Hesitation on acceleration when cold 2011 v6 - Mustang Evolution
Old 03-19-2016, 07:10 PM   #1
tombrochard's Avatar
Hi guys, I'm looking for a little help figuring out an acceleration issue on my car. When it's cold it accelerates unevenly. If you mash the accelerator to the floor it moves right out, but if you give it partial throttle it stumbles a bit. Warmed up completely there's a slight stumble. The car has 62k miles and it's a manual, still using original plugs. The only mods are mufflers, BBK headers, CAI, bama tune
I've checked the map sensor and cleaned it, cleaned the throttle body, cleaned the fly by wire potentiometer under the gas pedal, removed the bama tune and reinstalled it. Clean intake filter too
Any thoughts?
2011 V6 Premium Pony Package
Bama Tunes, BBK Shorty Headers, Magnaflow Exhaust, Airaid cold air intake
Flux Capacitor with a Mr. Fusion
tombrochard is offline   Reply With Quote
Old 03-19-2016, 10:34 PM   #2
heebe_geebe's Avatar
Does running the stock tune make a difference or are the issues still there?
2014 MCOA, V6 PREMIUM, PERFORMANCE PACKAGE, COMFORT PACKAGE, SECURITY PACKAGE, DEEP IMPACT BLUE WITH SILVER CUSTOM COBRA STYLE STRIPES, AIRAID TUBE, TINTED 35%, PIONEER 8000 NEX, REAR CAMERA, BORLA TOUR AXLE BACK, K&N FILTER. JLT OIL CATCH CAN, CUSTOM MADE HOOD STRUTS, BBK SHORTY CERAMIC
heebe_geebe is offline   Reply With Quote
Old 03-20-2016, 07:01 AM   #3
My car is stock and I notice this as well, I bought it used so unfortunately don't know everything about what has been replaced for the first 39k miles of it's life. It isn't super noticeable unless you know the car well, but it is definitely there on my stock car.
javallama is offline   Reply With Quote
Old 03-20-2016, 07:40 AM   #4
Same issues with the stock tune. I'm thinking it might be an issue with a sensor somewhere, but I haven't dug into that yet. No codes from the computer either.
It seems it hesitates between 2000 and 3000 RPM
Old 03-20-2016, 07:53 AM   #5
Precisely! Like if you are rolling at mid-high twenties in third so around 2-2.2k and put the pedal down a good amount but not WOT it starts accelerating, does a buck, then continues through the rev range. Maybe it has to do with wiggle room in the transmission since it is shifting momentum so suddenly.
Old 03-20-2016, 01:10 PM   #6
Koryak's Avatar
Poor cold throttle response is a symptom of intake valve deposits in an otherwise good engine. Try a bottle of Techron, BG 44K or other gas additive than claims intake valve cleaning. Sometimes you can see this problem with changes in air/fuel ratios and fuel trim with a scan tool but fuel additives are so cheap I'd just try it first.
Koryak is offline   Reply With Quote
Old 03-20-2016, 01:33 PM   #7
Thanks for the suggestion, I will pick that up next time I am near an auto parts store
Old 03-20-2016, 01:34 PM   #8
Let us know what you find out...
Old 03-20-2016, 07:14 PM   #9
Thanks for the advice on the fuel additive, I'm going to pick it up tomorrow. I wouldn't be surprised about the deposits on the intake valves, I had the intake off last summer and there was all sorts of crap on them. I'll let you guys know how the BG 44k works. That stuff has gotten pretty good reviews from what I can see
Old 03-27-2016, 11:48 AM   #10
Hi guys, I couldn't find the BG 44 in my local auto parts store so I'll probably order it online. I did try the seafoam spray that you spray into the throttle body. Totally a pain in the *** to use because if you don't get it right in front of the throttle plate the damn stuff leaks down the air intake and all over the air filter. Once I got it situated I sprayed about three quarters of a can into the intake and let it hot soak for about 30 minutes. As soon as I started the car it clogged the O2 sensor so I had to clear out that code later on. Took it for a ride and as the instructions say drive it aggressively. It was pretty funny, the car looked like a crop duster airplane going down the road, it's all that seafoam stuff burning off I guess. Long story short the hesitation when it's cold is almost gone so I'll order the BG 44 and that should finish the job off. That's the only stuff I'm gonna use in the tank because my local ford dealership highly recommends it.
