusting the dealer this time, but a lift is my next step.
How long is a mustang rear end compared to a ranger rear end. lenth meaning from tire to tire? macray33 General Mustang Discussion 1 03-14-2010 03:43 AM
Is a 1995 Mustang V6 rear end different from a 1995 Mustang V8 rear end? celyddon Pre-2005 V6 Mustang 2 08-25-2009 06:56 PM
Rear end noise??? woodly1069 Pre-2005 V6 Mustang 2 04-30-2008 07:56 AM
Rear end noise bsmith782 1996-2004 Mustang GT 31 08-23-2006 08:46 AM
rear end noise + PS favor jimmy_beaner The Bar 10 06-21-2005 12:00 AM
10:03 AM