If the car still hesitates after all that I'm going to take off the intake manifold and manually spray the intake valves and manifold. I did that last year and it certainly was an oily mess but it didn't hesitate either.
Any other thoughts on this?
Thanks too for the advice on the cleaning, that's clearly the issue here
Old 03-27-2016, 12:01 PM   #11
Koryak's Avatar
Glad the Seafoam helped despite the James Bond smoke screen. I won't ever do that where I live as there are environment police You'll find the 44K more effective and should notice more improvement after 100 miles. It even continues to work after you finish the tank by attacking carbon.
Old 03-27-2016, 01:22 PM   #12
you had pretty good luck with the stuff?
Old 03-27-2016, 02:29 PM   #13
Just ordered my 44K, Ill have it in by the end of the week. One thing we might want to mention is how many miles your car has on it. Mine is almost 60k miles.
Old 03-27-2016, 06:08 PM   #14
Koryak's Avatar
Yes, used to work at a dealership that used it and know several professional wrenches that like it too. The chemistry is PEA (high temp detergent) and is ideal for port fuel injection where gas hits the back of intake valves and cleans them. The only downside is price but much cheaper than engine disassembly.
Both Shell and Chevron gas use something similar but not strong enough once crud gets really built up. The crud on the valves absorbs fuel when the engine is cold so the mixture runs lean until heat can stop this. Years ago I couldn't believe how bad this was on my turbo Celica until the dealer convinced me to try BG 44K!
Old 03-27-2016, 07:35 PM   #15
Diehard's Avatar
I remember reading somewhere that some of the Top Tier Gasoline companies, use Chevron 65740 Techron Fuel System Cleaner.
Old 03-27-2016, 07:40 PM   #16
Hawkstang's Avatar
Region: Iowa
Mine has a very slight hesitation (talking like .01 seconds) of hesitation around 3500 during hard accelerations. My old Cougar had a spot in the power band like that as well but more noticeable.
I will say that getting the SCT tuner made my auto performance 2000% better/cleaner. The stock tune is total garbage on our autos IMO.
Hawkstang is offline   Reply With Quote
Old 03-27-2016, 07:44 PM   #17
Hawkstang's Avatar
Region: Iowa
Is it possible an old timer owned it before and it now has carbon build up? I'm just tossing out ideas so don't make too much fun of me. lol
Old 03-30-2016, 10:48 AM   #18
I'm laughing when I read the old timer remark, that's exactly the case. It had 12k miles on it when I bought it and now it has 62k. I also ordered the BG 44, it'll arrive on April 4th and we'll see what happens. My car now has only a minor hesitation now after sea foaming it, I'm hoping the BG 44 cleans the last bit up. I'll let you guys know
Old 03-30-2016, 07:53 PM   #19
Hawkstang's Avatar
Region: Iowa
Not sure if that is it, but a old dude had mine before me and I think he babied it too much. I might try that 44K stuff on my next fill up. Couldn't hurt I suppose.
Old 04-02-2016, 04:03 PM   #20
So I put in the 44k, first I put about 1/3rd of the can into my half full tank and ran that down to 1/4 tank, and then filled up and put the rest of the can so likely a little higher percentage than you're supposed to, no ill effects.
I have noticed that it has made a difference but I also replaced the air filter with a new OEM one and I think that made a bigger difference, the engine picks up revs way smoother. Especially downshifting and not well Rev matched, the engine picks up speed way more smoothly with no hesitation. Id recommend both steps to fix the issue. My car drives way better now.
Sent from my VS987 using Mustang Evolution mobile app
Old 04-02-2016, 04:37 PM   #21
Region: New Mexico
As a genuine old guy I can tell you not all old guys drive easy.
Do you guys use the cleaner normally or just to try to clear up problems?
WoodDA is offline   Reply With Quote
Old 04-02-2016, 06:15 PM   #22
Hawkstang's Avatar
Region: Iowa
Sorry, I shouldnt have made a blanket statement like that. I just wondered if maybe it didnt hit the 5k+ area in the RPMs enough with the previous owner.
I dumped a entire can of sea foam in half a tank 2 days ago and no smoke whatsoever, so I dont think the sea foam alone makes the smoke. I believe the smoke is carbon or gunk burning off, but I cant say for sure. I does make a funky stench though. Lol
I read up on the SF thoroughly and wouldnt use it or any additive more than once a year.
Old 04-02-2016, 06:29 PM   #23
Diehard's Avatar
LOL
This old guy hits the 5K+ every time I take mine out.
But I guess you could say I'm not the typical old guy.
Old 04-02-2016, 06:33 PM   #24
Hawkstang's Avatar
Region: Iowa
Originally Posted by Diehard View Post
LOL
I dont know how "old" you are, but if I live that long I'm sure Ill be in the same boat. Lol
Old 04-02-2016, 06:35 PM   #25
Hmm, I didn't put the seafoam into the tank. I sprayed it into the intake and smoked like hell when I burned it up. I put BG 44 in the Tank yesterday, I'll let you guys know how it works out. Hopefully the hesitation goes away.
Old 04-02-2016, 06:41 PM   #26
And don't worry about the old guy comment, I guess I'm not the typical old guy either. My mustang hits 6000 rpm probably more often than it should ...
Old 04-02-2016, 06:48 PM   #27
Diehard's Avatar
Well I hope you do live that long. And when that time comes I hope all the cars wont be driving themselves. LOL
Old 04-02-2016, 06:50 PM   #28
Hawkstang's Avatar
Region: Iowa
I'm 43 so Im prob not too far behind you. Been dealing with lymphoma for past 7 years, but still on the right side of the ground so all is good!
Old 04-02-2016, 07:04 PM   #29
Diehard's Avatar
Well I'm sorry to hear that. But you sound like you have a great attitude and that counts for a lot.
Old 04-02-2016, 07:07 PM   #30
Hawkstang's Avatar
Region: Iowa
Thanks. I def dont feel sorry for myself, a lot of unfortunate people have it much worse than I do, thats for sure. That crap is epidemic.
But back on subject... I jack too many threads as is. Lol
Old 04-10-2016, 06:46 AM   #31
Hi guys, just a quick update - used the BG 44 stuff, no difference to the hesitation. I'm guessing there's too much junk built up on the intake valves. I'm going to take apart the intake manifold next and spray things out manually. I'll take some pics and post them for you guys
Hey, do guys know how to turn that motor manually? I'm going to rotate it so I can expose each intake valve and spray it with intake cleaner.
Any thoughts?
Old 04-11-2016, 08:50 AM   #32
So I picked up some seafoam after running through my gas tank of 44k, I haven't run through much of it but I don't notice a difference yet between the 44k and this as far as improvement as seafoam is supposedly stronger. Also there is no cloud of smoke like I have seen some cars do when using sea foam, so it likely isnt all that dirty anymore.
I had a lot of driving time yesterday and was having a lot of fun with the better throttle response due to no hesitation, it drives like a new car. Almost 70k miles on it and likely has never had anything like that done.
Will update after I finish this tank of seafoam.
Old 04-11-2016, 08:57 AM   #33
ZombieSlayer's Avatar
I dont think you get the white smoke when you run it through your gas tank. I get it when I spray it into the Throttle Body when the car is on. The instructions are on the can. But I dont use the Sea Foam for the gas tank.
2016 Mustang GT: Guard Metallic w/ manual transmission; Performance Pack and Backup Sensors
ZombieSlayer is offline   Reply With Quote
Old 04-11-2016, 09:03 AM   #34
Ok that makes sense, I remember seeing videos and having friends do it where they did the 1/3 can in oil, 1/3 of can somewhere else that I cant remember, and one third in gas tank, so I thought I might have some smoke.
I followed the directions on the can and it said 1oz per gallon of fuel, the can is 16 ounces and the tank is like 14-16 so I put almost he whole thing in as I had just filled up.
Old 04-11-2016, 09:06 AM   #35
Well I think there is 1 kind of sea foam you put only in the gas tank, and another you put into the Intake or Throttle Body.
With the intake one, you turn the car on, rev to like 2500-3000 RPM, have someone spray the can into the TB or Intake, then shut the car off. Let is sit for 30-45 min. Then take the car for a drive. I usually drive it pretty hard.
Then you will see the white clouds.
2011 v6
2011 Mustang GT hesitation in low gear FirstGeneration 2011-2014 Mustang GT 2 06-28-2014 12:31 AM
Hesitation when cold falconplayer79 Pre-2005 V6 Mustang 12 09-12-2012 08:49 PM
Hesitation when cold alloy427r 2005-2010 Mustang GT 16 08-31-2012 05:58 PM
acceleration hesitation erk General Mustang Discussion 2 03-23-2011 11:17 AM
Hesitation acceleration blue95stang General Mustang Discussion 7 07-30-2008 10:26 AM
05:05 AM
